ButtonPressTime Reset doesn't work
Hi all,
I programmed an Arduino with 3 Pins with the following use:
  1. Press Enter
  2. Shutdown after pressed time of 5 seconds
  3. Restart after pressed time of 5 seconds
The program successfully notice the right pressed time for the buttons 2 und 3 but only once. If I want to use this again (e.g. after restart) a short press starts the routine.
Any idea? Thanks
My code:
#include <Keyboard.h>
#define BUTTON_ENTER_PIN 3
#define BUTTON_SHUTDOWN_PIN 6
#define BUTTON_REBOOT_PIN 9
#define REQUIRED_TIME 5000 // 5 Sekunden
#define KEY_KP_MINUS 0xDE
const char RunSequence[] = {
  KEY_LEFT_GUI, // Left-Windows-Key
  'r'
  pinMode(BUTTON_ENTER_PIN, INPUT_PULLUP);
  pinMode(BUTTON_SHUTDOWN_PIN, INPUT_PULLUP);
  pinMode(BUTTON_REBOOT_PIN, INPUT_PULLUP);
  digitalWrite(BUTTON_ENTER_PIN, HIGH);
  digitalWrite(BUTTON_SHUTDOWN_PIN, HIGH);
  digitalWrite(BUTTON_REBOOT_PIN, HIGH);
  Keyboard.begin();
  // ENTER
  static bool buttonEnterState = false;
  if (digitalRead(BUTTON_ENTER_PIN) == LOW)
    if (!buttonEnterState)
        // TODO: keyboard
        // Keyboard.press(KEY_ENTER);
		Keyboard.press(' ');
		delay(200);
		Keyboard.releaseAll();
        buttonEnterState = true;
  // SHUTDOWN
  static bool buttonShutdownState = false;
  static int buttonShutdownPressTime = 0;
  if (digitalRead(BUTTON_SHUTDOWN_PIN) == LOW)
    if (!buttonShutdownState)
        buttonShutdownPressTime = millis();
        buttonShutdownState = true;
    if (millis() - buttonShutdownPressTime > REQUIRED_TIME)
        // TODO: keyboard
		for (int i = 0; i < 2; i++)
			Keyboard.press(RunSequence[i]);
    	Keyboard.print("shutdown ");
      Keyboard.press(KEY_KP_MINUS);
      Keyboard.release(KEY_KP_MINUS);
      Keyboard.print("s ");
      Keyboard.print("t 5");
  static bool buttonRebootState = false;
  static int buttonRebootPressTime = 0;
  if (digitalRead(BUTTON_REBOOT_PIN) == LOW)
    if (!buttonRebootState)
        buttonRebootPressTime = millis();
        buttonRebootState = true;
    if (millis() - buttonRebootPressTime > REQUIRED_TIME)
        // TODO: keyboard
      Keyboard.print("r ");
Hi korki,
welcome to the arduino-forum.
Well done posting code as a code-section.
which exact type of arduino are you using?
my idea is to add more serial debug-output to trace what your code is really doing
another idea
using a state-machine instead of so many if-conditions
Hi StefanL38,
my board is Arduino Leonardo
Ok if it is a leonardo use a state-machine instead of so many if-conditions.
a state-machine reduces the number of if-conditions because each state (= mode of operation) is executed mutually exclusive.
This means code that should not be executed in a certain phase of your sequence will not executed.
modes of operation:
  • waiting for any keypress
  • if a keypress is detected start measuring time
  • check if key is pressed for 5 seconds continously
  • if pressed for 5 seconds continously send keyboard-presses
    if pressed for less than 5 seconds return to "waiting for any keypress"
the non-blocking nature of a state-machine will even enable to do things "in parallel"
like driving a display showing time = use as a clock
best regards Stefan
I used a tutorial to implement a state-machine. Works fine!
Great job. Thank you very much.
