How can I make the following task?
When a press a button, a led turns on, and only when I press the same button again, it turns off
Ku99:
Right here.... ignore the part where it's counting presses, but do your LED control where it's printing "on" or "off".
Try this code
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
// Variables will change:
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) { // if the state has changed, increment the counter
if (buttonState == HIGH) { // if the current state is HIGH then the button
Serial.println("on"); // wend from off to on:
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state,
// for next time through the loop
lastButtonState = buttonState;
if (buttonState) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
Thank you so much for your answer :). It is very hard to find someone who puts as much effort as you in an answer nowadays.
However, the code doesn't complete my task; the led turns on when I click the button, but if I stop clicking the button it turns off. To succesfully complete my task, when I click on the button, the led should turn on, and only when I click the button again, it should go off.
Is this homework? In which case should you not be doing "your task"?
Ku99:
answer answers.
Not much of an answer though only the last 5 lines actually matter and they don't do what was asked.
