Buttons for different display modes
Hey Guys, Basically I have an Arduino UNO, a 20x4 LCD screen, 4 push buttons and some temp sensors.
Now this project is going in my car to show battery voltages and a few temps.
I had the idea of pushing one button and all my voltages will show, (input via an analog input - 22k resistor on the neg, 68k on the pos)
I have attached code for that bit.
Now I just cant Figure out how to tell the audrino to switch what it displays once a button is pushed.
(to show the arduino what button is pushed I have 5V going into the push-buttons, Then each has its own different value of restance. I used this code to see what each value was.)
int sensePin =0;
void setup(){
analogReference(DEFAULT);
void loop (){
Serial.println(analogRead(sensePin));
When button 2 is pushed I would like the temps to show, I have Dallas 1 wire digital temp sensors (ill ask about them later)
So My question is how can i tell the Arduino to swap what it displays?
Thanks a heap guys.
Car_Monitor.ino (2.18 KB)
Something like this
const int sensePin = A0;
void setup(){
void loop (){
    int buttonValue = analogRead(sensePin); // buttonValue should be between 0 and 1023
    int displayMode = -1;   // Assume no change in display mode
    if (buttonValue > 1000) {
        displayMode = 3;
    if (buttonValue > 700) {
        displayMode = 2;
    if (buttonValue > 400) {
        displayMode = 1;
    if (buttonValue > 100) {
        displayMode = 0;
    Serial.print(buttonValue);
    Serial.print(" = ");
    Serial.println(displayMode);
You would need to adjust the values to suit your buttons.
If you have the inputs, I would just run each button to a seperate pin. If you want to use an analog read, look at getting a rotary or other multi-position switch - that way you can't have more than one button pressed at a time, and you (shouldn't) need to debounce.
For the multi-input, store which pin was pushed, and run a switch statement.
For the rotary or multi-position switch, something similar to Riva's code should work.
Thanks, Where do i specify to The Ardunino what code is connected to each display mode.
shark93:
After the code I wrote you have a variable called displayMode that will be the desired display mode required or -1 if no button pressed. Just use something like a switch case http://arduino.cc/en/Reference/SwitchCase to act out the desired mode.
Hey, Ive had a good try at it, hows it look? I'm getting an Error saying " error: expected initializer before 'if' "
On this line.
if (val == val2) { // make sure we got 2 consistant readings!
#include <LiquidCrystal.h> //import the Class for the LCD
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //pin numbers for the LCD
int switchPin = 0; // Select button is connected to pin 0
int val; // variable for reading the pin status
int val2; // variable for reading the delayed status
int buttonState; // variable to hold the select button state
int DisplayMode = 0; // Display Mode
int primary_battPin = 1; // Input from primary Battery
int secondary_battPin = 2; // Input from secondary Battery
int primary_val = 0; //temporarily store the primary input
int secondary_val = 0; //temporarily store the secondary input
float primary_pinVoltage = 0; // variable to hold the calculated voltage
float secondary_pinVoltage = 0; // variable to hold the calculated voltage
float primary_batteryVoltage = 0; //Temporarily store the primary Voltage
float secondary_batteryVoltage = 0; //Temporarily store the secondary Voltage
float ratio = 4.039; // The multiplier depending on which resistors used
// I used 68K and 22K 1/2 watt resistors.
pinMode(switchPin, INPUT); // Set the switch pin as input
buttonState = digitalRead(switchPin); // read the initial state
lcd.begin(20, 4); // initialise the LCD screen (20 characters long, by 4 lines high)
if (val != buttonState) { // the button state has changed!
if (val == LOW) { // check if the button is pressed
if (DisplayMode == 0) {DisplayMode = 1;} // Change to Mode 1
else {
if (DisplayMode == 1) {DisplayMode = 2;} // Change to Mode 2
else {
if (DisplayMode == 2) {DisplayMode = 3;} // Change to Mode 3
else {
if (DisplayMode == 3) {DisplayMode = 0;} // Change to Mode 0
if (value > (750) {
screen(1);
} else if (value > 550) {
screen(2);
} else if (value > 410) {
screen(3);
} else if (value > 340) {
screen(4);
} else if (value > 300) {
screen(5);
buttonState = val; // save the new state in our variable
// Now do whatever the DisplayMode Choosen
if (DisplayMode == 0) { // Battery Monitor Selection
primary_val = analogRead(primary_battPin); //Read the primary Battery input per loop
secondary_val = analogRead(secondary_battPin); //Read the secondary Battery input per loop
primary_pinVoltage = primary_val * 0.00488; //0.00488mV per 1024 steps for 5 Volts (ie; 5 / 1024 = 0.00488)
secondary_pinVoltage = secondary_val * 0.00488;
primary_batteryVoltage = primary_pinVoltage * ratio; //grab the calculated under 5Volt input and multiply it by the ratio to ..........
secondary_batteryVoltage = secondary_pinVoltage * ratio; // .............take it back to the 11~12~13Volt Range.
;lcd.setCursor(0, 0);// Place the Cursor on the Fist line first character position on the LCD screen
;lcd.print ("Batteries:")// Heading
;lcd.setCursor(0, 1); // First Line
;lcd.print("Primary : "); // Second Line
;lcd.print(primary_batteryVoltage); //The Voltage of Primary Battery.. S
;lcd.setCursor(0, 2);// Place the Cursor on the Second line first character position on the LCD screen
;lcd.print("Secondary: "); // Third Line
;lcd.print(secondary_batteryVoltage); //The Voltage of Secondary Battery.
delay(2000); //Pause for two seconds
if (DisplayMode == 1) { // Tempreture Selection
lcd.clear();
lcd.print("Air Temp : ");
// Air Temp Workings
lcd.print(" C");
lcd.print("Water Temp : ");
// Water Temp Workings
lcd.print(" C");
delay(2000);
if (DisplayMode == 2) { // Spare 1 Selection
lcd.clear();
lcd.print("Spare 1-1 : ");
// Spare 1-1 Workings
lcd.print(" ?");
lcd.print("Spare 1-2 : ");
// Temp2
lcd.print(" ?");
delay(2000);
if (DisplayMode == 3) { // Spare 2 Selection
lcd.clear();
lcd.print("Spare 2-1 : ");
// Spare 2-1 Workings
lcd.print(" ?");
lcd.print("Spare 2-2 : ");
// Spare 2-2 Workings
lcd.print(" ?");
delay(2000);
Thank you.
Several problems with your code I'm sorry to say.
You have several variables that are either not declared or not used (value, screen, val2 + many more)
You read the button state in setup but no more after that in loop so no amount of button pressing will do anything.
You have changed to using a digital pin (initial problem was analogue) but still have code to work with analogue pins.
Assuming this is the full code I can see now you will need to think about using a different structure (see BlinkWithoutDelay example) else the button press will be very unresponsive (button reading and long delays don't work well together)
I have attached the core of how your program could/should work and you just need to add in your display code where needed.
const int switchPin = 2;                  // Select button is connected to pin 2
const long refreshDelay = 2000;           // Duration between display updates
byte displayMode = 0;                     //Default display mode
void loop(){
  long currentTime = millis();            // Get current time
  while ((millis() - currentTime) < refreshDelay){
    if (digitalRead(switchPin) == HIGH) { // Alter HIGH/LOW depending on how switch is wired
      displayMode++;                      // Increment display mode
      if (displayMode > 2) {              // Reset display mode if beyond max mode
        displayMode = 0;
      break;                              // Exit while loop early as button pressed
    switch (displayMode) {
      case 0:
      // Put display mode 0 code here
      case 1:
      // Put display mode 1 code here
      case 2:
      // Put display mode 2 code here
Thank you so much for your help!
With the digital & analog pins, I'm using the Analog pins. Pin 0 is the input for the buttons. So does this mean I can just go const int switchPin = 0;
Or Because it says;
I should find an available Digital pin.
Not sure if I mentioned the button set up im going for is a voltage divider type set up so all 4 buttons goto the one pin. I have obtained each value each button sends to the Arduino
0- 890
1- 695
2- 363
3- 318
Now sorry for being such a pest Im really trying my best to understand all this, I just copied and pasted some of the old code in.
// include the library code:
// initialize the library with the numbers of the interface pins
const int switchPin = 6;                  // Select button is connected to pin 2
void loop(){
        displayMode = 0;
      case 0:
      case 1:
      case 2:
Thanks for your Input :slight_smile:
At least one of us us getting confused as original post and example code used analogRead but the next version you sent used digital (buttonState = digitalRead(switchPin); // read the initial state)
0- 890
1- 695
2- 363
3- 318
What value do you get with no button pressed, is it 0 or 1023 as this will effect the below code.
const int switchPin = A0;                 // Select button is connected to pin
byte oldDisplayMode = 0;                  //Old display mode
void loop(){
    int buttonValue = analogRead(switchPin); // buttonValue should be between 0 and 1023
    if (buttonValue > 792) {
      displayMode = 0;
    if (buttonValue > 529) {
      displayMode = 1;
    if (buttonValue > 340) {
      displayMode = 2;
    if (buttonValue > 159) {
      displayMode = 3;
    if (displayMode != oldDisplayMode) {  // Has display mode changed?
      oldDisplayMode = displayMode;
    case 0:
    case 1:
    case 2:
    case 3:
    // Put display mode 3 code here
This code will not work as is as you need to know what value is returned for no button pressed. I'm also not able to test it as I'm at work (no arduino here)
Hey,
I'm getting 0.
I'm sorry for the confusion, I had 2 versions of this going (mistake as it lead to so much confusion) I think Ill make the input pin an analog one.
This is what I have at the minute and Ive uploaded it to the Arduino.
byte buttonValue = 0;
void loop(){
      displayMode = 0;
      displayMode = 1;
      displayMode = 2;
      displayMode = 3;
    case 0:
    case 1:
    case 2:
    case 3:
Now When I push the button that send the value 890 To pin A0..... Nothing happens :frowning:
I cant believe how Frustrating this is, Maybe ive tried a project that's beyond my level of coding ability,:frowning:
Now When I push the button that send the value 890 To pin A0..... Nothing happens smiley-sad
More likely it's beyond my ability XD
I was cascading the button reading the wrong way so it was always coming out as mode 3
Try this.
byte oldDisplayMode = 0;                        // Old display mode
void loop(){
        byte displayMode = -1;                      // Assume no change in display mode
            displayMode = 3;
            displayMode = 2;
            displayMode = 1;
            displayMode = 0;
        if (displayMode != -1) {                    // Was button pressed?
                oldDisplayMode = displayMode;       // Set new display mode
    switch (oldDisplayMode) {
        case 0:
            lcd.print ("Batteries:");// Heading
        case 1:
        case 2:
        case 3:
I cant thank you enough!!!
It well on the way, Now yet another problem but im hoping its an easy fix,
Now when I press the button, the screen only reads, Secondary: (insert voltage)
Not the other bits like it should.
Now Ive double checked and the screen does work with this code
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 4);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
(I have made sure every line works)
Ideas on that one, It has to be in the code somewhere :frowning:
I found the problem!!!
I forgot to tell the Arduino how Big the screen was
lcd.begin(20, 4);.
Now Im onto my next adventure, The temp sensors :0
Ill post what im come up with here, Probally tomorrow its getting late here is Australia!
Riva, Thank you so much for your help !!!
No problem :blush:
Despite my tired eyes i want to get a little more done.
Now as i press the button the values change, This is all good until I release then all values freeze, Is there a way to make it keep reading without holding the button in or just change switch types?
2- Not Really a big thing, but when i turn the Arduino on, its just a blank screen until i press a button, In this section is it possible to put a message in, I tried putting it in a few spots but It didn't work properly , IE- the text i put in never went away.
Maybe just wire a resistor in so on start it gives a high value and then put that in the code?
Post you current code please. I don't have a LCD but I can substitute using Serial. The code should start in displayMode 0 and be updated every 2 seconds if no button pressed.
EDIT Just found bug after simulation. You need to change
to
Its tricky when one word or just a capital letter can stuff things up, Ive added in some code for my 3rd battery,
This is how it stands so far,
int camper_battPin = 3; //Input from camper battery
int camper_val = 0;//  //temporarily store the Camper input
float camper_pinVoltage =0; // variable to hold the calculated voltage
float camper_batteryVoltage = 0; //Temporarily store the camper Voltage
    lcd.begin(20, 4);
void loop(){
            displayMode = 3;
            displayMode = 2;
            displayMode = 1;
            displayMode = 0;
        case 0:
            lcd.print ("Hello:");// Heading
        case 1:
            camper_val = analogRead(camper_battPin); //Read the Camper Battery input per loop
            camper_pinVoltage = camper_val * 0.00488;
            camper_batteryVoltage = secondary_pinVoltage * ratio;
             lcd.setCursor(0, 4);    // First Line
            lcd.print("Camper   : "); // The Voltage of the Battery in the camper.
        case 2:
               lcd.clear();
        lcd.setCursor(0, 0);// Place the Cursor on the Fist line first character position on the LCD screen // Put display mode 1 code here
        lcd.print ("temps:");
        case 3:
shark93:
Does it work as expected now with the byte to int change?
Yep, Works Great now :slight_smile:
My next step is going tobe doing temps.
Just had a bit of an idea today, How hard would it be to:
  1. Make the Arduino Switch a relay when a voltage is reached in the primary battery.
  2. The Arduino knows when I have the car on.
Im guessing for 1 ill have to tell it something along the lines of, When Primary = (desired voltage), Output on an analog or digital pin?
and for 2 just have a voltage comes onto a pin and the arduino can read that ?
Cheers
shark93:
Pretty much like that. For the relay you would use digitalWrite. A good idea would be to program a slight dead zone/overlap so relay would come on a say 8V but only go off at 7V this could/would reduce relay flutter around the target voltage.
Most car ignitions have a voltage output that is only active when ignition is on. You could use this for question 2 but remember Arduino can only handle 5V where a car is most likely 12V
