Buttons help
I need help with my project, so if a button is pressed, then say hi in Serial Monitor, and if the button is pushed again, then say bye.
You go first: what have you tried so far?
So what have you written so far? Please post your progress with this project.
I'm not so sure how to do this exactly, so I haven't tried making the code yet.
Ok well have a look at this example: http://arduino.cc/en/Tutorial/ButtonStateChange .
But if you're really new, you might want to start at the top of the example page: http://arduino.cc/en/Tutorial/HomePage
TheXboxnerd:
something like this:
int ledPin = 13;
int buttonPin = 2;  //buttonPin
int lastPressed;
int state;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  int pressed = digitalRead(buttonPin);
  if (pressed == LOW)
    if (lastPressed == HIGH)
      state = !state;
      Serial.println(state? "hello" : "goodbye");
      digitalWrite(13, state? HIGH : LOW);
  lastPressed = pressed;
BulldogLowell:
I doubt if throwing the ternary operator at a beginner, without a single word of explanation, nor even saying it's called the ternary operator so he can look it up, has furthered his understanding one tiny bit.
JimboZA:
right, that was sort of my point here... heck I'll throw out a proposed solution for the problem, but the OP may have to do some work to understand.
it is the "cryptic dungeon-master" approach :blush:
I don't often use it, but it seemed à propos after the 2nd request
