hello , I'm trying to figure out press a button and the serial print will show me which color it is
I want it to be pressed as much time as i pressed no matter what color button i choose
what happens with my code is that if i press any color button the program just print it by repeat when I'm trying to press it once.
any help to solve the problem?
here is the code:
#define btn_length 5
char btns_Print[btn_length]={'Y','B','R','G','W'};
#define BtnPin_B 5
#define BtnPin_G 7
#define BtnPin_Y 8
#define BtnPin_R 6
#define BtnPin_W 11
unsigned long LastBtnChangeTime[btn_length];
int Btns[btn_length] = { BtnPin_Y ,BtnPin_B ,BtnPin_R ,BtnPin_G, BtnPin_W };
bool IsBtnPressed[btn_length];
for (int k = 0; k < btn_length; k++) {
pinMode(Btns[k], INPUT_PULLUP);
IsBtnPressed[k] = false;
for(int k = 0; k < btn_length; k++)
if (!IsBtnPressed[k] && (digitalRead(Btns[k]) == LOW) && (millis() - LastBtnChangeTime[k] > 50)) {
IsBtnPressed[k] = true;
Serial.println(btns_Print[k]);
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us.
The people who try to help with your pro…
When you posted your code without code tags did you receive a warning message ?
Why is this code in loop() ?
Why are you setting the LastBtnChangeTime only once in the sketch ?
Hello @alexvain31 ,
Questions similar to this are common on here so if you read some of the topics you'll find help. There are also lots of tutorials on reading buttons, here's mine: Buttons and other electro-mechanical inputs (introduction) , there are plenty of others.
Yes, i just agreed sorry
בתאריך שבת, 4 ביוני 2022 ב-19:06 מאת UKHeliBob via Arduino Forum <arduino@discoursemail.com >:
Hello alexvain31
Try this small example. The sketch uses a structured arry to collect all data.
BUTTON2TXT button2txts[] {
{ButtonPins[Blue], "blue", 0, 20, false},
You have to add the information as need for your project simply and may change the port addresses of the ButtonPins.
constexpr byte ButtonPins[] {A0, A1, A2, A3, A4};
enum Colors {Blue, Green, Yellow, Red, White};
struct BUTTON2TXT {
byte pin;
String text;
unsigned long stamp;
unsigned long duration;
int currentState;
for (auto ButtonPin: ButtonPins) pinMode(ButtonPin, INPUT_PULLUP);
unsigned long currentTime = millis();
for (auto &button2txt : button2txts) {
if (currentTime - button2txt.stamp >= button2txt.duration) {
button2txt.stamp = currentTime;
int newState = !digitalRead(button2txt.pin);
if (button2txt.currentState != newState) {
button2txt.currentState = newState;
if (newState) Serial.println( button2txt.text);
Дайте миру шанс!
system
Closed
December 1, 2022, 7:47pm
7
