Hi everyone,
I just changed my program to use the internal pullup resistors and now 2 of my buttons will not work. I have written a separate program to check if the wiring and boards are working properly, and they are. But in my project program I cannot get them to work.
For some reason only the "indexDownButton" and the "printDownButton" are not working. But the "indexUpButton" and "printUpButton" are working perfectly.
These buttons are used to increment values as seen in the program. I'm new to this, so I'm really sorry if my programming is hard for you guys to sift through. I really need to get this working by tomorrow night.
#include <openGLCD.h>
#include <openGLCD_Buildinfo.h>
#include <openGLCD_Config.h>
#include <Stepper.h>
#include <AccelStepper.h>
int STEPS = 1600;
int indexLength = 0;
AccelStepper stepper(1,3, 2);
int indexDownButton = 49;
int indexUpButton = 51;
int printUpButton = 46;
int printDownButton = 47;
int startButton = 52;
int modeButton = 53;
int relay = 50;
int busySig = 48;
int modePushCounter = 0;
int modeState = 0;
int lastModeState = 0;
int indexCounter = 0;
int indexUpState = 0;
int lastIndexUpState = 0;
int indexDownState = 0;
int lastIndexDownState = 0;
int printCounter = 0;
int printUpState = 0;
int lastPrintUpState = 0;
int printDownState = 0;
int lastPrintDownState = 0;
int JOGGING = 0;
int sigState = 0;
int lastSigState = 0;
GLCD.Init();
GLCD.SelectFont(Callibri11);
pinMode(modeButton, INPUT_PULLUP);
pinMode(startButton, INPUT);
pinMode(busySig, INPUT);
pinMode(relay, OUTPUT);
pinMode(indexUpButton, INPUT_PULLUP);
pinMode(indexDownButton, INPUT_PULLUP);
pinMode(printUpButton, INPUT_PULLUP);
pinMode(printDownButton, INPUT_PULLUP);
stepper.setMaxSpeed(1000000);
stepper.setAcceleration(10000);
delay(7000);
GLCD.ClearScreen();
modePushCounter = 1;
printUpState = digitalRead(printUpButton);
// compare the buttonState to its previous state
if (printUpState != lastPrintUpState) {
// if the state has changed, increment the counter
if (printUpState == LOW) {
// if the current state is HIGH then the button
// wend from off to on:
printCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(printCounter);
else {
// Delay a little bit to avoid bouncing
delay(50);
lastPrintUpState = printUpState;
if(indexCounter < 0)
(indexCounter = 0);
// save the current state as the last state,
//for next time through the loop
printDownState = digitalRead(printDownButton);
if (printDownState != lastPrintDownState) {
if (printDownState == LOW) {
printCounter--;
else {
delay(50);
indexUpState = digitalRead(indexUpButton);
if (indexUpState != lastIndexUpState) {
if (indexUpState == LOW) {
indexCounter = indexCounter + 5;
Serial.println(indexCounter);
else {
delay(50);
lastIndexUpState = indexUpState;
indexDownState = digitalRead(indexDownButton);
if (indexDownState != lastIndexDownState) {
if (indexDownState == LOW) {
indexCounter = indexCounter - 5;
else {
delay(50);
if(indexCounter > 80)
(indexCounter = 0);
indexLength = 3.183*(indexCounter+20); //3.183 steps/mm : add 20mm for spacing
// read the mode button input pin:
modeState = digitalRead(modeButton);
if (modeState != lastModeState)
if (modeState == LOW) {
modePushCounter++;
Serial.println(modePushCounter);
// if the current state is LOW then the button
// wend from on to off:
delay(50);
lastModeState = modeState;
//Change mode
if(modePushCounter == 1)
GLCD.SelectFont(Callibri11_bold);
GLCD.CursorTo(0, 0);
GLCD.print(" ");
GLCD.CursorTo(0, 1.75);
GLCD.print(" SELECT MODE ");
GLCD.CursorTo(0, 3);
GLCD.print(" TO BEGIN ");
GLCD.CursorTo(0, 4);
GLCD.print(" ");
GLCD.CursorTo(0, 2);
GLCD.print(" ");
if(modePushCounter == 2)
GLCD.SetFontColor(PIXEL_OFF);
GLCD.print(" JOG WEB ");
GLCD.SetFontColor(PIXEL_ON);
GLCD.print(" ");
GLCD.print(" PRESS START TO ");
GLCD.print(" ");
while(digitalRead(startButton) == HIGH)
stepper.run();
stepper.move(100);
if(modePushCounter == 3)
GLCD.print(" INTERMITTENT ");
GLCD.print(" ");
GLCD.print("PRINT LEGNTH: mm");
GLCD.CursorTo(8,2);
GLCD.print(indexCounter);
GLCD.print("STATUS: ");
sigState = digitalRead(busySig);
if(sigState != lastSigState)
delay(350);
stepper.runToPosition();
stepper.move(indexLength);
digitalWrite(relay, HIGH);
delay(25);
digitalWrite(relay, LOW);
lastSigState = sigState;
if(modePushCounter == 4)
GLCD.print(" CONTINUOUS ");
GLCD.print("# OF PRINTS: ");
GLCD.CursorTo(8,3);
GLCD.print(printCounter);
GLCD.CursorTo(8,2);
if(modePushCounter == 5)
(modePushCounter=1);
(indexCounter=0);
