Buttons
In the Sparkfun Inventors Kit the sample code for a push button runs under the format of "if_,then,else___"
if (((button1State == LOW)))
    digitalWrite(ledPin, HIGH);  // turn the LED on
    digitalWrite(ledPin, LOW);  // turn the LED off
I was wondering if you can have more than one "then" and the arduino randomly picks a "then". The format would be like" if_,then,or,or,else_". I tried to do that but the "or" doesn't turn orange like "if and else"
If there is a way to do this or close to doing this i would appreciate if you can reply
Thanks in advance
was wondering if you can have more than one “then” and the arduino randomly picks a “then”.
No this is the C++ language you are using.
There is no “then” in it at all.
The closest you could get it to generate a random number and use that in a switch statement to trigger a piece of code at “random”
Your best bet is to check for what you are looking for and then, if it isn't there, try a Random function to determine where to go from there.
Handy resources: Random: http://arduino.cc/en/reference/random#.UwQCr_ldV9U Switch: http://arduino.cc/en/Reference/SwitchCase#.UwQDePldV9U if...else: http://arduino.cc/en/Reference/Else#.UwQDevldV9U
int min = 1;
int max =6;
if (button1State == LOW)  {
    int var = random(min,max);
  switch (var) {
    case 1:
      //do something when var equals 1
    case 2:
      //do something when var equals 2
    default:
      // if nothing else matches, do the default
      // default is optional
Hope this helps!
Thanks i will try that and see if that works
Just wondering, for the code you put up am i able to put up more cases. e.i a case 3, 4, 5, or 6.
Ghostbusters: Just wondering, for the code you put up am i able to put up more cases. e.i a case 3, 4, 5, or 6.
Yes you can have as many cases as you want.
Thanks
tdewitt274, the code you put up what function does the min and max serve in the beggining
Ghostbusters: tdewitt274, the code you put up what function does the min and max serve in the beggining
It defines the range of the random numbers.
I prefer using IF statements as I feel it's less prone to mistakes (at least for me). I think the preferred method would be SWITCH in most cases.
You could do the same code as the below.
int min = 1;
int max = 6;
  if (var==1 && button1State == LOW) {
  } else if (var==2) {
With IF statements, you have the ability to do AND (&&) and OR (||) statements as part of your criteria. For example, the below.
if (var==1 && button1State == HIGH) {
Thanks :D Thanks :D Thanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :DThanks :D Thanks :D
Ghostbusters: Thanks :D Thanks :D Thanks :D Thanks :DThanks .....
There seems to be a syntax error in that code.
