Buy Atmega 2560 CHIP or similar chips having at least 64k on-chip
Where can I get Atmega 2560 chip(not board) or similar chips having at least 64kb on-chip memory and at least 30 GPIO's in India ?
I am doing a project involving :
touch-screen +LCD+SDCard : http://www.digibay.in/display/lcd/235-3-2-inches-wide-tft-lcd-module-400x240-with-sd-card-slot-and-touch-panel OR http://www.digibay.in/display/lcd/2-4-in-tft-lcd-display-65k-colors-320x240-touch-sd-slot
The Atmega328p chip runs out of both pins and memory in making the project run.
I have a budget for the project.The lesser it is the more better the project is.If not possible by any means then I will increase the budget. =(
I thought of using two atmega328p chips as these are very cheap ~230INR in probots.co.in so that the entire budget of the project is 230x2 + 999/1299 = 1359/1659 But it is also not possible since I'll have to send data among them and I THINK ( ie. not tested and verified) they'll run out of memory and pins.
Arduino Mega 2560 R3 is the solution to the problem but as I've mentioned I need to cut my budget.
The bare-bones micro-controller of Mega will work perfectly but I'm unable to find anybody selling it . It will be helpful for me if somebody knows any place/store where it is available.
Also if you know any other cheap AVR/PIC/Texas instruments boards/chips that can perform the job and is cheap and available in india (please refer the best store) it will do for me .
Thank You for your time and generosity.
See: http://forum.arduino.cc/index.php?topic=206292.msg1517616#msg1517616
