buzz wire game
Good Morning.
I am in a stage, and asked to make a Wire loop game, with a "start" button that should start the time count on lcd and a stop at the end that should stop time, but I'm having trouble creating the code because when I press the supposed button it conflicts with the wire. If you can help me, I'd appreciate it. The buttons I made with 2 metal washers with the cable soldered with tin in the middle.
We need to see a wiring diagram of what you are aiming at.
As tin is a conductor I can't see how this acts as a push button.
Agreed, a photo of this thing would help. I'm sure you must have read 'how to use this forum - please read', after all, its position a the top of every forum makes it easy to see and its title is quite self explanatory. I can only assume that your complete failure to follow the instructions come from your enthusiasm to get your project working as soon as you can!
@nelsontavares
Step away from the "REPORT TO MODERATOR" and nobody gets harmed :slight_smile:
Bob.
This is the circuit
Expect it isn’t. While reading the how to use this forum sticky post did you miss the bit about how to post an image?
The forum needs the URL of the image not the URL of a website that contains the image.
