Buzzer and button (Processing + Arduino)
Hello, I want to make something such that when a button is pressed, the piezo buzzer outputs a sound (like a car horn). How do I proceed to write a code for that in both processing and arduino? I'm still learning about serial communication between processing and arduino, so any help will be greatly appreciated :slight_smile:
Forget the interaction between Arduino and Processing for now. Can you control the buzzer just using the Arduino ?
Is the buzzer active, ie you supply a voltage and it makes a noise, or is it passive, ie you need to turn the voltage to the buzzer on and off at the frequency required in order to make a noise ?
byte pinBuzzer = 10;
byte pinBut    = A1;
void setup ()
  Serial.begin (115200);
  pinMode (pinBuzzer, OUTPUT);
  pinMode (pinBut,    INPUT_PULLUP);
void loop ()
#if 1
    digitalWrite (pinBuzzer,   digitalRead (pinBut));
#else
    digitalWrite (pinBuzzer, ! digitalRead (pinBut));
#endif
What hardware are you using?
