Can anyone help me with this code i just try to solve it but i can't anymore i want the relay to open using the fingerprint sensor when it is identify and automatically open and close within 10 seconds and when anyone who want to enter and not registered yet or unidentify the alarm will buzzer within 5seconds
here's my code
#include <SoftwareSerial.h>
#include <Wire.h>
#include <SD.h>
#include <DS3231.h>
#include <Adafruit_Fingerprint.h>
/* Webpage: https://www.electronoobs.com/eng_arduino_tut41.php
* Schematic: https://www.electronoobs.com/eng_arduino_tut40_sch1.php
* Code: https://www.electronoobs.com/eng_arduino_tut40_code3.php
* Youtube Channel: https://www.youtube.com/c/Electronoobs */
////////////////////////////////////INCLUDE ALL LIBRARIES/////////////////////////////////////////////
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4); //sometimes the adress is not 0x3f. Change to 0x27 if it dosn't work.
//Fingerprint libraries
int getFingerprintIDez();
SoftwareSerial mySerial(10, 11); // pin #2 is IN from sensor (GREEN wire)/ pin #3 is OUT from arduino (WHITE wire)
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
//Real time clock libraries
#include <DS3231.h>
DS3231 rtc(SDA, SCL);// Init the DS3231 using the hardware interface
//SD card read/write libraries
#include <SPI.h>
#include <SD.h>
File myFile;
//servo library
#include <Servo.h>
Servo miServo;
/////////////////////////////////////Input and outputs////////////////////////////////////////////////
int scan_pin = 13; //Pin for the scan push button
int add_id_pin = 12; //Pin for the add new ID push button
int open_door = 9; //Pin to open the door button
int RELAY_PIN = 6; //Pin for the Servo PWM signal
const int buzzer = 8; // Sound the alarm
//////////////////////////////////////Editable variables//////////////////////////////////////////////
int main_user_ID = 1; //Change this value if you want a different main user
int door_open_delay = 0.2;
int door_close_delay = 10000;
String file_name_to_save = "blackBox.txt";
//Other used variables in the code. Do not change!
bool scanning = false;
int counter = 0;
int id_ad_counter = 0;
bool id_ad = false;
uint8_t num = 1;
bool id_selected = false;
uint8_t id;
bool first_read = false;
bool main_user = false;
bool add_new_id = false;
bool door_locked = true;
Serial.begin(57600); //Start serial communication for fingerprint TX RX data.
rtc.begin(); //Start the real time clock (remember to set time before this code)
SD.begin(53); //Start SD card module with CS pin connected to D53 of the Arduino MEGA. The other pins are SPI pins
/*Now we open the new created file, write the data, and close it back*/
myFile = SD.open(file_name_to_save, FILE_WRITE); //Create a new file on the SD card named before
myFile.print("Door lock system started at ");
myFile.print(rtc.getTimeStr()); myFile.print(" and day "); myFile.print(rtc.getDateStr());
myFile.println(" ");myFile.println(" ");
myFile.close();
lcd.init(); //Init the LCD with i2c communication and print text
lcd.backlight();
lcd.setCursor(0,0);
lcd.print(" Press SCAN ");
lcd.setCursor(0,1);
lcd.print(" -door locked- ");
//Define pins as outputs or inputs
//BUZZER
pinMode(buzzer, OUTPUT);
pinMode(scan_pin,INPUT);
pinMode(add_id_pin,INPUT);
pinMode(open_door,INPUT);
pinMode(RELAY_PIN, OUTPUT);
miServo.write(door_close_delay); //Door close
digitalWrite(RELAY_PIN,HIGH);
delay(10000); // Door open
digitalWrite(RELAY_PIN,LOW); // Door close
finger.begin(57600); // set the data rate for the sensor serial port
/////////////////////////////////////////////VOID LOOP////////////////////////////////////////////////
/////////////////////////////////////////DOOR OPEN BUTTON PRESSED///////////////////////////////////
if(digitalRead(open_door))
door_locked = true;
lcd.setCursor(0,0);
lcd.print(" Door closed! ");
lcd.setCursor(0,1);
lcd.print(" ");
delay(2000);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
myFile.print(rtc.getDateStr()); myFile.print(" -- "); myFile.print(rtc.getTimeStr());
myFile.println(" -- Door was closed by a user");
myFile.close();
////////////////////////////////Scan button pressed/////////////////////////////////////////////////
if(digitalRead(scan_pin) && !id_ad)
myFile.println(" -- Attempt of openning door");
myFile.close();
scanning = true;
lcd.setCursor(0,0);
lcd.print(" Place finger ");
lcd.setCursor(0,1);
lcd.print("SCANNING--------");
while(scanning && counter <= 60)
getFingerprintID();
delay(100);
counter = counter + 1;
if(counter == 10)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("SCANNING ------");
if(counter == 20)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("SCANNING ----");
if(counter == 40)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("SCANNING --");
if(counter == 50)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("SCANNING ");
if(counter == 59)
lcd.setCursor(0,0);
lcd.print(" Timeout! ");
lcd.setCursor(0,1);
lcd.print(" Try again! ");
myFile.println(" -- Scanning timeout!");
myFile.close();
delay(2000);
if(door_locked)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" -door open- ");
scanning = false;
counter = 0;
///////////////////////////////END WITH SCANNING PART
//////////////////////////////////////////Add new button pressed///////////////////////////////////////////
if(digitalRead(add_id_pin) && !id_ad)
myFile.println(" -- Add new user attempt. Require identification!");
myFile.close();
add_new_id = true;
lcd.setCursor(0,0);
lcd.print(" Scan main user ");
lcd.setCursor(0,1);
lcd.print(" finger first! ");
while (id_ad_counter < 40 && !main_user)
getFingerprintID();
delay(100);
id_ad_counter = id_ad_counter+1;
if(!add_new_id)
id_ad_counter = 40;
id_ad_counter = 0;
add_new_id = false;
if(main_user)
lcd.setCursor(0,0);
lcd.print(" Add new ID# to ");
lcd.setCursor(0,1);
lcd.print(" the database ");
delay(1500);
print_num(num);
id_ad = true;
myFile.println(" -- Add new user permission granted");
myFile.close();
lcd.setCursor(0,0);
lcd.print("ERROR! Only main");
lcd.setCursor(0,1);
lcd.print("user can add IDs");
delay(1500);
if(door_locked)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
id_ad = false;
myFile.println(" -- The user does not have permission to add new user");
myFile.close();
if(digitalRead(scan_pin) && id_ad)
id=num;
while (! getFingerprintEnroll() );
id_ad = false;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" New ID saved ");
lcd.setCursor(4,1);
lcd.print("as ID #");
lcd.setCursor(11,1);
lcd.print(id);
delay(3000);
if(door_locked)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
add_new_id = false;
main_user = false;
id_ad = false;
if(digitalRead(add_id_pin) && id_ad)
num = num + 1;
if(num > 16)
num=1;
print_num(num);
}//end of void
/*This function will print the ID numbers when adding new ID*/
void print_num(uint8_t)
if (num == 1)
lcd.setCursor(0,0);
lcd.print("Select ID number");
lcd.setCursor(0,1);
lcd.print(">1 2 3 4 ");
if (num == 2)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 1 >2 3 4 ");
if (num == 3)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 1 2 >3 4 ");
if (num == 4)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 1 2 3 >4 ");
if (num == 5)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(">5 6 7 8 ");
if (num == 6)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 5 >6 7 8 ");
if (num == 7)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 5 6 >7 8 ");
if (num == 8)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 5 6 7 >8 ");
if (num == 9)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(">9 10 11 12 ");
if (num == 10)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 9 >10 11 12 ");
if (num == 11)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 9 10 >11 12 ");
if (num == 12)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 9 10 11 >12 ");
if (num == 13)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(">13 14 15 16 ");
if (num == 14)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 13 >14 15 16 ");
if (num == 15)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 13 14 >15 16 ");
if (num == 16)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" 13 14 15 >16 ");
/*This function will read the fingerprint placed on the sensor*/
uint8_t getFingerprintID()
uint8_t p = finger.getImage();
switch (p)
case FINGERPRINT_OK:
case FINGERPRINT_NOFINGER: return p;
case FINGERPRINT_PACKETRECIEVEERR: return p;
case FINGERPRINT_IMAGEFAIL: return p;
default: return p;
// OK success!
p = finger.image2Tz();
switch (p)
case FINGERPRINT_OK: break;
case FINGERPRINT_IMAGEMESS: return p;
case FINGERPRINT_FEATUREFAIL: return p;
case FINGERPRINT_INVALIDIMAGE: return p;
default: return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK)
scanning = false;
counter = 0;
if(add_new_id)
if(finger.fingerID == main_user_ID)
main_user = true;
id_ad = false;
add_new_id = false;
main_user = false;
id_ad = false;
miServo.write(door_open_delay); //delay so door is open
digitalWrite(RELAY_PIN,HIGH); //
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" User match ");
lcd.setCursor(0,1);
lcd.print(" ID: #");
lcd.setCursor(6,1);
lcd.print(finger.fingerID);
lcd.setCursor(9,1);
lcd.print("%: ");
lcd.setCursor(12,1);
lcd.print(finger.confidence);
myFile.print(" -- User match for ID# "); myFile.print(finger.fingerID);
myFile.print(" with confidence: "); myFile.print(finger.confidence); myFile.println(" - door open");
myFile.close();
door_locked = false;
delay(4000);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(50);
}//end finger OK
else if(p == FINGERPRINT_NOTFOUND)
scanning = false;
id_ad = false;
counter = 0;
lcd.setCursor(0,0);
lcd.print(" No match ");
lcd.setCursor(0,1);
add_new_id = false;
main_user = false;
myFile.print(" -- No match for any ID. Door status still the same");
myFile.close();
delay(2000);
if(door_locked)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(2);
return p;
}//end finger error
}// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
return finger.fingerID;
/*This function will add new ID to the database*/
uint8_t getFingerprintEnroll() {
int p = -1;
if(!first_read)
lcd.setCursor(0,0);
lcd.print("Add new as ID# ");
lcd.setCursor(14,0);
lcd.print(id);
lcd.setCursor(0,1);
while (p != FINGERPRINT_OK) {
switch (p) {
lcd.setCursor(0,0);
lcd.print(" Image taken! ");
lcd.setCursor(0,1);
lcd.print(" ");
delay(100);
first_read = true;
lcd.setCursor(0,0);
lcd.print(id);
lcd.setCursor(0,1);
lcd.setCursor(0,0);
lcd.print(" Comunication ");
lcd.setCursor(0,1);
lcd.print(" ERROR! ");
lcd.setCursor(0,0);
lcd.print(" -Image ");
lcd.setCursor(0,1);
default:
lcd.setCursor(0,0);
lcd.print(" -Unknown ");
lcd.setCursor(0,1);
// OK success!
p = finger.image2Tz(1);
switch (p) {
lcd.setCursor(0,0);
lcd.print("Image converted!");
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,0);
lcd.print("Image too messy!");
lcd.setCursor(0,1);
lcd.print(" ");
return p;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
lcd.setCursor(0,0);
lcd.print(" No fingerprint ");
lcd.setCursor(0,1);
lcd.print("features found ");
return p;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
default:
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
lcd.setCursor(0,0);
lcd.print(" Remove finger! ");
lcd.setCursor(0,1);
lcd.print(" ");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
lcd.setCursor(0,1);
lcd.print("ID# ");
lcd.setCursor(4,1);
lcd.print(id);
p = -1;
lcd.setCursor(0,0);
lcd.print("Place again the ");
lcd.setCursor(0,1);
lcd.print("same finger ");
switch (p) {
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
default:
lcd.setCursor(0,0);
lcd.setCursor(0,1);
// OK success!
p = finger.image2Tz(2);
switch (p) {
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" ");
return p;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
default:
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
// OK converted!
lcd.setCursor(0,0);
lcd.print(" Creating model ");
lcd.setCursor(0,1);
lcd.print("for ID# ");
lcd.setCursor(8,1);
lcd.print(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
lcd.setCursor(0,0);
lcd.print(" Print matched! ");
lcd.setCursor(0,1);
lcd.print(" ");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
lcd.setCursor(0,0);
lcd.print("Fingerprint did ");
lcd.setCursor(0,1);
lcd.print("not match ");
return p;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
lcd.setCursor(0,1);
lcd.print("ID# ");
lcd.setCursor(4,1);
lcd.print(id);
p = finger.storeModel(id);
lcd.setCursor(0,0);
lcd.print(" Stored ");
lcd.setCursor(0,1);
lcd.print(" ");
myFile.print(" -- New fingerprint stored for ID# "); myFile.println(id);
myFile.close();
first_read = false;
id_ad = false;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
lcd.setCursor(0,0);
lcd.print("Could not store ");
lcd.setCursor(0,1);
lcd.print("in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
lcd.setCursor(0,0);
lcd.print("Error writing to");
lcd.setCursor(0,1);
lcd.print("flash ");
return p;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
return p;
