Buzzer Type, current voltage Versus Tone()
I'm looking at this little transducer/buzzer. Do I drive this with PWM, by using the Tone() function, or does it just need a constant voltage, like digitalWrite(buzzerPin, HIGH)? Also, it give the sound level rating at 3 volts. Will 5 volts hurt it, or should I use a resistor between the arduino pin and this? And finally, I don't see anything in the data sheet about markings for positive or negative, so does it matter which lead I hook to ground and which to a digital pin?
Thanks,
Hi, This is sometimes confusing.. I use this terminology:
BUZZER; A noise producing component that makes a sound when 5V (usually) is applied.
BEEPER: A transducer that makes sound when a changing voltage SIGNAL is applied to it.
So the beeper is like a little speaker, and you usually use the Arduino TONE function to make sounds.
A BUZZER always makes the same sound when powered, whereas the BEEPER can make different sounds with different applied signals.
You have a "BEEPER" which is just a sound transducer with no electronics of its own..
Great, that's what I was thinking, but I wasn't sure. So if it's a "transducer" or "piezo", it always needs something like the TONE function. Hence digikey's term "Transducer, Externally Driven".
But then the "frequency" rating on digikey is 4khz -- that must just be it's optimal level it's designed for, but it will actually change with whatever frequency I give it via my TONE function.
Thanks.
That's exactly right...
Write a little code that sweeps the Tone from 1000 to maybe 6000 Hz and you'll find some frequencies are LOUDer due to the transducer properties.
Here are a few things that I wrote that you can try out:
http://arduino-info.wikispaces.com/YourDuinoStarter_BeeperTone
http://arduino-info.wikispaces.com/Project-HandBat
This one has a swept frequency:
http://arduino-info.wikispaces.com/Brick-Noisemakers
OK, thanks for the examples.
cheers.
You could put 2 or 3 diodes in series to drop 1.2 - 1.8 volts.
