i tried to figure out from where the problem is and i concluded its from the fingerprint sensor it makes no sense but it's happennenig and now am really confused
PS : void buzzer() and the pinMode in void configurationBroche() are the ones wich concerne the buzzer the rest of the code is working properly
PS 2: the buzzer is just an alarme when the door still open after a specified delay thats all
#include <Adafruit_Fingerprint.h>
#include <HardwareSerial.h>
#include <ESP8266WiFi.h>
//#include <WiFi.h>
const char* NOM;
const char* SALLE;
String Event_Name = "historique des entrés";
String Key = "cmzj-mXCZk0corohNRlWAMndXnKjDLqJIjwlslpECJ7";
String resource = "/trigger/" + Event_Name + "/with/key/" + Key;
// Maker Webhooks IFTTT
const char* server = "maker.ifttt.com";
// Replace with your SSID and Password
const char* utilisateur = "Orange-BFAA";
const char* mdp = "topnetbnh";
LiquidCrystal_I2C lcd(0x27, 20, 4);
Adafruit_Fingerprint empreinte = Adafruit_Fingerprint(&Serial1);
int BouttonBas = 13;
int BouttonHaut = 26;
int BouttonSelect = 33;
int menu = 1;
int EtatdePorte;
initialisation();
configurationBroche();
Empreinte();
Bouttons();
buzzer();
void initialisation(){
lcd.init();
lcd.backlight();
lcd.print("Placer votre empreinte");
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
empreinte.begin(57600);
delay(5);
if (empreinte.verifyPassword()) {
Serial.println("capteur d'empreinte detecté");
Serial.println("aucune capteur d'empreinte detecté");
while (1) { delay(1); }
Serial.println(F("Reading sensor parameters"));
empreinte.getParameters();
Serial.print(F("Status: 0x")); Serial.println(empreinte.status_reg, HEX);
Serial.print(F("Sys ID: 0x")); Serial.println(empreinte.system_id, HEX);
Serial.print(F("Capacity: ")); Serial.println(empreinte.capacity);
Serial.print(F("Security level: ")); Serial.println(empreinte.security_level);
Serial.print(F("Device address: ")); Serial.println(empreinte.device_addr, HEX);
Serial.print(F("Packet len: ")); Serial.println(empreinte.packet_len);
Serial.print(F("Baud rate: ")); Serial.println(empreinte.baud_rate);
empreinte.getTemplateCount();
if (empreinte.templateCount == 0) {
Serial.print("aucun empreinte enregistré dans la capteur, essayez de faire l'exemple (enroll)");
else {
Serial.println("attendre pour une empreinte validé");
Serial.print("capteur contien "); Serial.print(empreinte.templateCount); Serial.println(" templates");
Serial.print("Connection a: ");
Serial.print(utilisateur);
WiFi.begin(utilisateur, mdp);
int timeout = 10 * 4; // 10 seconds
while (WiFi.status() != WL_CONNECTED && (timeout-- > 0)) {
delay(250);
Serial.print(".");
Serial.println("");
if (WiFi.status() != WL_CONNECTED) {
Serial.println("erreur de connexion");
Serial.print("WiFi connecte a: ");
Serial.print(millis());
Serial.print(",IP address : ");
void configurationBroche() {
pinMode(BouttonHaut, INPUT_PULLUP);
pinMode(BouttonBas, INPUT_PULLUP);
pinMode(BouttonSelect, INPUT_PULLUP);
pinMode(12, INPUT_PULLUP);
void Empreinte(){
getFingerprintID();
if (empreinte.fingerID == 1) {
Serial.print("!!--");
Serial.println(empreinte.fingerID);
NOM = "ahmed benhamad";
if (empreinte.confidence >= 60) {
Serial.print("Attendace Marked for "); Serial.println(NOM);
// digital write - open the door
delay(50);
if (empreinte.fingerID == 88 ) {
digitalWrite(2, LOW);
NOM = "mondher ayeb";
Serial.print("Empreinte marqué pour "); Serial.println(NOM);
} //don't ned to run this at full speed.
empreinte.fingerID = 0;
void Bouttons() {
if (!digitalRead(BouttonBas)){
menu++;
MAJMenu();
delay(100);
while (!digitalRead(BouttonBas));
if (!digitalRead(BouttonHaut)){
menu--;
MAJMenu();
delay(100);
while(!digitalRead(BouttonHaut));
if (!digitalRead(BouttonSelect)){
executionAction();
MAJMenu();
delay(100);
while (!digitalRead(BouttonSelect));
void buzzer(){
EtatdePorte=digitalRead(12);
if (EtatdePorte == HIGH){
tone(14, 400);
else{
noTone(14);
delay(200);
void MAJMenu() {
switch (menu) {
case 0:
menu = 1;
case 1:
lcd.clear();
lcd.print(">Salle 1");
lcd.setCursor(0, 1);
lcd.print(" Salle 2");
lcd.setCursor(0, 2);
lcd.print(" Salle 3");
lcd.setCursor(0, 3);
lcd.print(" Annuler");
case 2:
lcd.clear();
lcd.print(" Salle 1");
lcd.print(">Salle 2");
case 3:
lcd.clear();
lcd.print(">Salle 3");
case 4:
lcd.clear();
lcd.print(">Annuler");
case 5:
menu = 4;
uint8_t getFingerprintID() {
uint8_t p = empreinte.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image prise");
case FINGERPRINT_NOFINGER:
Serial.println("aucune empreinte détecté");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("erreur de communication");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("erreur de lire de l'empreinte");
return p;
default:
Serial.println("erreur inconnu");
return p;
// OK success!
p = empreinte.image2Tz();
switch (p) {
Serial.println("Image converti");
case FINGERPRINT_IMAGEMESS:
Serial.println("l'image est malpropre");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("impossible de trouver les caractéristique de l'empreinte");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = empreinte.fingerSearch();
if (p == FINGERPRINT_OK) {
Serial.println("correspondance trouvé");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
lcd.clear();
lcd.println("aucune correspondance");
delay(3000);
lcd.clear();
lcd.println("Ressayer une autre fois");
return p;
return p;
// found a match!
lcd.clear();
lcd.print("Empreinte validee");
delay(2000);
lcd.clear();
MAJMenu();
return empreinte.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
p = empreinte.fingerFastSearch();
void executionAction() {
switch (menu) {
case 1:
action1();
case 2:
action2();
case 3:
action3();
case 4:
action4();
void action1() {
lcd.clear();
lcd.print("Salle 1 est ouvert");
delay(1500);
SALLE="salle 1";
IFTTTRequete();
ESP.restart();
void action2() {
lcd.clear();
lcd.print("Salle 2 est ouvert");
delay(1500);
SALLE="salle 2";
IFTTTRequete();
ESP.restart();
void action3() {
lcd.clear();
lcd.print("Salle 3 est ouvert");
delay(1500);
SALLE="salle 3";
IFTTTRequete();
ESP.restart();
void action4() {
lcd.clear();
lcd.print("Annulation...");
delay(1500);
ESP.restart();
void IFTTTRequete() {
Serial.print("Connection Ă ");
Serial.print(server);
WiFiClient client;
int retries = 5;
while (!!!client.connect(server, 80) && (retries-- > 0)) {
Serial.print(".");
if (!!!client.connected()) {
Serial.println("erreur de connexion...");
Serial.print("Request resource: ");
Serial.println(resource);
String jsonObject = String("{\"value1\":\"") + NOM + "\",\"value2\":\"" + SALLE
client.println(String("POST ") + resource + " HTTP/1.1");
client.println(String("Host: ") + server);
client.println("Connection: close\r\nContent-Type: application/json");
client.print("Content-Length: ");
client.println(jsonObject.length());
client.println();
client.println(jsonObject);
int timeout = 5 * 10; // 5 seconds
while (!!!client.available() && (timeout-- > 0)) {
delay(100);
if (!!!client.available()) {
Serial.println("No response...");
while (client.available()) {
Serial.write(client.read());
Serial.println("\nclosing connection");
client.stop();
kolaha
May 31, 2022, 11:46am
2
if (!client.available()) {
kolaha
May 31, 2022, 12:02pm
3
void Bouttons() {
if (!digitalRead(BouttonBas))menu++;
if (!digitalRead(BouttonHaut))menu--;
if (!digitalRead(BouttonSelect))executionAction();
delay(100);
while (!digitalRead(BouttonBas) || !digitalRead(BouttonHaut) || !digitalRead(BouttonSelect));
MAJMenu();
really appreciate that but please read my actual problem
Put some serial prints in (start with buzzer) to see what's going on.
kolaha
May 31, 2022, 12:23pm
6
@ahmed6666 UPD try if this edition does alternative
//#include <WiFi.h>
const char* NOM;
const char* SALLE;
const int BouttonBas = 13;
const int BouttonHaut = 26;
const int BouttonSelect = 33;
int menu = 1;
int EtatdePorte;
void setup(){
initialisation();
void loop(){
Empreinte();
Bouttons();
buzzer();
void initialisation() {
lcd.init();
lcd.backlight();
yield(100);
yield(5);
while (1) {
yield(1);
else {
yield(250);
Serial.print(".");
Serial.println("");
void Empreinte() {
getFingerprintID();
yield(50);
void Bouttons() {
yield(100);
MAJMenu();
void buzzer() {
EtatdePorte = digitalRead(12);
if (EtatdePorte == HIGH)tone(14, 400,1000, BUZZER_CHANNEL);
else noTone(14);
yield(200);
void MAJMenu() {
switch (menu) {
case 0:
menu = 1;
case 1:
lcd.clear();
case 2:
lcd.clear();
case 3:
lcd.clear();
case 4:
lcd.clear();
case 5:
menu = 4;
switch (p) {
return p;
return p;
return p;
default:
return p;
// OK success!
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
return p;
lcd.clear();
yield(3000);
lcd.clear();
return p;
return p;
// found a match!
lcd.clear();
yield(2000);
lcd.clear();
MAJMenu();
switch (menu) {
case 1:
action1();
case 2:
action2();
case 3:
action3();
case 4:
action4();
void action1() {
lcd.clear();
yield(1500);
SALLE = "salle 1";
IFTTTRequete();
ESP.restart();
void action2() {
lcd.clear();
yield(1500);
SALLE = "salle 2";
IFTTTRequete();
ESP.restart();
void action3() {
lcd.clear();
yield(1500);
SALLE = "salle 3";
IFTTTRequete();
ESP.restart();
void action4() {
lcd.clear();
yield(1500);
ESP.restart();
WiFiClient client;
int retries = 5;
while (!client.connect(server, 80) && (retries-- > 0)) {
Serial.print(".");
if (!client.connected()) {
client.println();
while (!client.available() && (timeout-- > 0)) {
yield(100);
client.stop();
me either thats why it confuses me
is there any possibility that the problem is from the ESP8266 ?
and you say if anything else is disconnected the buzzer start to work, yes?
Which ESP8266 are you using?
Post an image of your wiring with the buzzer connected.
Post a schematic.
Post, below, the latest version of the code you are using.
no, as i said the code but the buzzer work properly thats why i didnt connect the fingerprint sensor i just connected le LCD and it works, what i meant is that i built the buzzer code out of my main code and it worked (thats how i built my code step by step and then it ends in a single file) so i tried to put the buzzer in every single file and it worked except in the test of fingerprint file
#include <Wire.h>
//#include <WiFi.h>
const char* NOM;
const char* SALLE;
const int buzzer = 14;
const int sensor = 12;
int menu = 1;
int EtatdePorte;
initialisation();
Empreinte();
Bouttons();
alarme();
lcd.init();
lcd.backlight();
delay(100);
delay(5);
else {
delay(250);
Serial.print(".");
Serial.println("");
pinMode(sensor, INPUT_PULLUP);
void Empreinte(){
getFingerprintID();
delay(50);
void Bouttons() {
menu++;
MAJMenu();
delay(100);
menu--;
MAJMenu();
delay(100);
executionAction();
MAJMenu();
delay(100);
void alarme(){
EtatdePorte=digitalRead(sensor);
digitalWrite(buzzer, HIGH);
else{
noTone(buzzer);
delay(200);
void MAJMenu() {
switch (menu) {
case 0:
menu = 1;
case 1:
lcd.clear();
case 2:
lcd.clear();
case 3:
lcd.clear();
case 4:
lcd.clear();
case 5:
menu = 4;
switch (p) {
return p;
return p;
return p;
default:
return p;
// OK success!
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
return p;
lcd.clear();
delay(3000);
lcd.clear();
return p;
return p;
// found a match!
lcd.clear();
delay(2000);
lcd.clear();
MAJMenu();
switch (menu) {
case 1:
action1();
case 2:
action2();
case 3:
action3();
case 4:
action4();
void action1() {
lcd.clear();
//digitalWrite(
delay(1500);
SALLE="salle 1";
IFTTTRequete();
ESP.restart();
void action2() {
lcd.clear();
delay(1500);
SALLE="salle 2";
IFTTTRequete();
ESP.restart();
void action3() {
lcd.clear();
delay(1500);
SALLE="salle 3";
IFTTTRequete();
ESP.restart();
void action4() {
lcd.clear();
delay(1500);
ESP.restart();
WiFiClient client;
int retries = 5;
Serial.print(".");
client.println();
delay(100);
client.stop();
Well thanks for posting the project image. I am confused that the devices used in the code like the fingerprint sensor or lcd is not connected. You do know the setup() does not properly WORK if those devices are NOT connected?
Sorry I cannot help you. Good luck with your project.
ahmed6666:
void buzzer(){
tone(14, 400);
Serial.println("buzzer should be working";
digitalwrite(13,HIGH);
else{
noTone(14);
Serial.println("buzzer off");
digitalwrite(13,LOW);
delay(200);
I would start there and see what happens, its possible that one of the librarys used here is conflicting with the Tone function.
if you see the serial output or the LED illuminate then you at least know that the code is meeting the requirements for the tone to be generated. then you can troubleshoot why it doesnt generate.
the pin 13 in digitalWrite is for what ?
that will turn the built in LED on that is on pin 13
system
Closed
November 28, 2022, 10:50pm
18
