Using PuTTY I have been able to make a working ANSI terminal on my WinXP PC.
I haven’t tried colors yet but screen control and cursor positioning work.
It took changing a setting to get screen clears to work not through background color change.
Anyway, here is a terminal app version of Blink Without Delay with Instant User I/O added.
Compiled & tested, hard part is setting up PuTTY right. Make it 80 chars x 25 lines, 57600 & defaults.
/* Blink without Delay -- with UL fixes and User Input, formatted for ANSI terminal
Turns on and off a light emitting diode(LED) connected to a digital
pin, without using the delay() function. This means that other code
can run at the same time without being interrupted by the LED code.
The circuit:
* LED attached from pin 13 to ground.
* Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
modifed to add User-I/O as BWD2 1 Jan 2014
by GoForSmoke :-P
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to
// set pin numbers:
const int ledPin = 13; // the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
unsigned long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
unsigned long tWait = 1000UL; // interval at which to blink (milliseconds)
unsigned long userFactor = 100UL;
void displayData( void )
Serial.write( 27 ); // Esc
Serial.print( F("[12;12H") ); // set cursor
Serial.print( F("[K") ); // erase to end of line
Serial.print( F("blink wait = ") );
Serial.println( tWait );
Serial.print( F("[14;12H") ); // set cursor
Serial.print( F("[K" )); // erase to end of line
Serial.print( F("factor = ") );
Serial.println( userFactor );
Serial.print( F("[16;12H") ); // set cursor
Serial.print( F("User Entry? > ") );
void usageMsg( void )
Serial.print( F("[2J") ); // clear VT100 screen
Serial.print( F("[2;12H") ); // set cursor
Serial.println ( F ( __FILE__ ) );
Serial.println( F("\nUSER CONTROL CHARS\n") );
Serial.println( F("F to blink faster, half factor") );
Serial.println( F("S to blink slower, double factor") );
Serial.println( F("digit entered x factor = blink\n") );
displayData();
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
Serial.begin( 57600 );
Serial.println( F("\nBWD2-PuTTY startup\n") );
usageMsg();
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if ( currentMillis - previousMillis > tWait )
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
ledState = !ledState; // ! is logical not, opposite
// set the LED with the ledState of the variable:
digitalWrite( ledPin, ledState );
} // end of blink state change
// lowest priority is serial data because it is slow.
if ( Serial.available() )
char serChar = Serial.read();
if ( serChar >= '0' && serChar <= '9' ) // digits only
if ( serChar > '0' )
tWait = (long)( serChar - '0' ) * userFactor;
tWait = 10UL * userFactor;
displayData();
serChar &= 0xDF; // strips bit 5, makes lowercase alphas uppercase
if ( serChar == 'F' ) // faster
if ( userFactor > 1UL )
userFactor /= 2UL; // increase the frequency
tWait /= 2UL;
displayData();
if ( serChar == 'S' ) // slower
if ( userFactor < 1000UL )
userFactor *= 2UL; // decrease the frequency
tWait *= 2UL;
displayData();
if ( serChar == 'H' ) // help
usageMsg();
} // end of serial available
// finished all tasks
