By the registers how to prohibit to have 2 digital pins at the same time in ON ?
Hello,
In my project the DUE will pilot up to 6 three-phase frequency inverters controlling 6 220v tri-geared motors.
Each gearmotor is connected to a crank rod system controlled in position by a 360 ° potentiometer. The normal working stroke will be + 60 ° / 0 ° / -60 °
For the drive control part (out of the internally managed position feedback loop in the Due, I need for each motor to:
1 ADC input (no problem at the moment)
1 PWM output (subject treated on another post http://forum.arduino.cc/index.php?topic=457632.0 )
2 Digital outputs to control the direction of rotation at the input of the drives
Specifications for digital outputs:
 Prohibition of having both outputs of the same ON drive at the same time. This is equivalent to forbidding front and rear control at the same time
 Possibility of having the output pair OFF on the same inverter.
 In order to have the PID management as fast as possible, I wish to use the registers of the SAM AT91SAM 3X8E of the DUE
12 pins reserved for the control of the direction of rotation of the 6 motors:
Direction of drive rotation 1: Pin 31 (PWM L0) and Pin 35 (PWM H0)
Direction of drive rotation 2: Pin 36 (PWM L1) and Pin 37 (PWM H1)
Direction of drive rotation 3: Pin 38 (PWM L2) and Pin 39 (PWM H2)
Direction of drive rotation 4: Pin 40 (PWM L3) and Pin 41 (PWM H3)
Direction of drive rotation 5: Pin 08 (PWM L5) and Pin 44 (PWM H5)
Direction of drive rotation 6: Pin 07 (PWM L6) and Pin 45 (PWM H6)
These 12 pins will be interfaced for power with 3 integrated circuits ULN2803
Do you already have a code using the registers and having this feature to prohibit 2 outputs at ON at the same time
A test does not penalize the speed of the permutation
Certainly the inverter, forbids this possibility by failing.
A solution in code form would be more elegant
For now, I only know how to switch digital pins without any overlapping state check.
Here is my code with other numbers of pins I had taken at random (pins 25 and 45)
uint32_t pin_25 = (1u << 0); // masque pour la pin 25 (Port Pin D0)
uint32_t pin_45 = (1u << 18); // masque pour la pin 45 (Port Pin C18)
REG_PIOD_OER = pin_25; // pin 25 est configuré en output au niveau du port D
REG_PIOC_OER = pin_45; // pin 45 est configuré en output au niveau du port C
REG_PIOD_CODR = pin_25; // Basculement pin 25 en OFF (clear)
REG_PIOC_CODR = pin_45; // Basculement pin 45 en OFF (clear)
//Changement état des pins 25 et 45 avec “Delay”
delayMicroseconds(1); // wait for a 1ms
REG_PIOD_SODR = pin_25; // Basculement pin 25 en ON (set)
delayMicroseconds(1); / / wait for a 1ms
REG_PIOC_SODR = pin_45; // Basculement pin 45 en ON (set)
Bonjour,
Dans mon projet la DUE pilotera jusqu’à 6 variateurs de fréquences triphasé commandant 6 motoréducteurs 220v tri.
Chaque motoréducteur est relié à un système bielle manivelle contrôlé en position par un potentiomètre à 360°. La course de travail normale sera +60° /0° / -60°
Pour la partie de commande du variateur (hors de la boucle de feedback de position géré en interne dans la Due, j’ai besoin pour chaque moteur de :
1 Entrée ADC (aucun problème pour l’instant)
1 Sortie PWM (sujet traité sur un autre post http://forum.arduino.cc/index.php?topic=457632.0 )
2 Sorties digitales afin de commander le sens de rotation à l’entrée des variateurs
Cahier des charges pour les sorties digitales :
 Interdiction d’avoir les 2 sorties d’un même variateur ON en même temps. Cela revient à interdire la commande avant et la commande arrière en même temps
 Possibilité d’avoir la paire de sortie OFF sur un même variateur.
 Afin d’avoir une gestion du PID la plus rapide possible, je souhaite utiliser les registres du SAM AT91SAM 3X8E de la DUE
12 Pins réservées pour la commande des sens de rotation des 6 moteurs :
Sens rotation du variateur 1 : Pin 31 (PWM L0) et Pin 35 (PWM H0)
Sens rotation du variateur 2 : Pin 36 (PWM L1) et Pin 37 (PWM H1)
Sens rotation du variateur 3 : Pin 38 (PWM L2) et Pin 39 (PWM H2)
Sens rotation du variateur 4 : Pin 40 (PWM L3) et Pin 41 (PWM H3)
Sens rotation du variateur 5: Pin 08 (PWM L5) et Pin 44 (PWM H5)
Sens rotation du variateur 6 : Pin 07 (PWM L6) et Pin 45 (PWM H6)
Ces 12 pins seront interfacées pour la puissance avec 3 circuits intégrés ULN2803
Avez-vous déjà un code utilisant les registres et ayant cette fonctionnalité d’interdire 2 sorties à ON en même temps
Un test ne pénalisant pas la rapidité de la permutation
Certes le variateur, interdit cette possibilité en se mettant en défaut.
Une solution sous forme de code serait plus élégante
Pour l’instant, je ne sais que basculer des pins digitales sans aucune vérification de chevauchement d’état.
Voici mon code avec d’autres numéro de pins que j’avais prise au hasard (pins 25 et 45)
(Voir le code ci-dessus en fin de la partie en anglais)
Don’t do that.
The chip doesn’t have any protection against two pins being on at the same time. How would it know which one to switch off if you did? Maybe they are active-low pins where active is actually “off”?
You write the code in a way that doesn’t allow this.
(Some microcontrollers have timers that are specifically designed for controlling muti-phase motors, with outputs for each of several phases that are configurable to have "off time" in between the on-time of the different phases, so that no two outputs are on at the same time. It looks like the Due (SAM3X) might have such a feature:
The PWM macrocell controls 8 channels independently. Each channel controls two complementary square output waveforms. Characteristics of the output waveforms such as period, duty-cycle, polarity and dead-times (also called dead-bands or non-overlapping times) are configured through the user interface.
But I don't think there is any way to get these configured via the Arduino environment. You could try the Atmel forums for a (hopefully) better answer.
@Morgans
Do not do that
The test code that I inserted in my previous post is concerned by the above quote
Is it incomplete?
How do you change it to make it compliant?
Do not do that. ...
You write the code in a way that does not allow this
Do you have an example code to apply to a pair of digital pin to meet my need?
@Morgans
Don't do that
Le code d’essai que j’ai inséré dans mon post précédent est concerné par la citation ci-dessus
Est-il incomplet ?
Comment le modifier pour le rendre conforme ?
Don't do that. …
You write the code in a way that doesn't allow this
Avez-vous un exemple de code à appliquer sur une paire de pin digitale pour répondre à mon besoin ?
When I look at the pinout diagram, I can see some différences with your tab:
Direction of drive rotation 1: Pin 34 (PWM L0) and Pin 35 (PWM H0)
Direction of drive rotation 3: Pin 43 (PWM L2) and Pin 39 (PWM H2)
Here is an example of what I think is dead time programmation for PWM High and Low (not tested) :
void setup () {
  // PWM Set-up on pin PC7 and PA20 (Arduino Pin 39 and 43): see Datasheet chap. 38.5.1 page 973
  PMC->PMC_PCER1 |= PMC_PCER1_PID36;                   // PWM on
  // Select Instance=PWM; Signal=PWMH2 (channel 2); I/O Line=PC7 (P7, Arduino pine 39, see pinout diagram) ; Peripheral=B
  PIOC->PIO_ABSR |= PIO_ABSR_P7;                        // Set PWM pin perhipheral type B
  PIOC->PIO_PDR |= PIO_PDR_P7;                          // Set PWM pin to an output
  // Edit : Select Instance=PWM; Signal=PWML2 (channel 2); I/O Line=PA20 (P20, Arduino pine 43, see pinout diagram) ; Peripheral=B
  PIOA->PIO_ABSR |= PIO_ABSR_P20;                        // Set PWM pin perhipheral type B
  PIOA->PIO_PDR |= PIO_PDR_P20;                          // Set PWM pin to an output
  // Enable the PWM channel 2 (see datasheet page 973)
  PWM->PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(42);    // Set the PWM clock rate to 2MHz (84MHz/42). Adjust DIVA for the resolution you are looking for
  PWM->PWM_CH_NUM[2].PWM_CMR = PWM_CMR_CALG | PWM_CMR_CPRE_CLKA;     // The period is  left aligned, clock source as CLKA on channel 2
  PWM->PWM_CH_NUM[2].PWM_CPRD = 1000000;                             // Channel 2 : Set the PWM frequency 2MHz/(2 * CPRD) = F ; 1< CPRD < 2exp24  -1 ; F = 1 Hz
  PWM->PWM_CH_NUM[2].PWM_CDTY = 800000;                              // Channel 2: Set the PWM duty cycle to x%= (CDTY/ CPRD)  * 100 % ; Duty cycle = 80%
  // Dead time between 2 complementary PWM H and L, e.g.:
  PWM->PWM_CH_NUM[2].PWM_CMR |= PWM_CMR_DTE;                          // Enable dead time
  uint32_t DTH = 100;                                                //DTH is between 0 and CPRD - CDTY = 200000
  uint32_t DTL = 100;                                                //DTL is between 0 and CDTY = 800000
  PWM->PWM_CH_NUM[2].PWM_DT = DTH | DTL << 16;                      // Datasheet chap. 38.6.2.4 page 981 and chap. 38.7.43 page 1051
  PWM->PWM_ENA = PWM_ENA_CHID2;
  // Alternately, you can use this format :  REG_PWM_CPRD2 = 1000000;
  // In this example, Frequency is 1 HZ with a DT of 80%
  delay(100);
I mean aside from the dead-time generation in the PWM timers, it's your responsibility not to turn on two pins at the same time. If you don't want two pins on, then don't turn them both on.
(I was assuming with my short comment that you had read the sections of the datasheet that West and Newbie are referring to.)
@Morgans
Of course, I was thinking about the possibility of overlap during some microseconds.
Biensûr , je pensais au risque de chevauchement durant possible durant quelque microsecondes.
@Westfw
The Atmel forum is a good idea, but I will first see the code proposed by ard_newbie that I thank elsewhere.
Le forum Atmel est une bonne idée , mais je vais d’abord voir le code proposé par ard_newbie que je remercie par ailleurs.
@ Ard-newbie, thanks for your comments and your code :grin:
:grin: Thank you for pointing out my mistake: :-X :-[, it should read:
But regarding the second difference, I thought:
Pin 38 (PWM L2) identical to Pin 43 (PWM L2)
Pin 39 (PWM H2) identical to Pin53 (PWM H2)
Like Pin 37 (PWM H1) identical to Pin42 (PWM H1)
Thanks again for your code that I will study thanks to the valuable data you have put in comments: smiley-mr-green: (datasheet Atmel-11057C)
In deciphering little by little, I have questions:
On page 973, I find in the table 3 lines PWMH2 with Peripheral B: PA13, PB14 and PC7
In the file varian.cpp of the Due, I find that a match: pin39 <-> PC7 (used in your code)
What is PA13, PB14 (datasheet page 973)?
What about the CPU tabs AT91SAM3X8E?
Without connection with Due physical pine?
I started studying to study your code using the datasheet and the brave Google!
I also checked / compiled and uploaded your code into Due
Result:
PIN 39 turns ON for 3.3ms before turning OFF. The period of the ON / OFF signal is 17ms
Pin 43 never switches to ON
See screenshot in attachment
I also did not understand why:
  • you put an isolated delay in the loop loop().
  • Why I have a cyclic tilting of the pin39 while Setup() is supposed to be executed only once when the Due
To clarify the structure of the code I need:
The switching times ON / OFF can be very fast when my actuators arrive and will maintain the target position to reach. (Motor PID)
If the Forward pilot pin 39 and the Reverse pilot pin 43
  1. During the setup program the pins 39 (forward) and 43 (reverse) must be every 2 in OFF
  2. 2 functions void Forward () and void Reverse () must handle the direction of rotation
  3. Before ordering Forward, you would need: Reverse = OFF, Dead time then Forward in ON
  4. Before ordering Reverse, you would need: Forward = OFF, Dead time then Reverse in ON
@Ard-newbie,merci pour vos remarques et votre code :grin:
:grin: Merci de m’avoir fait remarquer mon erreur :-X :-[ , il faut bien lire :
Mais concernant la seconde différence, je pensais que :
Pin 38 (PWM L2) identique à Pin 43 (PWM L2)
Pin 39 (PWM H2) identique à Pin53 (PWM H2)
Comme Pin 37 (PWM H1) identique à Pin42 (PWM H1)
Merci encore pour votre code que je vais étudier grâce aux précieuses données que vous avez mises en commentaires :grin: (datasheet Atmel-11057C)
En déchiffrant peu à peu, il me vient des questions :
A la page 973, je trouve dans le tableau 3 lignes PWMH2 avec Peripheral B : PA13, PB14 et PC7
Dans le fichier varian.cpp de la Due, je trouve qu’une correspondance : pin39 <-> PC7(utilisé dans votre code)
A quoi correspond PA13, PB14 (datasheet page 973) ?
Que des pattes du CPU AT91SAM3X8E ?
Sans liaison avec pin physique de la Due ?
J’ai commencé à étudier à étudier votre code à l’aide du datasheet et du brave Google !
J’ai également vérifié / compilé et téléversé votre code dans la Due
Résultat :
La pin 39 passe ON pendant 3,3ms avant de passer en OFF. La période du signal ON / OFF est de 17ms
La pin 43 ne bascule jamais en ON
Voir copie d’écran en pièce jointe
J’ai également pas compris pourquoi :
  • vous avez mis un delay isolé dans la boucle Loop().
  • Pourquoi j’ai un basculement cyclique de la pin39 alors que Setup() est censé être exécuté qu’une fois à la mise sous tension de la Due
Pour éclaircir le principe de structure du code dont j’ai besoin :
Les temps de commutations ON / OFF peuvent être très rapide lorsque mes actionneurs arriveront et maintiendront la position cible à atteindre. (PID moteur)
Si la pin 39 pilote Forward et la pin 43 pilote Reverse
  1. Lors du programme setup les pin 39 (forward) et 43 (reverse) doivent être toutes les 2 en OFF
  2. 2 fonctions void Forward() et void Reverse() doivent gérer le sens de rotation
  3. Avant de commander Forward, Il faudrait : Reverse = OFF, Dead time puis Forward en ON
  4. Avant de commander Reverse, Il faudrait : Forward = OFF, Dead time puis Reverse en ON[/quote]
    [/quote]
I forgot to specify an important point in my need
Recall :
Direction of rotation of drive 1: Pin 34 (PWM L0) and Pin 35 (PWM H0)
Direction of rotation of drive 2: Pin 36 (PWM L1) and Pin 37 (PWM H1)
Direction of rotation of drive 3: Pin 43 (PWM L2) and Pin 39 (PWM H2)
Direction of rotation of drive 4: Pin 40 (PWM L3) and Pin 41 (PWM H3)
Direction of rotation of drive 5: Pin 08 (PWM L5) and Pin 44 (PWM H5)
Direction of rotation of drive 6: Pin 07 (PWM L6) and Pin 45 (PWM H6)
Additional requirements:
The time in each of the 12 pins (36, 37, 43, 39, 40, 41, 08, 44, 07 and 45) is ON must vary independently of each other and also for pins using the same channel (Time varying from 0 to infinity)?
Is it possible to generate 2 times on the same channel?
If Yes, how do we do it?
The switching time in ON of the 12 pins mentioned must be able to be controlled independently of each other in functions Void of the Arduino code
The switching time in ON of the aforementioned 12 pins is called to vary continuously as a function of the actual position comparison of each actuator with respect to the target position to be executed.
These target values vary continuously depending on the information received by the serial link
J’ai oublié de préciser un point important dans mon besoin
Rappel :
Sens de rotation de l'entraînement 1: Pin 34 (PWM L0) et Pin 35 (PWM H0)
Sens de rotation de l'entraînement 2: Pin 36 (PWM L1) et Pin 37 (PWM H1)
Sens de rotation de l'entraînement 3: Pin 43 (PWM L2) et Pin 39 (PWM H2)
Sens de rotation de l'entraînement 4: Pin 40 (PWM L3) et Pin 41 (PWM H3)
Sens de rotation de l'entraînement 5: Pin 08 (PWM L5) et Pin 44 (PWM H5)
Sens de rotation de l'entraînement 6: Pin 07 (PWM L6) et Pin 45 (PWM H6)
Besoins complémentaires :
Le temps pendant chacune les 12 pins (36, 37, 43, 39, 40, 41, 08, 44, 07 et 45) est en ON doit varier indépendamment l’une de l’autre et également pour des pins utilisant le même canal (temps variant de 0 à l’infini) ?
Est-ce possible de générer 2 temps sur le même canal ?
Si Oui, comment fait-on ?
Le temps de commutation en ON des 12 pins citées devront pouvoir être commandé indépendamment l’un de l’autre dans des fonctions Void du code Arduino
Le temps de commutation en ON des 12 pins citées sa appelé à varier en permanence en fonction de la comparaison de position réelle de chaque actionneur par rapport à la position cible à exécuter.
Ces valeurs cibles varient en permanence en fonction d’information reçues par la liaison série.
[/quote]
Some of Sam3x pins are not broken out on DUE...I just followed the pinout diagram with PWM indications, so you may be right, some PWM outputs are duplicated and available.
A fix for PWML2 output: I did a copy paste for PA20 with PC7, so obviously it should be this for PWML2:
And delay() in loop is useless.
I corrected the 2 lines according to your indications
With PWM-> PWM_CH_NUM [2] .PWM_CDTY = 800000; , As Duty was 80%, I had only a tension around 2.6v and pins 39 and 49 in High (no opposition of the states on pins 39 and 43!)
I did 2 other tests
PWM-> PWM_CH_NUM [2] .PWM_CDTY = 0; The pine 39 is High and the pine 43 Low and without any Dead Time
PWM-> PWM_CH_NUM [2] .PWM_CDTY = 1000000; Pine 39 is Low and Pine 43 High and without any Dead Time
See 2 screenshots
In yellow the pin39 and in blue the pin43
I do not understand how to use your remark at the bottom of your code
// Alternately, you can use this format: REG_PWM_CPRD2 = 1000000;
I need 3 different states:
1) Pin39 Low and Pin43 Low (after running Setup and when my actuator reached its target)
2) Pin43 Low + Dead Time + Pin39 High (forward rotation)
3) Pin39 Low + Dead Time + Pin43 High (reverse rotation)
Problem with the suggested sample code:
  1. Never at the output of the Setup the 2 pins 39 and 43 are in Low
  2. No possibility to my knowledge to have the 2 pins 39 and 43 are Low when the target position is reached
  3. The Dead Time between High and Low states and vice versa does not work
J’ai corrigé les 2 lignes selon vos indications
Avec PWM->PWM_CH_NUM[2].PWM_CDTY = 800000; , comme Duty était à 80% , je n’avais qu’une tension aux alentours de 2,6v et les pins 39 et 49 en High (**pas d’opposition des états sur les pins 39 et 43 ! ) **
J’ai fait 2 autres essais En mettant
PWM->PWM_CH_NUM[2].PWM_CDTY = 0; la pin 39 est High et la pin 43 Low et sans aucun Dead Time
PWM->PWM_CH_NUM[2].PWM_CDTY = 1000000; la pin 39 est Low et la pin 43 High et sans aucun Dead Time
Voir les 2 copies d’écrans
En jaune la pin39 et en bleu la pin43
Je ne comprends pas comment utiliser votre remarque en bas de votre code
J’ai besoin de 3 états différents :
  1. Pin39 Low et Pin43 Low (après l’exécution du Setup et lors mon actionneur a atteint sa cible)
  2. Pin43 Low + Dead Time + Pin39 High (rotation avant)
  3. Pin39 Low + Dead Time + Pin43 High (rotation arrière)
Problème avec le code d’exemple proposé :
  1. Jamais en sortie du Setup les 2 pins 39 et 43 sont en Low
  2. Pas de possibilité a ma connaissance d’avoir les 2 pins 39 et 43 sont Low lorsque la position cible est atteinte
  3. Le Dead Time entre les états High et Low et vice versa ne fonctionne pas
Test Oscillo - V2 - PWM-PWM_CH_NUM[2].PWM_CDTY = 0; Jaune Pin39 et Bleu Pin43.png
Test Oscillo - V2 - PWM-PWM_CH_NUM [2] .PWM_CDTY = 1000000; Jaune Pin39 et Bleu Pin43.png
I did some modifications in the snippet to show that it works :
#define DISABLE_SW_PROT (0)
#define ENABLE_SW_PROT  (1)
#define ENABLE_HW_PROT  (2)
#define PASSWD  (0x50574D)
void setup () {
  // PWM Set-up on pins PC7 and PA20 (Arduino Pins 39(PWMH2) and 43(PWML2)): see Datasheet chap. 38.5.1 page 973
  PMC->PMC_PCER1 |= PMC_PCER1_PID36;                   // PWM power on
  PWM->PWM_WPCR = PWM_WPCR_WPCMD(DISABLE_SW_PROT)
                | PWM_WPCR_WPRG0
                | PWM_WPCR_WPRG1
                | PWM_WPCR_WPRG2
                | PWM_WPCR_WPRG3
                | PWM_WPCR_WPRG4
                | PWM_WPCR_WPRG5
                | PWM_WPCR_WPKEY(PASSWD);                 // Disable PWM write protect
  PWM->PWM_DIS = PWM_DIS_CHID2;                        // Disable PWM channel 2
  // Select Instance=PWM; Signal=PWMH2 (channel 2); I/O Line=PC7 (P7, Arduino pin 39, see pinout diagram) ; Peripheral=B
  PIOC->PIO_ABSR |= PIO_PC7B_PWMH2;                     // Set PWM pin perhipheral type B
  // Select Instance=PWM; Signal=PWML2 (channel 2); I/O Line=PA20 (P20, Arduino pin 43, see pinout diagram) ; Peripheral=B
  PIOA->PIO_ABSR |= PIO_PA20B_PWML2;                    // Set PWM pin perhipheral type B
  PWM->PWM_CH_NUM[2].PWM_CMR = PWM_CMR_CPRE_CLKA;     // The period is left aligned, clock source as CLKA on channel 2
  PWM->PWM_CH_NUM[2].PWM_CPRD = 1000;                             // Channel 2 : Set the PWM frequency 2MHz/(2 * CPRD) = F ;
  PWM->PWM_CH_NUM[2].PWM_CDTY = 500;                             // Channel 2: Set the PWM duty cycle to x%= (CDTY/ CPRD)  * 100 % ;
  /****  Try with (DTH=500, DTL=0) then (DTH=0,DTL=500)  then (DTH=500,DTL=500)****/
  uint32_t DTH = 0;                                                //DTH is between 0 and CPRD - CDTY BUT MAX value = 2 exp13  - 1 = 8191
  uint32_t DTL = 0;                                              //DTL is between 0 and CDTY BUT MAX value = 2exp13 - 1 = 8191
If you want PWMHx and PWMLx LOW together, you need to adjust dead time accordingly.
If you want to modify dead time “on the fly” you need PWM_DTUPD (refer to the datasheet)
Hello,
I come back to report my progress after several days during which Google Translate and the datasheet pricked my eyes
Thank you for the time you give me to answer my problems.
  1. I uploaded your code to 2Khz as is with the duty at 50% with DTH = 0 - DTL = 0
    Result: OK none Dead Time car DTH = 0 - DTL = 0
Reminder for interpretation of attachments:
Yellow curve = Pin 39 (PWMH2) and blue curve = Pin 43 (PWML2)
  1. I have passed the value of Dead Time at DTH = 10 - DTL = 10 while keeping the Duty at 50%
    Result Duty50%: OK the Dead Time of 5μs is visible
    (See 3 attachments 50% - DTH = 10 - DTL = 10)
  2. Keeping the Dead Time at DTH = 10 - DTL = 10 keeping the Duty at 100%
    Duty100% Result: This looks fine: No Dead Time visible because no state change
  3. I passed the frequency PWM from 2Khz to 10Khz
    Note:
    I think the formula used for the PWM frequency is inappropriate because the period is aligned to the left.
    I used the following formula F Pwm = MCK / (CPRD * DIVA)
    This is confirmed by observing the PWM signal on the oscilloscope
    Result: with a frequency at 10Khz and a Duty at 50%, the Dead Time still works
    (See 1 attachment Test Code 0 - Tfou57_PWM L et H à 10Khz et Dead Time DTH 10 et DTL 10 soit 05 micros secondes)
Creation of 3 programs containing the combinations of I will meet to control the direction of my drives:
  • void P39_LOW_and_P43_LOW ()
  • void P39_HIGH_and_P43_LOW ()
  • void P39_LOW_and_P43_HIGH ()
    Loop () adds 3 “for” loops of different duration for each of the 3 “Void” functions
My working code See 1 attachment
Problem: “Dead Time” does not work on this code
The “Dead Time” causes me problems when running my 3 programs “Void” used loop in “Loop” and each with different loop lengths
Question 1:
How to set up a 10μs Dead Time between each pins state changeover 39 and 43?
Does the Dead Time have to resume all lines of code in Setup ()?
I need a fastest code with a minimum of code line to best manage the PID of the engines
Question 2:
How can the above code be optimized
  • I may have lines repeated unnecessarily apart of course deleting all lines of duplicate code comments
Question 3:
  • Tables management of the 2 pins of direction for each of the 6 engines to facilitate the scructure of the final code (management of 12 pins)
Texte original :
Bonjour,
Je reviens faire part de mon avancement après plusieurs jours pendant lesquels Google Translate et le datasheet me piquaient les yeux
Merci pour le temps que vous m’accordez pour répondre à mes problèmes.
  1. J’ai téléversé votre code à 2Khz tel quel avec le duty à 50% avec DTH=0 - DTL=0
    Résultat : OK aucune Dead Time car DTH=0 - DTL=0
Rappel pour interprétation des pièces jointes:
Courbe jaune = Pin 39 (PWMH2) et courbe bleu = Pin 43 (PWML2)
  1. J’ai passé la valeur de Dead Time à DTH=10 - DTL=10 en gardant le Duty à 50%
    Résultat Duty50% : OK le Dead Time de 5µs est visible
    (voir 3 pièces jointes 50% - DTH=10 - DTL=10)
  2. En gardant le Dead Time à DTH=10 - DTL=10 en gardant le Duty à 100%
    Résultat Duty100% : Cela semble correct : Aucun Dead Time visible car pas de changement d’état
  3. J’ai passé la fréquence PWM de 2Khz à 10Khz
    Nota :
    Je pense que la formule utilisée pour la fréquence PWM est non appropriée car la période est alignée à gauche.
    J’ai utilisé la formule suivante F Pwm = MCK /(CPRD * DIVA)
    Cela se vérifie à l’observation du signal PWM à l’oscilloscope
    Résultat : avec une fréquence à 10Khz et un Duty à 50%, le Dead Time fonctionne toujours
    ( voir 1 pièce jointe Test Code 0 - Tfou57_PWM L et H à 10Khz et Dead Time DTH 10 et DTL 10 soit 05 micros secondes)
Création de 3 programmes reprenant les combinaisons de je vais rencontrer pour commander le sens de mes variateurs :
  • void P39_LOW_and_P43_LOW()
  • void P39_HIGH_and_P43_LOW()
  • void P39_LOW_and_P43_HIGH()
    Rajout dans Loop() de 3 boucles « for » d’une durée différente pour chacune des 3 fonctions « Void »
Mon code de travail ( voir pièce jointe)
Problème : « Dead Time »ne fonctionne pas sur ce code
Le « Dead Time » me pose des problèmes lors de l’exécution de mes 3 programmes « Void « utilisés en boucle dans « Loop » et chacun avec des longueurs de boucle différentes
Question 1:
Comment mettre en place une Dead Time de 10µs entre chaque basculement d’état des pins 39 et 43 ?
Faut-il pour fonctionner le Dead Time reprendre toutes les lignes de code du Setup() ?Il me faut un code le plus rapide avec un minimum de ligne de code afin gérer au mieux le PID des moteurs
Question 2:
Comment le code ci-dessus peut-il être optimisé
  • J’ai peut-être des lignes répétées inutilement à part bien sûr la suppression de toutes les lignes de code en doubles mises en commentaires
Question 3:
  • Gestion par tableaux des 2 pins de direction pour de chacun des 6 moteurs afin de faciliter la scructure du code final (gestion de 12 pins)
_CodeV5c_PWM_L_et_H_de_Tfou57_3_Void_et_Loop_10Khz.ino (10 KB)
The signal obtained by the code is not regular over time.
I can observe high and low state width variations depending on the trigger of the oscilloscope trigger (variations of pin 43 High blue curve - up to 37μs)
On this screenshot, I also observe 2 areas with the pine 39 High (yellow curve) for no reason for a duration of 40μs left and 16μs in the center of the screenshot
Delay of pine 39 to change to LOW state
Do you have a correction to offer me for
  1. Restore a cyclic regularity of the Loop loop ()
  2. To activate the Dead Time between each state change (High and Low)
All ideas will be the goods that came
see Attachment
Le signal obtenu par le code n’est pas régulier dans le temps .
Je peux observer des variations de largeur d’état High et Low selon le déclenchement du trigger de l’oscilloscope ( variations de pin 43 High courbe bleu - allant jusqu’à 37µs)
Sur cette copie d’écran ,j’observe également des 2 zones parasistes avec la pin 39 High ( courbe jaune ) sans raison durant une durée de 40µs à gauche et de 16µs au centre de la capture d’écran
Retard de la pin 39 à passer à l’état LOW
Avez vous une correction à me proposer pour
1 ) Rétablir une régularité cyclique du fonctionnent de la boucle Loop()
2) Pour activer le Dead Time entre chaque changement d’état ( High et Low)
Toute les idées seront les biens venues
voir pièce jointe
Some thoughts and précisions :
Chap. 38.6.2.2 page 978
…This channel parameter is defined in the CPRD field of the PWM_CPRDx register.
If the waveform is left aligned, then the output waveform Frequency depends on the counter source clock and can be calculated:
Mck / (CPRD * DIVA)
Chap. 38.7.37 page 1044
CALG bit = 0 : The period is left aligned
Channel 2 : Set the PWM frequency 2MHz/(2 * CPRD) = F AND 0<= CPRD<= 2exp16 -1 = 65535
Channel 2: Set the PWM duty cycle to x%= (CDTY/ CPRD) * 100 % AND 0<= CDTY <= CPRD AND 2exp16 -1 = 65535
uint32_t DTH = 500;
uint32_t DTL = 500;
As I understand PWM datasheet section, once you have set dead time in your setup() function, you can update dead time ONLY by using PWM_DTUPD while channel is enabled (idem for PWM_CPRDUPD and PWM_CDTYUPD ) :
38.6.5.3 Changing the Duty-Cycle, the Period and the Dead-Times page 997 (i.e. in void loop() or PWM_Handler())
Use PWM_CDTYUPDx, PWM_CPRDUPDx and PWM_DTUPDx to change waveform parameters while the channel is still enabled.
If the channel is an asynchronous channel (SYNCx = 0 in “PWM Sync Channels Mode register”
(PWM_SCM)), these registers hold the new period, duty-cycle and dead-times values until the end of the current PWM period and update the values for the next period.
I can not get DTUPD to work properly using either:
Uint32_t DTUPD = 100;
REG_PWM_DT2 = DTUPD << 16;
or
REG_PWM_ DTUPD2 = 100
By consulting the Datasheet in Chapter 38.7.44 on page 1052
• DTHUPD: updating the dead time value for the PWMHx output
Sets the dead time value for the PWMHx output.
This value must be set between 0 and CPRD-CDTY (PWM_CPRx and PWM_CDTYx).
This value is only applied at the beginning of the next channel period x PWM.
• DTLUPD: updating the dead time value for the PWMLx output
Sets the dead time value for the PWMLx output.
This value must be set between 0 and CDTY (PWM_CDTYx).
This value is applied only at the beginning of the next channel period x PWM
With DTHUPD and DTLUPD it works in part with
  • a cyclic irregularity
  • No Dead Time after program void P39_HIGH_and_P43_LOW () or at the beginning of void P39_LOW_and_P43_HIGH ()
I tested the code again by Arduino in stages:
Void Setup () only = OK → Pin 39 LOW and Pin 43 LOW
Void Setup () Setup
  • Void P39_LOW_and_P43_LOW () = OK → Pin 39 LOW and Pin 43 LOW
Void Setup ()
  • Void P39_HIGH_and_P43_LOW () without DeadTime
  • Void P39_LOW_and_P43_HIGH () without DeadTime
= Enchainent expected but with an irregular cyregular irregularity (like a hockey!) In Void P39_LOW_and_P43_LOW () and Void P39_HIGH_and_P43_LOW () without DeadTime
I think the Dead Time of Void P39_LOW_and_P43_LOW () works badly, it has like a hockey in general every 7, 6ms. Recall my PWM frequency is 10Khz
(See attachment, time is from left to right)
QUESTIONS
  1. Have tracks to make the Dead Time of Void P39_LOW_and_P43_LOW () more regular?
  2. Limit of regularity of Arduino Due?
  3. Do you have a similar code to suggest for study?
  4. How to operate the Dead Time of void P39_HIGH_and_P43_LOW () and void P39_LOW_and_P43_HIGH?
    I tried different values, no value creates coherent Dead Time.
  5. Does anyone have the ability to redo an observation with another oscilloscope?
Je n’arrive pas à faire fonctionner DTUPD correctement en utilisant soit :
uint32_t DTUPD =100;
ou
En consultant le Datasheet au Chap 38.7.44 à la page 1052
• DTHUPD: mise à jour de la valeur de temps mort pour la sortie PWMHx
Définit la valeur de temps mort pour la sortie PWMHx.
Cette valeur doit être définie entre 0 et CPRD-CDTY (PWM_CPRx et PWM_CDTYx).
Cette valeur n’est appliquée qu’au début de la prochaine période de canal x PWM.
• DTLUPD: mise à jour de la valeur de temps mort pour la sortie PWMLx
Définit la valeur de temps mort pour la sortie PWMLx.
Cette valeur doit être définie entre 0 et CDTY (PWM_CDTYx).
Avec DTHUPD et DTLUPD cela fonctionne en partie avec
  • une irregularité cyclique
  • Pas de Dead Time après le programme void P39_HIGH_and_P43_LOW() ou au début de void P39_LOW_and_P43_HIGH()
J’ai testé à nouveau le code par Arduino par étapes :
Void Setup () seul = OK → Pin 39 LOW et Pin 43 LOW
Void Setup () Setup
  • Void P39_LOW_and_P43_LOW () = OK → Pin 39 LOW et Pin 43 LOW
Void Setup ()
  • Void P39_HIGH_and_P43_LOW () sans DeadTime
  • Void P39_LOW_and_P43_HIGH () sans DeadTime
= Enchainent attendu mais avec une irrégularité cylique irrégulière ( comme un hocquet !) en Void P39_LOW_and_P43_LOW () et Void P39_HIGH_and_P43_LOW () sans DeadTime
Je pense que le Dead Time du Void P39_LOW_and_P43_LOW () fonctionne mal, il a comme un hocquet en général toutes les 7, 6ms. Rappel ma fréquence PWM est de 10Khz
(Voir pièce jointe, le temps se déroule de gauche à droite)
QUESTIONS
  1. Avez des pistes pour rendre le Dead Time du Void P39_LOW_and_P43_LOW () plus régulier ?
  2. Limite de régularité de l’Arduino Due ?
  3. Avez-vous un code similaire à proposer pour étude ?
  4. Comment faire fonctionner le Dead Time de void P39_HIGH_and_P43_LOW () et de void P39_LOW_and_P43_HIGH ?
    J’ai essayé différentes valeurs, aucune valeur ne crée des Dead Time cohérents.
  5. Est-ce que quelqu’un à la possibilité de refaire un constat avec un autre oscilloscope ?
Code_PWM_L_et_H_-Complet-_Sans_Dead_Time_si_Pin_39_ou_43_High.ino|attachment (10.8 KB)
Your code becomes very very difficult to decipher… :confused:
1/ Once you have set CPRD and CDTY, it gives you a frequency and a duty cycle for either PWMHx AND PWMLx (x=2 in your code).
2/ You set nowhere in your code :
PWM->PWM_CH_NUM[2].PWM_DTUPD = DTHUPD | DTLUPD << 16;
Whereas you need to set this register, once PWM channel 2 is enabled, to UPDate dead time.
See a new example below where dead time is updated every 1500 ms :
void setup () {
                  | PWM_WPCR_WPRG0
                  | PWM_WPCR_WPRG1
                  | PWM_WPCR_WPRG2
                  | PWM_WPCR_WPRG3
                  | PWM_WPCR_WPRG4
                  | PWM_WPCR_WPRG5
  /****  Try with (DTH=500, DTL=0) then (DTH=0,DTL=500) ****/
  // Alternately, you can use this format :  REG_PWM_CPRD2 = 1000;
  boolean flag = false;
  if (flag == false) {
    DTH = 500;
    DTL = 0;
    PWM->PWM_CH_NUM[2].PWM_DTUPD = DTH | DTL << 16;
    delay(1500);
    flag = true;
  if (flag == true) {
    DTH = 0;
    DTL = 500;
    delay(1500);
    flag = false;
Your code becomes very difficult to decipher …
Sorry! :-*
  • for lines canceled and posted
  • for plenty of comments
  • For the comments in French, it was my working file!
REG_PWM_DT2 = DTHUPD | DTLUPD <16;
Of
PWM-> PWM_CH_NUM [2] .PWM_DTUPD = DTHUPD | DTLUPD << 16; ?
I thought REG_PWM_DT2 = DTHUPD | DTLUPD << 16 was an identical but abbreviated way of writing and the 2 of DT2 meant channel 2!
When to use one writing or the other?
One method is faster and more reliable than the other?
Tomorrow, with head rested, I will adapt your code :
1) To set the PWM frequency to 10Khz
10Khz in 12 bits are also the frequency and the resolution of the 6 pins PWM Timer that I will use for the drive speed setpoint.
The 6 pins PWM Timer 2,3,4,5,10,11
Frequency PWM Timer of 10Khz 12 bits being obtained modifying variant.h
(I have already tried 40Khz, but at this frequency the CPU heats up and the Arduino Due is HS after several hours … A card already lost in the field of honor, CPU boiling and refusing to upload a new code. …)
2) To add the important step, pin 39 LOW and pin 43 LOW
(case of future operation as soon as the position setpoint is reached)
3) To put a shorter delay between each change of state to visualize to the oscilloscope over a width of screen the set of the 3 stages as well as the Dead Time with each change of state
What do you think of the problem of cyclical irregularity that I observed …?
Désolé !
  • pour les lignes annulées et mises en commentaires
  • pour abondance de commentaires
  • Pour les commentaires en Français, c’était mon fichier de travail !
REG_PWM_DT2 = DTHUPD | DTLUPD << 16;
de
PWM->PWM_CH_NUM[2].PWM_DTUPD = DTHUPD | DTLUPD << 16; ?
Je pensais que REG_PWM_DT2 = DTHUPD | DTLUPD << 16 était une façon identique mais écrite de façon abrégée et le 2 de DT2 signifiait le canal 2 !
Quand utiliser une écriture ou l’autre ?
Une méthode est plus rapide et fiable que l’autre ?
Demain , à tête reposée , je vais adapter votre code:
1) Pour mettre la fréquence PWM de 10Khz
10Khz en 12 bits sont également la fréquence et la résolution des 6 pins PWM Timer que j’utiliserai pour la consigne de vitesse des variateurs .
Les 6 pins PWM Timer 2,3,4,5,10,11
Fréquence PWM Timer de 10Khz 12 bits étant obtenue modifiant variant.h
(J’ai déjà essayé 40Khz, mais à cette fréquence le CPU chauffe et l’Arduino Due est HS après plusieurs d’heures … Une carte déjà perdue au champs d’honneur, CPU bouillant et refus de téléverser un nouveau code…)
**2)**Pour rajout l’étape importante, pin 39 LOW et pin 43 LOW ( cas du fonctionnement futur dès que la consigne de position est atteinte)
**3)**Mettre un delay plus court entre chaque changement d’état pour visualiser à l’oscilloscope sur une largeur d’écran l’ensemble des 3 étapes ainsi que les Dead Time à chaque changement d’état
Je verrais ensuite sur la régularité cyclique du signal test est améliorée.
Que pensez-vous du problème d’irrégularité cyclique que j’avais observée …?
Report of the day:
After changing the setup to have Pin 39 LOW and Pin 43 LOW at the end of the configuration
Changing these lines in Setup:
PWM-> PWM_CH_NUM [2] .PWM_CDTY = 500;
DTH = 500;
DTL = 500;
Modification in your Loop loop for 1st test: Duty constant at 50% (Setup)
DTH = 50
DTL = 50
Delay reduction to 15ms
Finding:
Dead Time = OK with PWM at 50% (Setup configuration)
Bizarre! : With delay (15) ms or delay (0), the observed curves are identical
Your Loop Loop does not meet my needs, need 3 different states
Pin 39 LOW and pin 43 LOW which requires a duty at 50% and DTH = 500 and
DTL = 500
Pin 39 HIGH and pin 43 LOW which requires a duty at 0% and DTH = 50 and
DTL = 50
Pin 39 LOW and pin 43 HIGH which requires duty at 100% and DTH = 50 and
DTL = 50
I had to modify your loop Loop by adding another Boolean variable STOP and modify on the fly the duty
To change the duty on the fly, I used the following syntax:
PWM-> PWM_CH_NUM [2] .PWM_CDTYUPD = 500; For Pin 39 LOW and pin 43 LOW
PWM-> PWM_CH_NUM [2] .PWM_CDTYUPD = 0; For Pin 39 HIGH and pin 43 LOW
PWM-> PWM_CH_NUM [2] .PWM_CDTYUPD = 1000; For pine 39 HIGH and pine 43 LOW
Problem encountered after using PWM-> PWM_CH_NUM [2] .PWM_CDTYUPD = x
- The cyclical variation of the state of tilting of the pines is no longer regular at all!
- Duration during which Pin 39 is LOW and pin 43 is LOW constantly changes
Constat de la journée:
Après modifier le setup pour avoir Pin 39 LOW et Pin 43 LOW à la fin de la configuration
Modification de ces lignes dans Setup:
DTH = 500;
DTL = 500;
Modification dans votre boucle Loop pour 1er test : Duty constant à 50% (Setup)
DTH = 50
DTL = 50
Réduction du delay à 15ms
Constat:
Dead Time = OK avec le PWM à 50% (configuration du Setup)
Bizarre ! : Avec delay(15)ms ou delay(0), les courbes observées sont identiques
Votre boucle Loop ne repondant pa à mes besoins, besoin de 3 états différents
Pin 39 LOW et pin 43 LOW qui nécessite un duty à 50% et DTH = 500 et
DTL = 500
Pin 39 HIGH et pin 43 LOW qui nécessite un duty à 0% et DTH = 50 et
DTL = 50
Pin 39 LOW et pin 43 HIGH qui nécessite un duty à 100% et DTH = 50 et
DTL = 50
J’ai dû modifier votre boucle Loop en rajoutant une autre variable booléenne STOP et modifier à la volée le duty
Pour modifier le duty à la volée , j’ai utilisé la syntaxe suivante :
PWM->PWM_CH_NUM[2].PWM_CDTYUPD = 500; pour Pin 39 LOW et pin 43 LOW
PWM->PWM_CH_NUM[2].PWM_CDTYUPD = 0; pour Pin 39 HIGH et pin 43 LOW
PWM->PWM_CH_NUM[2].PWM_CDTYUPD = 1000; pour pin 39 HIGH et pin 43 LOW
Problème rencontré après l’utilisation de PWM->PWM_CH_NUM[2].PWM_CDTYUPD = x
  • La variation cyclique de m’état de basculement des pins n’est plus régulier du tout !
  • Durée durant laquelle la Pin 39 est LOW et pin 43 est LOW varie en permanence
I am not entirely clear what you want but you will note that PWM controller has an output override feature : 38.6.2.5 page 982. You can override the output of PWMH and PWML.
By using buffer registers PWM_OSSUPD and PWM_OSCUPD, the output selection of PWM outputs is done synchronously to the channel counter, at the beginning of the next PWM period.
By using registers PWM_OSS and PWM_OSC, the output selection of PWM outputs is done asynchronously to the channel counter, as soon as the register is written.
While overriding PWM outputs, the channel counters continue to run, only the PWM outputs are forced to user defined values.
