Hello, i have a Problem with the source code of Sundial.
I want to use a key switch as bypass to open my gps based box. My idea was, to give 5V via a key Switch to the digital pin 0 on the arduino and by pushing the main button to start the box, the servo opens. I tried many ways but don't find any solution.
I hope you can help me. I am sure it is simple by it seems that it is not my Cup of tea^^
Here is the source code:
#include <PWMServo.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <EEPROM.h>
#include <LiquidCrystal.h>
//Hier nichts verändern!
static const int SERVO_CLOSED_ANGLE = 95; // degrees (0-180)
static const int SERVO_OPEN_ANGLE = 135; // degrees (0-180)
//Hier kannst du Deine Koordinaten und den Radius eingeben
static const float DEST_LATITUDE = 47.642154; // degrees (-90 to 90)
static const float DEST_LONGITUDE = 9.762664; // degrees (-180 to 180)
static const int RADIUS = 100; // meters
static const int LCD_CONTRAST = 50; // (0-255)
static const int DEF_ATTEMPT_MAX = 50;
static const int EEPROM_OFFSET = 100;
static const int GPS_RX_PIN = 4, GPS_TX_PIN = 3;
static const int LCD_ENABLE_PIN = 7, LCD_RS_PIN = 5, LCD_RW_PIN = 8;
static const int LCD_DB4_PIN = 14, LCD_DB5_PIN = 15, LCD_DB6_PIN = 16, LCD_DB7_PIN = 17;
static const int LCD_CONTRAST_PIN = 6;
static const int POLOLU_SWITCH_PIN = 12;
static const int SERVO_CONTROL_PIN = 9;
static const int LED_PIN = 2;
static const int PIEZO_PIN = 11;
static SoftwareSerial ss(GPS_RX_PIN, GPS_TX_PIN);
static LiquidCrystal lcd(LCD_RS_PIN, LCD_RW_PIN, LCD_ENABLE_PIN, LCD_DB4_PIN, LCD_DB5_PIN, LCD_DB6_PIN, LCD_DB7_PIN);
static TinyGPS tinyGps;
static int attemptCounter;
static PWMServo servo;
pinMode(POLOLU_SWITCH_PIN, OUTPUT);
digitalWrite(POLOLU_SWITCH_PIN, LOW);
servo.attach(SERVO_CONTROL_PIN);
ss.begin(4800);
pinMode(LCD_CONTRAST_PIN, OUTPUT);
analogWrite(LCD_CONTRAST_PIN, LCD_CONTRAST);
lcd.begin(16, 2);
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, HIGH);
servo.write(SERVO_CLOSED_ANGLE);
attemptCounter = EEPROM.read(EEPROM_OFFSET);
if (attemptCounter == 0xFF)
attemptCounter = 0;
++attemptCounter;
Msg(lcd, " Kevin & ", " Nadja's ", 1500);
Msg(lcd, " Adventure ", " Box! ", 2000);
if (attemptCounter >= DEF_ATTEMPT_MAX)
Msg(lcd, " Sorry, keine ", " weiteren ", 2000);
Msg(lcd, " Versuche ", " erlaubt! ", 2000);
Msg(lcd, " Bitte Besitzer ", " kontaktieren! ", 2000);
Msg(lcd, " Telefon: ", " 0152-52564613 ", 5000);
Msg(lcd, "kevinmeister89@ ", " googlemail.com ", 5000);
Msg(lcd, " Vielen Dank! ", "", 2000);
PowerOff();
Msg(lcd, "Das ist Versuch ", "", 2000);
lcd.clear();
lcd.setCursor(3, 0);
lcd.print(attemptCounter);
lcd.print(" von ");
lcd.print(DEF_ATTEMPT_MAX);
delay(2000);
EEPROM.write(EEPROM_OFFSET, attemptCounter);
Msg(lcd, " (((Suche))) ", " (((GPS..))) ", 0);
if (ss.available() && tinyGps.encode(ss.read()))
float lat, lon;
unsigned long fixAge;
tinyGps.f_get_position(&lat, &lon, &fixAge);
if (fixAge != TinyGPS::GPS_INVALID_AGE)
Chirp(true);
float distance_meters = TinyGPS::distance_between(lat, lon, DEST_LATITUDE, DEST_LONGITUDE);
if (distance_meters <= RADIUS)
Msg(lcd, " Zugriff ", " erlaubt! ", 2000);
EEPROM.write(EEPROM_OFFSET, 0);
servo.write(SERVO_OPEN_ANGLE);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(" Entfernung ");
lcd.setCursor(6, 1);
if (distance_meters < 5000)
lcd.print((int)distance_meters);
lcd.print("m");
lcd.print((int)(distance_meters / 1000));
lcd.print("km");
delay(4000);
Msg(lcd, " Kein ", " Zugriff! ", 2000);
PowerOff();
if (millis() >= 300000)
PowerOff2();
void PowerOff()
Chirp(false);
Msg(lcd, " Schalte aus! ", "", 2000);
lcd.clear();
digitalWrite(POLOLU_SWITCH_PIN, HIGH);
delay(300000);
delay(10000);
exit(1);
void PowerOff2()
Chirp(false);
Msg(lcd, " Kein Signal! ", "", 2000);
lcd.clear();
delay(300000);
delay(10000);
exit(1);
void Msg(LiquidCrystal &lcd, const char *top, const char *bottom, unsigned long del)
lcd.clear();
lcd.print(top);
lcd.setCursor(0, 1);
lcd.print(bottom);
delay(del);
static void Chirp(bool up)
static const int A = 1760;
static const int E = 2637;
static const int CS = 2218;
static const int duration = 100;
int tone1 = up ? A : E;
int tone2 = up ? E : A;
ss.end();
tone(PIEZO_PIN, tone1, duration);
delay(duration);
noTone(PIEZO_PIN);
tone(PIEZO_PIN, tone2, duration);
delay(duration);
noTone(PIEZO_PIN);
ss.begin(4800);
My idea was in "void setup();" add something like this:
pinMode(53, OUTPUT);
pinMode(bypass_input,INPUT);
servo.attach(servo_Pin);
servo.write(closePosition);
gpsSerial.begin (9600); // connect gps sensor
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
val = digitalRead(bypass_input);
if (val == HIGH){
PrintToLCD("Bypass enabled","(2000)");
servo.write(openPosition);
PowerOff();
Best greetings Kevin
