could define a "null" serial device and use a serial ptr (i.e. someSerial->println()). the serial-ptr can be set to the null device when no output is desired and set to a valid serial device when it it desired
this will probably help everyone understand what Im getting at. I do a lot of little projects like this and everytime i program in the buffer scrub on connect on the app side, it bothers me ![]()
again, not that it makes any difference to the end result as you can see, just feels less than artful.
im not after debug, but similar functional premise.
so the two propsals in #21 solve your functional requirement?
If not - what are you missing?
you have the best response by far that seems potentially promising, definitely more-so along the lines of what i would consider ideal - going to play with it and check loop time and storage space usage of your way vs my simplistic way.
I should have recognized you. You mounted a lawnmower carb on an old 289 and got some crazy gas mileage. You even 3D printed the intake manifold. Very impressive.
Man, I want you to do that for me on an old Mustang
