I am trying to bypass POT on PWM controller but wanted to get input before going down this route - just to make sure I am not missing anything.
The controller has two SA555 which I am guessing is to drive two separate banks of mosfets (two banks of 4). I was able to apply arduino PWM output to each of them on PIN 3 and control a smaller 24v motor.
Pin 1 has 12volt input - even though I was able to use 5v PWM from Arduino.
Below is the plan and please let me know if I am missing something and should avoid this route:
Will run PWM with opto-isolator to go PWM from 5v to 12v that will be applied to pin 3.
Since there are two SA555 chips, I could run two separate PWMs to each and sync them (or should I just use one and hook to both pins?).
3.Optocoupler supports up to 20khz. Should I just keep Arduino default 490 or 980hz?
Is there a consideration I am missing? Here is a physical overview of the controller.
P.S. I am also able to connect with DAC MCP4725 to the POT input but wanted to simplify the design by taking out DAC and ADC parts.
