Bypassing volume POT
I'm using a design based on Adafruit's WaveShield.
Can I just solder a wire between volume POT's in/out legs to bypass it (use full volume) or do I still need to add some kind of resistor? I want to eliminate pot completely in the future version.
Here's a diagram just in case.
Yes.
But you still need a 10K resistor to act as an impedance load for the filter.
Grumpy_Mike:
Yes.
Ah, thanks! I think I see. So add 10K resistor after R11 to the ground, right?
Yes.
