byte addr elements question
I'm studding one wire library to work with one wire ds18b20 sensor and looking to the examples I found this that is bugging me what this code is doing
define MAX_DS1820_SENSORS 2
byte addr[MAX_DS1820_SENSORS][8];
I can't understand what will be happen on this line Is this a multi array element?
This is a two dimensional array. The address of a one wire sensor is 8 bytes long and here 2 sensors are used, so room for 2 times 8 bytes.
ok so addr[1] will contain the address of first sensor with 8 bytes long and addr[2] will contain the address of the second sensor, is this correct?
No, the indexes start counting at 0, not 1. The first one is addr[0], the second one is addr[1].
yes my mistake i forgot 0:( Thanks for help
