I propose a new funciton byte analogReadPWM(uint8_t pin) to return the value set earlier to the PWM analog output pin. The code complies and is functioning.
in a nutshell, I ran across a need to retrieve the value I set into the PWM output pin The value was set and adjusted in several parts of my program and I needed to figure out what it got changed to.
so i came across this solution by creating an adaptation to wiring_analog.c
the testing code makes a change to the PWM pin 11 within a function randomly. then after leaving the function i retrieve the value using my new function analogReadPWM() which returns the value I set there earlier.
the results are similar to digitalRead for digital output pins but instead returns the value set to the analog output
Serial.begin(57600);
pinMode(11, OUTPUT);
analogWrite(11, 100);
delay(2000);
setPWM();
int MyPWMVal = analogReadPWM(11); // this doesn't work but it is what i need to do... HOW can I do this and is it even possible?
Serial.print("My PWM Value is:");
Serial.println(MyPWMVal);
void setPWM(){ // represents special code setting the PWM output to some value
int x = random(0,255);
Serial.print("Lets set the PWM Value to:");
Serial.println(x);
analogWrite(11, x);
// THE FOLLOWING FUNCTION IS DERIVED FROM:
wiring_analog.c - analog input and output
Part of Arduino - http://www.arduino.cc/
Copyright (c) 2005-2006 David A. Mellis
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General
Public License along with this library; if not, write to the
Free Software Foundation, Inc., 59 Temple Place, Suite 330,
Boston, MA 02111-1307 USA
Modified 28 September 2010 by Mark Sproul
$Id: wiring.c 248 2007-02-03 15:36:30Z mellis $
// Right now, PWM output only works on the pins with
// hardware support. These are defined in the appropriate
// pins_*.c file. For the rest of the pins, are default
// to digital output.
byte analogReadPWM(uint8_t pin){
byte val;
switch(digitalPinToTimer(pin)) // returns timer location if it is on a timer see NOT_ON_TIMER
// XXX fix needed for atmega8
#if defined(TCCR0) && defined(COM00) && !defined(__AVR_ATmega8__)
case TIMER0A:
val = OCR0; // get pwm duty
#endif
#if defined(TCCR0A) && defined(COM0A1)
case TIMER0A:
val = OCR0A; // get pwm duty
#endif
#if defined(TCCR0A) && defined(COM0B1)
case TIMER0B:
val = OCR0B; // get pwm duty
#endif
#if defined(TCCR1A) && defined(COM1A1)
case TIMER1A:
val = OCR1A; // get pwm duty
#endif
#if defined(TCCR1A) && defined(COM1B1)
case TIMER1B:
val = OCR1B; // get pwm duty
#endif
#if defined(TCCR2) && defined(COM21)
case TIMER2:
val = OCR2; // get pwm duty
#endif
#if defined(TCCR2A) && defined(COM2A1)
case TIMER2A:
val = OCR2A; // get pwm duty
#endif
#if defined(TCCR2A) && defined(COM2B1)
case TIMER2B:
val = OCR2B; // get pwm duty
#endif
#if defined(TCCR3A) && defined(COM3A1)
case TIMER3A:
val = OCR3A; // get pwm duty
#endif
#if defined(TCCR3A) && defined(COM3B1)
case TIMER3B:
val = OCR3B; // get pwm duty
#endif
#if defined(TCCR3A) && defined(COM3C1)
case TIMER3C:
val = OCR3C; // get pwm duty
#endif
#if defined(TCCR4A)
case TIMER4A:
val = OCR4A; // get pwm duty
#endif
#if defined(TCCR4A) && defined(COM4B1)
case TIMER4B:
val = OCR4B; // get pwm duty
#endif
#if defined(TCCR4A) && defined(COM4C1)
case TIMER4C:
val = OCR4C; // get pwm duty
#endif
#if defined(TCCR4C) && defined(COM4D1)
case TIMER4D:
val = OCR4D; // get pwm duty
#endif
#if defined(TCCR5A) && defined(COM5A1)
case TIMER5A:
val = OCR5A; // get pwm duty
#endif
#if defined(TCCR5A) && defined(COM5B1)
case TIMER5B:
val = OCR5B; // get pwm duty
#endif
#if defined(TCCR5A) && defined(COM5C1)
case TIMER5C:
val = OCR5C; // get pwm duty
#endif
case NOT_ON_TIMER:
default:
val = digitalRead(pin);
return(val);
Thank you for considering this addition.
ZHomeSlice
