Byte Array Broken?
Hello, I am building a Xmodem sender containing my eagle key using a Arduino Duemilanove. Xmodem part works well but the byte array points to some of the machinecode.
#include <avr/pgmspace.h>
const PROGMEM int filesize = 19;
const PROGMEM byte data[] = {0x50, 0x4b,/*The rest of the data*/};
int datablock = 0;
int incomingByte = 0;
  message();
//Help message
void message() {
  Serial.println(F("-Use Xmodem to recive eagle.zip"));
  Serial.println(F("-Press R to reset transfer."));
  Serial.println(F("-Press H to display this message."));
  Serial.flush();
void serialEvent() {
  incomingByte = Serial.read();
  if (incomingByte == 104 || incomingByte == 72) {
    message();
  } else if (incomingByte == 114 || incomingByte == 82) {
    datablock = 0;
    Serial.println(F("Transfer reset."));
    Serial.flush();
  } else if (incomingByte == 21) {
    sendBlock(datablock, filesize);
  } else if (incomingByte == 6) {
    datablock++;
void sendBlock(int xmodemblock, int numberofblocks) {
  if (xmodemblock == numberofblocks) {
    Serial.write(4);
    int sum = 0;
    Serial.write(1);
    Serial.write(xmodemblock + 1);
    Serial.write(255 - (xmodemblock + 1));
    Serial.flush();
    for (int i = (xmodemblock * 128); i < (xmodemblock + 1) * 128; i++) {
      Serial.write(data[i]);
      sum = 0xff & (sum + data[i]);
      Serial.flush();
    Serial.write(lowByte(sum));
    Serial.flush();
Xmodem_USB_stick.ino (16.1 KB)
hexdump of what I recived.txt (11.9 KB)
You're not reading "data" correctly.
Check the reference pages for details of how to read PROGMEM.
Also, the code can be changed a little to make it easier to read:
#define NAK 21               // Place at top of file
#define ACK 6
  incomingByte = toupper(Serial.read());
  switch (incomingByte) {
    case 'H':
      message();
    case 'R':
      datablock = 0;
      Serial.flush();
    case NAK:
    case ACK:
      datablock++;
    default:
     // Serial.print("In default: incomingByte = ");   // Error trap...??
     // Serial.println(incomingByte);
GhostWolf:
Yes, your data array has been declared to reside in program memory space (PROGMEM, therefore you CANNOT access the data as if they were in a RAM array using
data[i]
You have to use a function to retrieve the data from PROGMEM instead, like
pgm_read_byte(&data[i])
jurs:
data[i]
Thank you, it worked perfectly.
