I have been having problems using for loops and data arrays while using the TVout library to output video to a composite TV, and I'm making a top-down platformer game, and I need to draw maps for it.
The code:
#include <TVout.h>
TVout tv;
#include <fontALL.h>
byte currentMap = 0;
PROGMEM const byte wall[] = {
8,8,
0b11111111,
0b11000101,
0b10100011,
0b10010001,
0b10001001,
0b11000101,
0b10100011,
0b11111111,
PROGMEM const byte maps[1][25][28] = {
{0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},
{0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF},
tv.begin(NTSC, 240, 216);
drawMap(0);
void drawMap(int mapNumber) {
for(int x = 0; x < 28; x++) {
for(int y = 0; y < 25; y++) {
if(maps[mapNumber][y][x] != 0x00) {
tv.bitmap(x*8, y*8, wall);
tv.delay(10);
The setup I have is simple; there is a 3 dimensional array with map data (0xFF and 0x00 to represent walls and empty space for now, temporary) and 2 nested for loops to go through every single coordinate on the map. Then, I have an if statement saying if the byte is not 0x00, (because when I tried equal to 0xFF, the screen went black, which is also a problem, but whatever) it draws a "wall" (an 8x8 pixel bitmap) which is all fine. The problem is things like this start showing up on the screen (picture linked below). Clearly, this is not what I want or what I put in the maps array. I'm thinking the for loop is getting interrupted by timers or something, or the array is not readable, but nothing seems to be working. when I tell it to draw the bitmaps individually, right after another, it seems to do the right thing. Either I'm not seeing something very obvious, or what, but I've never had an issue like this before.
