Byte Array Help Needed
Can someone help me explain how to easily access bytes in a byte array?
void IncomingByte (const byte c)
  if (tailindex <= 256)
    ringbuffer[tailindex++] = c;
    Serial.println (ringbuffer[tailindex]);  //this doesn't work for accessing bytes
    tailindex = 0;
  if (tailindex == 8)
    for (int x = 0; x < 8; x++)
      Serial.println (ringbuffer[x]);    //this works fine for accessing bytes
This line seems strange to me
I think I would try
tailindex++;
ringbuffer[tailindex] = c;
Can you explain why that line "seems strange"?
Nothing wrong with that assuming that the author meant to write it that way. It sets the value of the current entry in the array then increments the index to the array.
byte anArray[] = {12, 23, 45};
  for (int x = 0; x < sizeof(anArray); x++)
    Serial.println(anArray[x]);
Can someone explain why this cant work, tailindex is and int and has a value.
Serial.println (ringbuffer[tailindex]);  //this doesn't work for accessing the byte just saved because tailindex has been incremented since then
What do you mean "can't work" ?
tailindex = 0;
ringbuffer[tailindex++] = c;               //now ringbuffer[0] has the byte read from c  byte "201"
Serial.println (ringbuffer[tailindex]);   //this just prints a 0
Serial.println (ringbuffer[0]);              //this prints  the correct byte "201"
You incremented tailindex - what did you expect?
Serial.println (ringbuffer[tailindex - 1]);    //maybe this can work?
"maybe" ?
It would have been quicker to try it than to post it.
Thanks for your help, I will try it out when I get my hands back on my hardware.
ringbuffer[tailindex] = c;                        //now ringbuffer[0] has the byte read from c  byte "201"
Serial.println (ringbuffer[tailindex]);        //Trying this too,
tailindex++;                                          //Trying this too, your awesome me not so much
Serial.println(ringbuffer[tailindex++] = c);
Or the rather obvious:
Serial.println (c);
You know whats in the buffer, you just put it there, just print the value you put in.
ring buffers of size 256 are particularly easy to fill/empty IFF the index is uint8_t.
if index is NOT uint8_t , or the buffer is NOT size 256, you have do more work; it might be a LOT more, percentagewise, but it's still 'not very much'.
I'm curious why you are passing something that is not a string to a function that expects a string, but still expecting the function to operate properly.
How can you expect to make ringbuffer into a string?
Why the hell aren't you using camelCase for your names?
SamIAm93:
I think I would try
tailindex++;
and what happens when tailindex = the last element of the array? I don't understand "trying" some code. When you put code in a sketch, you put it there because you know what t is going to do.
Or, you think you know what it is going to do. I'm surprised every day when my code doesn't do what I expect. Then, I fix it.
