Is there a way to read a byte array using a Stream? Is there any subclass of Stream that do this?
Thanks.
Thanks.
Stream contains the method:
size_t readBytes( char *buffer, size_t length); // read chars from stream into buffer
// terminates if length characters have been read or timeout (see setTimeout)
// returns the number of characters placed in the buffer (0 means no valid data found)
MarkT:
Stream contains the method:size_t readBytes( char *buffer, size_t length); // read chars from stream into buffer
I want de the inverse. Like:
byte buffer[128];
MemoryStream stream(buffer);
byte b = stream.read();
That's not what your post title or initial post says.
The Stream class derives from the print class which has both print() and write() methods that can take arrays. So, yes, a Stream class can write arrays.
I think what the PO wanted is a stream-like interface around a chunk of memory. For example, if we were to write a string to an array, we do
char buffer[100];
strcpy(buffer, "Hello world!");
If we wrap a stream interface around the array, it may look like the following.
MemoryStream stm(buffer);
stm.write("Hello world!");
It may seem redundant here, but it may be useful when some function takes a stream pointer as an argument, and in some cases we want that function to operate on a memory buffer.
I'd be interested to know if such a wrapper exists. If not, I think we can implement one using a simple queue structure on that array.
