byte array to String
how can I convert a byte array to Sting?
Either I am to stupid to search nobody required it so far. Most likely the first option :slight_smile:
Thanks
Robert
But you definitely don't want to use the String class. Search the forum for it and you'll find enough reasons not to use it.
String myString = String(myByteArray);
I don't believe I've ever heard of a Sting class. Are you raising bees? Or scorpions?
PaulS:
Neither - he's an FBI agent looking to entrap a rival CIA agent :wink:
majenko:
String() - Arduino Reference
thanks for the answer. That's what I tried first. It works fine with a char array but not with an array of bytes.
Maybe my mistake is somewhere else.
Here my examples:
fails with "call of overloaded 'String(byte [5])' is ambiguous" :
void setup(void){}
void loop(void)
byte byteArray[5];
strcpy((char *)byteArray,"0123");
String myString = String(byteArray);
compiles fine:
void setup(void){}
void loop(void)
char byteArray[5];
Thanks
Robert
Ah, byte is a typedef for "unsigned char" - there is no unsigned char prototype for the String constructor.
Cast it to (char *) and it should be fine.
void setup(void)
void loop(void)
  byte byteArray[5];
  String myString = String((char *)byteArray);
majenko:
Perfect!
Thanks for the great help.
Robert
robvoi:
Thanks
Robert
hi all,
this worked for me
String myString = String((char*)myByteArray);
this worked for me
That calls two constructors, the equal operator, and the destructor.
String myString = (char*)myByteArray;
Does the same thing with only one call to the constructor.
Hi, im not making an answer, but i have a problem, i dont't really know what to do.
im trying to use this:
but doesn't work and returns me this:
no matching function for call to 'String(void (&)(byte*, byte))'
i'm trying to do it with Byte Buffer, because i need to convert to String theme i would send to dataBase.
i would appreciate so much if someone helps me
