Thank you all for the support. I am sorry if i make you angry with my very poor programming skills, i'm mostly good at the hardware stuff.
So, first of all, here is the code with indents (i didn't even know arduino had auto-format, thank you, the code looked hard to read to me too).
// Project 16
#include <TimerOne.h>
//Pin connected to Pin 12 of 74HC595 (Latch)
int latchPin = 8;
//Pin connected to Pin 11 of 74HC595 (Clock)
int clockPin = 12;
//Pin connected to Pin 14 of 74HC595 (Data)
int dataPin = 11;
uint8_t led[8];
long counter1 = 0;
long counter2 = 0;
//set pins to output
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
led[0] = B11111111;
led[1] = B10000001;
led[2] = B10111101;
led[3] = B10100101;
led[4] = B10100101;
led[5] = B10111101;
led[6] = B10000001;
led[7] = B11111111;
Timer1.initialize(10000);
Timer1.attachInterrupt(screenUpdate);
counter1++;
if (counter1 >=100000) {
counter2++;
if (counter2 >= 10000) {
counter1 = 0;
counter2 = 0;
for (int i=0; i<8; i++) {
led[i]= ~led[i];
void screenUpdate() {
uint8_t row = B00000001;
for (byte k = 0; k < 9; k++) {
// Open up the latch ready to receive data
digitalWrite(latchPin, LOW);
shiftIt(~row );
shiftIt(led[k] ); // LED array
// Close the latch, sending the data in the registers out to the matrix
digitalWrite(latchPin, HIGH);
row = row << 1;
void shiftIt(byte dataOut) {
// Shift out 8 bits LSB first,
// on rising edge of clock
boolean pinState;
//clear shift register read for sending data
digitalWrite(dataPin, LOW);
// for each bit in dataOut send out a bit
//set clockPin to LOW prior to sending bit
digitalWrite(clockPin, LOW);
// if the value of DataOut and (logical AND) a bitmask
// are true, set pinState to 1 (HIGH)
if ( dataOut & (1<<i) ) {
pinState = HIGH;
else {
pinState = LOW;
//sets dataPin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState);
//send bit out on rising edge of clock
digitalWrite(clockPin, HIGH);
//stop shifting
I have found another sketch with a similar table and I ask if this would work.
pattern.h
#define FRAMECNT 3
Frame Frames[FRAMECNT] = {
{B10000000, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000, B00001000},
{B01000000, B11000000, B00000000, B00000000, B00000000, B00000000, B00011000, B00010000},
{B11100000, B10100000, B00000000, B00000000, B00000000, B11111000, B00101000, B00111000}
first part of main code
typedef byte Frame[8];
uint8_t *led;
int curFrameIdx;
#include pattern.h
setframe function
void setFrame(int idx) {
led = Frames[idx];
and the loop
if (++curFrameIdx == FRAMECNT) {
curFrameIdx = 0;
// select frame for display
setFrame(curFrameIdx);
delay(400); // i won t use delay in the final program
Here is the full code of the other project :
* Show animations on a DIMxDIM led matrix
* Uses Timer1 library to
* constantly run an interrupt routine
* at a specified frequency. This
* refreshes the display without the
* main loop having to do anything.
//#define TESTMODE // continuously sequence thru the LED's
#define DIM 5 // x/y dimension - 5x5 matrix
#define DIM1 (DIM-1)
typedef byte Frame[DIM];
#include "frames.h"
byte row = 0;
byte *curFrame;
int curFrameIdx;
// col[xx] of leds - anodes
// these are the arduino pins assigned to each column
int cols[DIM] = {12,11,10,9,8};
// row[xx] of leds - cathodes
// these are the arduino pins assigned to each row
int rows[DIM] = {7,6,5,4,3};
Frame blankFrame =
{B00000,
B00000,
B00000,
B00000,
B00000};
// blank the screen
void clearLeds() {
// blank screen
curFrame = blankFrame;
// select a frame to display
// idx = 0 -> FRAMDECNT-1
curFrame = Frames[idx];
// Interrupt routine
// each time display() is called, it turns off the previous row
// and turns on the next row
byte bitMask = B00000011;
void display() {
digitalWrite(rows[row], HIGH); // Turn whole previous row off
if (bitMask == B00010000) {
bitMask = B00000011; // light the right 2 columns (pins 9,8)
// increment row and wrap if necessary
if (++row == DIM) {
row = 0;
else if (bitMask == B00000011) {
bitMask = B00001100; // light the middle 2 columns (pins 11,10)
else { // bitMaskIdx == B00001100
bitMask = B00010000; // light the leftmost column (pin 12)
// direct port manipulation.
// PORTB is a pseudo variable for digital pins 8 to 13 The two high bits (6 & 7) map to the crystal pins and are not usable
// the bottom 5 bits are our columns. We don't want to change the other bits,
// so we first mask the bits we ignore, and then set the bits we want to light
PORTB &= B11100000;
PORTB |= curFrame[row] & bitMask;
digitalWrite(rows[row], LOW); // Turn whole row on at once (for equal lighting times)
int i;
// sets the pins as output
for (i = 0; i < DIM; i++) {
pinMode(cols[i], OUTPUT);
pinMode(rows[i], OUTPUT);
// set up cols and rows (set display to dark)
digitalWrite(cols[i], LOW);
digitalWrite(rows[i], HIGH);
clearLeds();
#ifdef TESTMODE
while (1) {
for (i=0;i < DIM;i++) {
digitalWrite(rows[i],LOW);
for (int j=0;j < DIM;j++) {
digitalWrite(cols[j],HIGH);
delay(250);
digitalWrite(cols[j],LOW);
digitalWrite(rows[i],HIGH);
#else // !TESTMODE
// interrupt interval in uSec
// this determines how long to keep each row turned on
// so if we have 5 rows, we redraw the whole screen
// once every 5 rows * 3 cycles per row * 1000 usec = .015 sec -> 66.67Hz
// if you perceive flickering you can decrease to 500 for a 133.33Hz rate
Timer1.initialize(1000);
Timer1.attachInterrupt(display); // ISR
curFrameIdx = -1;
#endif // TESTMODE
// increment the frame index and wrap if necessary
curFrameIdx = 0;
delay(400); // wait time between frames in ms
The other question, besides "will it work" is why in the second program (the last one) the cuPrameIdx doesn't have a default value, and how come it is set to 0 in the loop, and not 1, because in the pattern.h FRAMECNT can't be 0.
PS Just to make sure, i want to combine the first sketch with the 3 parts i posted after, the last code is only there so show you where i copied those parts.
