I am using the 433 MHz receiver and transmitter with an arduino mega 2560 and UNO. Below is my code on the receivers end:
int incomingByte = 0;
int led = 13;
pinMode(led, OUTPUT);
if (Serial.available() > 0) {
digitaWrite(led, HIGH);
incomingByte = Serial.read();
Serial.print(char(incomingByte));
if (String(incomingByte)) == "00:00:00:00:00:00") {
Serial.println("The data received does match");
}else{
Serial.println("The data received does not match");
Now, every time I run this code, ' incomingByte' always stores just one byte ( one character)and therefore I always get the ' does not match ' error. I want to concatenate the bytes and store them in either a variable char or else a variable string. Can some body please help me here .
How could a single byte ever equal that string?
You need to read the incoming data into a string and then compare that, or compare one character at a time as they come in.
Heren is a function I wrote that basically does this
boolean waitPattern(char *receiveBuffer, int receiveBufferLen, char *thePattern,Stream *inStream)
char *patternPos = thePattern;
receiveBufferLen--;// Allow space for zero termination
while(*patternPos!=0 && receiveBufferLen>0)
if (inStream->available() && receiveBufferLen-->0)
*receiveBuffer=inStream->read();
if (*receiveBuffer++==*patternPos)
patternPos++;
patternPos = thePattern;// reset the pattern position pointer back to the start of the pattern
if (*patternPos==0)
*receiveBuffer=0;// terminate receive buffer
return true; // found the pattern
return false;// did not find before we ran out of input buffer
You pass a buffer, ie char array, a pattern ie a c string, and a pointer to stream ie &Serial
If you only want to pattern match, just modify the code to read into a single character rather than the pointer to the buffer.
Actually I have a version that works without a buffer, but is on a computer that I don't have access to until tomorrow, but some other clever person can change the code for you
