Hi guys.
Yesterday, I complied this program and it run well. Now, I'm rebuilting it and some errors occurt.
Can you tell me how to fix that?
I cannot understand why same code but not same result.
Many thanks.
char inData[24];
byte index;
boolean started = false;
boolean ended = false;
Serial.println("Temperature & Humidity");
while(Serial.available() > 0)
char aChar = Serial.read();
if(aChar == '<')
started = true;
index = 0;
inData[index] = '\0';
else if(aChar == '>')
ended = true;
else if(started)
inData[index] = aChar;
index++;
inData[index] = ',';
if(started && ended)
// Use the value
if(inData[0] == 'T')
inData[0] = ' ';
int windVal = atoi(inData);
Serial.println(" ");
Serial.print("Temp:");
Serial.print(inData);
Serial.print("C");
else if(inData[0] == 'H')
inData[0] = ' ';
int temp = atoi(inData);
Serial.print("Humidity:");
Serial.print("%");
started = false;
ended = false;
index = 0;
