Byte not recognised after updating to Ver 2.0.0 rc-8
I had a problem compiling my program after updating to the latest cli version, which was byte not recognised.
Prior to the update it worked ok with no compile errors.
History was I was having problems with a hdd, which I swapped out and created a new project folder on the latest drive, and copied all the files into the new project folder.
I checked the paths were ok and set up the same, however when I came to compile I got the above error.
I have no idea where the build file is for this, so would presume, it may have something to do with the build file, however all I did do was add #include <Arduino.h> in the ino file and the sketch compiled error free.
Version: 2.0.0-rc8
Date: 2022-06-23T09:36:07.533Z
CLI Version: 0.24.0 [c1b10f56]
Copyright © 2022 Arduino SA
Your topic has been moved to the dedicated IDE2.0 section of the forum.
Thanks
Hi @latedev. Thanks for your report.
What do you mean by this? Did you change the version of Arduino CLI that is bundled with Arduino IDE 2.0.0-rc8?
Please provide the full and exact text of the error message.
Which board do you have selected in the Arduino IDE?
Does the error occur if you compile this sketch?:
byte x = 42;
void setup() {}
void loop() {}
This code should be placed in the .ino file of a new sketch, not added to an existing project.
I found the problem when going through answering your questions.
Thanks.
The problem was I had entered #include "Arduino.h" which I presume would have over-ridden the #include <Arduino.h> thus negating any and all defined names, within that file.
