Hi Sifus,
I receive some text via mqtt (PubSubClient.h) which represents a RGB code in (pseudo) HEX format (#FFFFFF = white, #FF0000 = Red, ... you know already).
Issue is I need this pseudo hex info in decimal and split in red,green and blue parts. (#FF0000 => 255,0,0)
I feel I already read the internet twice how to do that. I suspect it's too simple to even write about it? However byte shifting, atoi stoL serial.print(r,HEX) and so on is now entirely confusing me.
I did a bit debugging with Serial.print but I assume it makes it worse since (assumingly) it converts the bytes already into something readable?
void callback(char* topic, byte* payload, unsigned int length) {
String command((char*)topic);
String parameter;
for (int i = 0; i < length; i++)
parameter += (char)payload[i];
if (command.endsWith("/color")){
Serial.println("Adjust color: ");
Serial.print(command);
Serial.print(" - ");
Serial.println(parameter);
byte r=(payload>>16);
byte g=(payload>>8);
byte b=(payload);
Serial.print("R: " + r + " G: " + g + " B: " + b);
else if (command.endsWith("/status")){
Serial.println("received status: ");
above is one of many attempts. The conversion to String is probably highly unprofessional but the only way I can realize the if clauses. That works well (while it may not be most efficient) but the first block for "/color" does not do the job.
Right now I get invalid operands of types 'byte* {aka unsigned char*}' and 'int' to binary 'operator>>' but this is just one of many different error messages I explored.
Can i not get way with all that scrap and simply use the bytes out of payload to show a pair as DEC format?
Please point me in a good direction. This costs me way too many grey hair already while google always brings me back to those solutions which don't work (for me).
