Byte to Char
I'm sending a byte on a C# side (over a serial port) over to the arduino. I want the arduino to read that byte and then put that value into a char variable. My question is, if the value is greater than 127/128 will it be positive and if it's less than that, will it be negative in the new char?
Example:
If I read a byte (value = 255) and I put that value into a character, will it be 127 and if I have another byte (value = 0) will that value become -128? Thank you very much for the help.
Mattix: I want the arduino to read that byte and then put that value into a char variable.
if ( Serial.available() )
  char ch;
  ch = Serial.read();
Got it.
My question is, if the value is greater than 127 /128 will it be positive
No. An unsigned eight bit value greater than 127 is interpreted as a negative signed value.
and if it's less than that {128}, will it be negative in the new char?
No. An unsigned eight bit value less than or equal to 127 is interpreted as a positive signed value.
No. An unsigned eight bit value of 255 when converted to a signed value is interpreted as a -1.
No. Zero is zero.
Maybe this will help...
Uns Hex Sig
0 0x00 0 1 0x01 +1 2 0x02 +2 ... ... ... 126 0x7E +126 127 0x7F +127 128 0x80 -128 129 0x81 -127 130 0x82 -126 ... ... ... 254 0xFE -2 255 0xFF -1
Ok thank you very much. I think I can use the map function to solve my problem. Have a good day!
Also, I understood hex, just kind of confused what would happen going from signed to unsigned. You cleared that up.
Mattix:
You are welcome.
If you describe the problem I suspect someone here can offer a simpler solution.
Have a good day!
You too!
It's nothing too bad. I don't think I'll have further difficulties, but if I do, I'll post here in a few minutes.
