#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <IPAddress.h>
#include <Wire.h> //For oled
//---------------FONT + GRAPHIC-----------------------------//
#include "data.h"
// OLED I2C bus address
#define OLED_address 0x3c
const char* ssid = "sieze";
const char* password = "ushallno";
char* topic = "#"; // using wildcard to monitor all traffic from mqtt server
char* server = "192.168.0.7"; // Address of my server on my network, substitute yours!
char message_buff[100]; // initialise storage buffer (i haven't tested to this capacity.)
WiFiClient wifiClient;
PubSubClient client(server, 1883, callback, wifiClient);
String macToStr(const uint8_t* mac)
String result;
for (int i = 0; i < 6; ++i) {
result += String(mac[i], 16);
if (i < 5)
result += ':';
return result;
delay(10);
// Set SDA & SCL for ESP8266 to:
#ifdef ARDUINO_ESP8266_ESP01
Wire.pins(0, 2); //0=SDA, 2=SCL, 2 also =LED
#endif
// Initialize I2C and OLED Display
Wire.begin();
init_OLED();
reset_display(); // Clear logo and load saved mode
for (int i = 0; i < 128 * 8; i++) // show 128* 64 Logo
SendChar(pgm_read_byte(logo + i));
delay(8000);
displayOn();
clear_display();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
WiFi.config(IPAddress(192, 168, 0, 58), IPAddress(192, 168, 0, 1), IPAddress(255, 255, 255, 0));
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
sendStrXY("IP OK", 0, 0);
// connection to broker script.
if (client.connect("arduinoClient")) {
client.publish("outTopic", "hello world");
client.subscribe("esprelaytest"); // i should probably just point this to the variable above.
client.subscribe("MyMQTT/25/2/V_TEMP"); // Jared room
client.subscribe("MyMQTT/25/4/V_LIGHT");
client.subscribe("MyMQTT/25/5/V_LIGHT");
Serial.println("Broker connected");
sendStrXY("Broker OK", 1, 0);
//delay(1000);
//clear_display();
else {
sendStrXY("Broker bad", 1, 0);
Serial.println("MQTT connect failed");
Serial.println("Will reset and try again...");
delay(2000);
abort();
client.loop();
void callback(char* topic, byte* payload, unsigned int length) {
int i = 0;
Serial.println("Message arrived: topic: " + String(topic));
Serial.println("Length: " + String(length, DEC));
// create character buffer with ending null terminator (string)
for (i = 0; i < length; i++) {
message_buff[i] = payload[i];
message_buff[i] = '\0';
String msgString = String(message_buff);
Serial.println("Payload: " + msgString);
if (String(topic) == "MyMQTT/25/4/V_LIGHT" && msgString == "1") { // if there is a "1" published to any topic (#) on the broker then:
sendStrXY("Relay 1 ON", 0, 0);
else if (String(topic) == "MyMQTT/25/4/V_LIGHT" && msgString == "0") {
sendStrXY("Relay 1 OFF", 0, 0);
else if (String(topic) == "MyMQTT/25/5/V_LIGHT" && msgString == "1") {
sendStrXY("Relay 2 ON", 1, 0);
else if (String(topic) == "MyMQTT/25/5/V_LIGHT" && msgString == "0") {
sendStrXY("Relay 2 OFF", 1, 0);
else if (String(topic) == "MyMQTT/25/2/V_TEMP") {
//Serial.println(msgString);
sendCharXY(payload, 2, 0);
// Turns display on.
void displayOn(void)
sendcommand(0xaf); //display on
// Prints a display char (not just a byte) in coordinates X Y,
// being multiples of 8. This means we have 16 COLS (0-15)
// and 8 ROWS (0-7).
static void sendCharXY(unsigned char data, int X, int Y)
setXY(X, Y);
Wire.beginTransmission(OLED_address); // begin transmitting
Wire.write(0x40);//data mode
for (int i = 0; i < 8; i++) //8
Wire.write(pgm_read_byte(myFont[data - 0x20] + i));
Wire.endTransmission(); // stop transmitting
// Set the cursor position in a 16 COL * 8 ROW map.
static void setXY(unsigned char row, unsigned char col)
sendcommand(0xb0 + row); //set page address
sendcommand(0x00 + (8 * col & 0x0f)); //set low col address //8
sendcommand(0x10 + ((8 * col >> 4) & 0x0f)); //set high col address //8
// Turns display off.
void displayOff(void)
sendcommand(0xae); //display off
// Clears the display by sendind 0 to all the screen map.
static void clear_display(void)
unsigned char i, k;
for (k = 0; k < 8; k++) //8
setXY(k, 0);
for (i = 0; i < 128; i++) //was 128
SendChar(0); //clear all COL
// Actually this sends a byte, not a char to draw in the display.
// Display's chars uses 8 byte font the small ones and 96 bytes
// for the big number font.
static void SendChar(unsigned char data)
Wire.write(data);
// Resets display depending on the actual mode.
static void reset_display(void)
displayOff();
clear_display();
displayOn();
// Prints a string in coordinates X Y, being multiples of 8.
// This means we have 16 COLS (0-15) and 8 ROWS (0-7).
static void sendStrXY( char *string, int X, int Y)
setXY(X, Y);
unsigned char i = 0;
while (*string)
for (i = 0; i < 8; i++)
SendChar(pgm_read_byte(myFont[*string - 0x20] + i));
*string++;
// Used to send commands to the display.
static void sendcommand(unsigned char com)
Wire.beginTransmission(OLED_address); //begin transmitting
Wire.write(0x80); //command mode
Wire.write(com);
// Inits oled and draws logo at startup
static void init_OLED(void)
sendcommand(0xa6); //Set Normal Display (default)
// Adafruit Init sequence for 128x64 OLED module
sendcommand(0xAE); //DISPLAYOFF
sendcommand(0xD5); //SETDISPLAYCLOCKDIV
sendcommand(0x80); // the suggested ratio 0x80
sendcommand(0xA8); //SSD1306_SETMULTIPLEX
sendcommand(0x2F); //--1/48 duty //NEW!!!
sendcommand(0xD3); //SETDISPLAYOFFSET
sendcommand(0x0); //no offset
sendcommand(0x40 | 0x0); //SETSTARTLINE
sendcommand(0x8D); //CHARGEPUMP
sendcommand(0x14);
sendcommand(0x20); //MEMORYMODE
sendcommand(0x00); //0x0 act like ks0108
sendcommand(0xA0 | 0x1); //SEGREMAP //Rotate screen 180 deg
//sendcommand(0xA0);
sendcommand(0xC8); //COMSCANDEC Rotate screen 180 Deg
//sendcommand(0xC0);
sendcommand(0xDA); //0xDA
sendcommand(0x12); //COMSCANDEC
sendcommand(0x81); //SETCONTRAS
sendcommand(0xCF); //
sendcommand(0xd9); //SETPRECHARGE
sendcommand(0xF1);
sendcommand(0xDB); //SETVCOMDETECT
sendcommand(0x40);
sendcommand(0xA4); //DISPLAYALLON_RESUME
sendcommand(0xA6); //NORMALDISPLAY
clear_display();
sendcommand(0x2e); // stop scroll
sendcommand(0x20); //Set Memory Addressing Mode
sendcommand(0x00); //Set Memory Addressing Mode ab Horizontal addressing mode
setXY(0, 0);
for(int i=0;i<128*8;i++) // show 128* 64 Logo
SendChar(pgm_read_byte(logo+i));
