Byte variable
goodmorning everybody,
how can I assign the value read by a sensor that is 3 bytes long three variablili Byte different ?
then I have to add two of these variables and then convert them to integer values
ITALIANO
buon giorno a tutti!!,
come faccio ad assegnare il valore letto da un sensore che è lungo 3 Byte a tre variablili Byte differenti?
successivamente devo sommare due di queste variabili per poi convertirle in valori interi
thank you very much
unsigned long val = (((unsigned long)a) << 16) | (((unsigned long)b) << 16) | c;
where a, b, c are your byte values.
AWOL:
I suppose you mean:
unsigned long val = (((unsigned long)a) << 16) | (((unsigned long)b) << 8) | c;
if I read the value with this function:
#define Dat 5
#define Clk 6
shiftIn(Dat, Clk, MSBFIRST);
how can i do this??.. sorry but i’m a beginner with arduino…
it return a data stream: 00000010101100110101000100000000
4 byte
1°temp 2°temp humi CRC
I have to share this information and add the first to the second and then i subtract 400.
finally i have the temperature, the humidity and the CRC…
please help me
thankyou very much
because i read this value from a sensor (7719 termoigrosens).
see your other thread. (end this one)
I reply you in the other thread
