C# 2 Servo Motor Control
Hi everyone,
I am a beginner with Arduino and code.
I am Turkish, sorry for my english.
I’m making servo control (for robot arm) with c# for now. However, there are code that runs the Arduino and C # code. How can I set up 2 Servo Motors?
Arduino Code:
#include <Servo.h>
Servo servoMotor;
int servoPin=13;
int value=0;
int angle;
int x;
void setup(){
  servoMotor.attach(servoPin);
void loop(){
  if(Serial.available() >0)
    value = Serial.read();
    if(value>0){
      x=value;
  else if (x>0 && x<181){
    angle=x+20;
    servoMotor.write(angle);
C# Kodu:
private void trackBar1_body_Scroll(object sender, EventArgs e)
            if (serialPort1.IsOpen == true)
                int PWM_deger = trackBar1_body.Value;
                label1.Text = trackBar1_body.Value.ToString();
                b = BitConverter.GetBytes(PWM_deger);
                serialPort1.Write(b, 0, 4);
            else MessageBox.Show("Connect to Device first !!");
I’m waiting for your help.
You just need to create 2 object for 2 motor.
example:servo servo1;
servo servo2;
AshwiniGunjal:
servo servo2;
Thank you for your information. However, I want to manage 4 servomotors with C #. How can i make it.
#include<servo.h>
servo servo1;
servo servo2;
void setup(){
serial.begin(9600);
servo1.attach(pin no);
servo2.attach(pin no);
void loop(){
servo1.write(angle);
servo2.write(angle);
I don’t know in c# but I know in arduino language.
AshwiniGunjal:
#include<servo.h>
servo servo1;
servo servo2;
void setup(){
serial.begin(9600);
void loop(){
I don't know in c# but I know in arduino language.
Thank you for your answer. But how can I check this pin number from C# ?
The C# app should know NOTHING about the hardware on the Arduino side.
You simply send 4 values that represent the positions for the servos, in some order, and the Arduino applies the values to the servos in the proper order.
PaulS:
Thank you very much for your information.
I have no idea how to do it. Could you help ?
Sure, I know how to do "it". I've been married 34 years.
I'm sure that you meant something else, though. At least, I hope you did.
So, what is "it" that you need help with? Once your C# app has opened the serial port, port.Write(someString) is not exactly rocket science.
With a properly formulated string, and Robin2's tutorial on reading serial data, getting the Arduino to read the string, and parse it into 4 position values is trivial.
Using Servo::write() to send the appropriate position value to the appropriate servo is simple.
PaulS:
http://forum.arduino.cc/index.php?topic=396450.0
Thank you very much.
However, I did not get a complete result because of my work.
Can you help me please?
Sure. Send me your computer.
Or POST YOUR CODE!
PaulS:
Or POST YOUR CODE!
Really, but very thank you
I communicated to you via a private message. I expect you to answer.
You have unrealistic expectations.
PaulS:
I do not understand anything you said sorry.
PaulS:
Would you please help me
No. I've tried. I've asked you to post your code. You've refused.
PaulS:
I sent the code from the private message.
I can send it from here
http://s3.dosya.tc/server11/5c5kkd/Arduino.rar.html
And expected me to immediately fix it. THAT was unreasonable, as I mentioned.
Post your code HERE. Do not send me any more PMs with demands that I solve your problems immediately.
PaulS:
I understand you. This is the code.
ARDUINO CODE:
#include <Servo.h>
Servo servoMotor;
int servoPin=13;
int value=0;
int angle;
int x;
void setup(){
void loop(){
if(value>0){
x=value;
angle=x+20;
C# CODE:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO.Ports;
namespace WindowsFormsApplication2
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
for (int i = 0; i < System.IO.Ports.SerialPort.GetPortNames().Length; i++)
comboBox1.Items.Add(System.IO.Ports.SerialPort.GetPortNames());
  • trackBar1_middleservo.Visible = false;*
  • trackBar2_leftServo.Visible = false;*
  • trackBar3_rightServo.Visible = false;*
  • trackBar4_HandServo.Visible = false;*
  • private void button1_Click(object sender, EventArgs e)*
  • try*
  • serialPort1.PortName = comboBox1.Text;*
  • if (!serialPort1.IsOpen) serialPort1.Open();*
  • catch*
  • MesrighteBox.Show(“PPort Connected…!”);*
  • trackBar1_middleservo.Visible = true;*
  • trackBar2_leftServo.Visible = true;*
  • trackBar3_rightServo.Visible = true;*
  • trackBar4_HandServo.Visible = true;*
  • private void trackBar1_middleservo_Scroll(object sender, EventArgs e)*
  • if (serialPort1.IsOpen == true)*
  • int PWM_value = trackBar1_middleservo.Value;*
  • label1.Text = trackBar1_middleservo.Value.ToString();*
  • byte b = BitConverter.GetBytes(PWM_value);*
  • serialPort1.Write(b, 0, 4);*
  • else MesrighteBox.Show(“Connect to Device first !!”);*
  • private void trackBar2_leftServo_Scroll(object sender, EventArgs e)*
  • private void trackBar3_rightServo_Scroll(object sender, EventArgs e)*
  • private void trackBar4_HandServo_Scroll(object sender, EventArgs e)*
You still have not posted your code correctly. The <> icon makes it stupidly simple to do so.
Your Arduino code has an if/else if set of statements where the two conditions bear no relationship to each other. If there is serial data to read, do something. Else, if the value in x is between 1 and 180, do something else.
I see no relationship between the if and the else if. So, it is difficult to believe that the else if statement is appropriate.
I am certain that your C# code is not half in italics. But, since what we see is, we have to guess what it was supposed to look like. I don’t care for guessing games AT ALL.
As you move the slider, the Value property of the trackBar1_middleservo object changes. You get that value as an int, and then convert the int to an array of bytes, and send the 4 bytes in the array to the serial port.
On the Arduino end, then, you expect that each of the 4 bytes will be a position for the servo to move to. That is NOT a realistic expectation AT ALL.
Store the value of the Value property in a variable whose type is byte. Shitcan the code to convert the byte to an array of bytes. Send the ONE byte to the serial port.
PaulS:
This is all the code available.
Thank you for the information. However, I still do not know how to do it. Please help
