C# and arduino
Greeatings.
I need some help about c# and arduino.
Is someone make some aplication for download code from c# to arduino .
For example in c# I can change some parametars for arduino exc. font on display , number of something
Have somone some idea for that how can do that or have any link ?
Thank you
You want a C# application to replace the IDE? Why?
What font on what display?
It IS possible to re-write the IDE in C# instead of Java. After all, C# is Microsoft's name for Java. But, why?
t0r30rs:
If you mean that you want to be able to use a C# program to call the command-line Arduino IDE to compile and upload a program then this Python uploader program may provide a blueprint.
If you just want to send serial data from a C# program to an Arduino program have a look at Serial Input Basics
If neither is what you want to do then please explain more clearly.
...R
PaulS:
Say what???? How on earth do you come up with this kind of garbage?? There is NO relation between c# and Java, other than they are derived from a c heritage. But that's as far as it goes. They are otherwise VERY different languages. You might as well claim the French language is "France's name for Spanish"!
Regards,
Ray L.
Robin2:
...R
I explane you what i need.
on my aplication i need to change font on my tft,
evry time i must write diferente code for this.
Now i have idea when i have aplication for that i select font which i will use and
that do change my orginal code.
and i download that on my mcu
I don't have any experience with TFT displays so I have no idea how the data for a font is stored or if it is possible to store the data for 2 or 3 different fonts and select different ones while a program is running.
And when you say "change font" do you mean that you want to make all the text appear differently or only a few characters?
One thought is to store the font data on an SD Card and have a function within the Arduino program that can accept data from a PC program for a new font and save it as a new file on the SD Card.
...R
