c#,c++,Perl, What is arduino's language?
Is there a book that shows how to program well and efficiently the arduino language like a c++ book?
Im learning c++, but what language is the arduino using? I cannot find any place that teaches how to learn the language in dept.
Please tell mehow the language works
Thank you
Im learning c++
That's good, because that IS the language that the Arduinos are programmed in.
Then why isn’t working when I try the simplest c++ program?
#include
using namespace std;
int main()
int x;
cout<<“Please enter value”;
cin>>x;
return 0;
It doesn't have a file system. There is no stdin and stdout.
Also the STL is not included. You can however download that (not that this gives you cout at such). However there is a streaming library. That lets you stream to the serial port.
Then why isn't working when I try the simplest c++ program?
Have you LOOKED at your Arduino? Where do you expect the data that cout outputs to appear? The Arduino doesn't have a display device?
Where do you expect the data that cin is looking for to come from? Did your Arduino come with a keyboard attached?
#include
int main()
The Arduino environment defines main() for you already, so you can’t redefine it. It’s in hardware \ arduino \ cores \ arduino \ main.cpp and it looks like this:
#include <Arduino.h>
int main(void)
	init();
#if defined(USBCON)
	USB.attach();
#endif
	setup();
	for (;;) {
		loop();
		if (serialEventRun) serialEventRun();
	return 0;
