Hello.
I have been struggling to solve this out by myself but it has been more than 10 days and nothing is going well. I made a jsp webpage on which a databean value is displayed in tag.
I put ‘888’ as default, and I made it change to ‘1’ or ‘0’ if I click on on/off buttons, respectively.
I checked if the databean value is changed to ‘1’/‘0’ and it DID change(Printed onto eclipse console window).
But the Arduino console window still doesn’t show 1/0. It always shows the default value 888.
In my opinion it is because the Arduino sketch is not refreshing the value.
But I don’t know what to use and how to implement whatever to the coding.
If anybody knows any good function/whatsoever,
Please reply me.
- main.jsp file
<!-- main.jsp
Main page that shows a simple on/off control and DHT11 sensor value -->
<%@ page language="java" contentType="text/html; charset=utf-8"
pageEncoding="utf-8"%>
<%@ page import="com.Test.domain.Relay" %>
Relay relay = new Relay();
pageContext.setAttribute("relay", relay);
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title>Simple sensor value reading app</title>
<link href="http://code.jquery.com/mobile/1.0/jquery.mobile-1.0.min.css" rel="stylesheet" type="text/css"/>
<script src="http://code.jquery.com/jquery-1.6.4.min.js" type="text/javascript"></script>
<script src="http://code.jquery.com/mobile/1.0/jquery.mobile-1.0.min.js" type="text/javascript"></script>
<script>
$(document).ready(function(){
var timer = setInterval(function(){
$.get("http://192.168.0.32", function(data){
$("#result").text(data);
}, 2000);
$("#autoRefresh").click(function(){
alert("interval stopped.");
clearInterval(timer);
$("#relayOn").click(function(){
$("#relayState").val("1");
$("#form1").attr("action","Processing.jsp");
$("#form1").submit();
$("#relayOff").click(function(){
$("#relayState").val("0");
</script>
</head>
<body>
<div data-role="page" id="page">
<div data-role="header">
<h1>DHT11 Sensor temperature</h1>
</div>
<div data-role="content">
<p><span id="result">Current Temperature : Reading data...</span>
<form method="GET" id="form1" action="" target="haha">
<input type="button" id="relayOn" name="relayOn" value="RelayOn">
<input type="button" id="relayOff" name="relayOff" value="RelayOff">
<input type="text" id="relayState" name="relayState" value="998">
</form>
<span id="relayPower">${relay.relayPower}</span>
</div>
<div data-role="footer">
<h4>Footer</h4>
</div>
</div>
<iframe name="haha">
</iframe>
</body>
</html>
2. Processing.jsp file
Processing.jsp
A processing file to receive parameters and proceed those files.
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
request.setCharacterEncoding("utf-8");
String temp = request.getParameter("relayState");
System.out.println("temp: "+temp);
int relayState = Integer.parseInt(temp);
relay.relayPower = relayState;
System.out.println("relay.relayPower: "+relay.relayPower);
request.setAttribute("haval", relay.relayPower);
<body>
<span id="relayDAT">${relay.relayPower}</span>
</body>
3. Arduino sketch file
// Arduino sketch (c++)
#include <dht11.h>
#include <SPI.h>
#include <Ethernet.h>
/* Set MAC address of ethernet shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
/* Set IP address of ethernet shield,
in case DHCP IP allocation is failed.
IPAddress ip(192, 168, 0, 32);
// Client object that will connect to tomcat server
// running in eclipse.
EthernetClient arduinoClient;
// Tomcat project server address
byte server[] = { 192, 168, 0, 55 };
// Client object that will connect to arduino web server from tomcat project server.
EthernetClient tomcatClient;
// Create arduino web server object
EthernetServer arduinoServer(80);
// DHT11 sensor value input
int sensorpin = A0;
// Set relay on/off socket as 2
int relay = 2;
// Create DHT11 sensor object
dht11 dht11;
// Define a variable to save relay on/off state
int relayOnOff;
// If DHCP IP allocation fails
if(Ethernet.begin(mac) == 0) {
Serial.println("DHCP IP allocation failed .....");
Serial.println("Allocating the set IP...");
Ethernet.begin(mac, ip);
// Begin arduino web server
arduinoServer.begin();
// Wait for a moment while ethernet is being initialized..
Serial.print("Set IP : ");
Serial.println(Ethernet.localIP());
Serial.println("Connecting to the tomcat server...");
// When a request from arduino web server is received,
// get the EthernetClient object that sent the request.
// Here I proceed messages sent to the server, using EthernetClient object.
tomcatClient = arduinoServer.available();
// When a client's request is received to arduino web server,
if(tomcatClient) {
// Set a variable to save if HTTP request is over/not over - HTTP request ends with blank line.
boolean current_line_is_blank = true;
// When the web server is connected with the client,
// analyze the client's request and respond to the client in a loop statement.
while(tomcatClient.connected()) {
// When the client's message is received,
if(tomcatClient.available()) {
//Read the first character and delete it from the receiving buffer.
char c = tomcatClient.read();
Serial.print(c);
// If the character is a line-feed, and the line is blank,
// it means HTTP request is over. So write the response data.
if(c == '\n' && current_line_is_blank) {
// Write a standard HTTP response header.
tomcatClient.println("HTTP/1.1 200 OK");
// CORS(Cross-Origin Resource Sharing)을 활용한 크로스도메인 Ajax
// Cross-domain Ajax, using CORS(Cross-Origin Resource Sharing)
tomcatClient.println("Access-Control-Allow-Origin:*");
// Set MIME type of HTTP response data.
tomcatClient.println("Content-Type: text/html; charset=utf-8");
tomcatClient.println();
tomcatClient.print("Current Temperature: ");
tomcatClient.print(temperature());
tomcatClient.println("℃");
if(c == '\n') {
} else if(c != '\r') {
current_line_is_blank = false;
delay(10);
// Stop tomcat client
tomcatClient.stop();
// Now arduino becomes a client and tomcat is a server.
// Arduino requests tomcat.
// connect() functiion:
// Host name is converted to IP address, through DNS server.
// If a client can be connected to a server well, it returns 1.
// 1: connection complete.
// 0: connection failed.
int state = arduinoClient.connect(server, 8080);
Serial.println("state : " + String(state));
// When connected to tomcat project server,
if(state) {
Serial.println("Tomcat project server connection complete.");
// Requst for the relay on/off state information, to tomcat project server.
arduinoClient.println("GET /Test/main.jsp HTTP/1.1");
arduinoClient.println("User-Agent: Arduino 1.6.11");
arduinoClient.println("Host: 192.168.0.55:8080");
// The last line of a web request ends with blank line.
arduinoClient.println();
Serial.println("Tomcat project server connection failed.");
// When a client requests to a tomcat project server,
if(arduinoClient.connected()){
if(arduinoClient.find("<span id=\"relayPower\">")){ //ask for ${relay.relayPower} in <span> tag
relayOnOff = arduinoClient.parseInt();
Serial.println("111111111111111111111111111111");
Serial.println(relayOnOff);
if(relayOnOff == 1){
digitalWrite(relay, HIGH);
digitalWrite(relay, LOW);
// Stop the arduino client
arduinoClient.stop();
delay(3000);
// A function that returns temperature value, after reading
// DHT11 sensor value.
float temperature() {
// Read sensor value.
dht11.read(sensorpin);
int dhtInput = dht11.temperature;
// Print the temperature value on the console window.
Serial.print("Dht11 value measured: ");
Serial.println(dhtInput);
// Return the calculated celcius value.
return dhtInput;
**Data bean file is attached. It is Relay.java file.
relay.txt (360 Bytes)
