C code translation
http://wiki.gnokii.org/index.php/Protocol_description
I'm trying to translate the C code found on the website listed above into code for the arduino. If anyone could help point me in the right direction as far as where to start I would appreciate it. I plan to isolate only the code essential for sending and receiving SMS messeges.
Here is the code
       some questions or comments send to <zecarlos1957@hotmail.com>
       my thanks to web,   i am  learning width them
       my bad ingles!!!!!!!!!!!!????????????
       thanks to Justin Karneges who was the ward whork
       I am Jose Jesus from Portugal
#include <stdlib.h>
#include <conio.h>
#include <stdio.h>
#include <mem.h>
#include <dos.h>
#include <time.h>
#include <string.h>
#include "rs232.h"   //or some else serial driver
#define N61MAXSIZE 120
#define BUF_SIZ       1024
typedef unsigned char uchar;
typedef unsigned short ushort;
uchar input_buffer[1024],output_buffer[1024];
unsigned char transtable[]={
       '@' ,0xa3,'§' ,0xa5,0xe8,0xe9,0xf9,0xec,
       0xf2,0xc7,'\n',0xd8,0xf8,'\r',0xc5,0xe5,
       '?' ,'_' ,'?' ,'?' ,'?' ,'?' ,'?' ,'?' ,
       '?' ,'?' ,'?' ,'?' ,0xc6,0xe6,0xdf,0xc9,
       ' ' ,'!' ,'\"','#' ,0xa4,'%' ,'&' ,'\'',
       '0' ,'1' ,'2' ,'3' ,'4' ,'5' ,'6' ,'7' ,
       '8' ,'9' ,':' ,';' ,'<' ,'=' ,'>' ,'?' ,
       0xa1,'A' ,'B' ,'C' ,'D' ,'E' ,'F' ,'G' ,
       'H' ,'I' ,'J' ,'K' ,'L' ,'M' ,'N' ,'O' ,
       'P' ,'Q' ,'R' ,'S' ,'T' ,'U' ,'V' ,'W' ,
       'X' ,'Y' ,'Z' ,0xc4,0xd6,0xd1,0xdc,0xa7,
       0xbf,'a' ,'b' ,'c' ,'d' ,'e' ,'f' ,'g' ,
       'h' ,'i' ,'j' ,'k' ,'l' ,'m' ,'n' ,'o' ,
       'p' ,'q' ,'r' ,'s' ,'t' ,'u' ,'v' ,'w' ,
       'x' ,'y' ,'z' ,0xe4,0xf6,0xf1,0xfc,0xe0
struct Message{
       uchar id;
       uchar dest;
       uchar source;
       uchar type;
       uchar unknown;
       uchar size;
       uchar dat[256];
       uchar cs[2];
}message;
int firsttime=1;
class TM{
protected:
        int seqnum,prevseq,ack,inbox,done,nsms;
        uchar memtype;
        uchar version[80];
        uchar smsc[80];
        int sendframe(int,int,uchar*);
        int nextseq();
//        void sinc();
        void smssendfull(char *smsc,char *dest,char *msg);
        void sendack(int type,int seqnum);
        void bcd(char *dst,char *s);
        void bcd2(char *dst,char *s);
//        char *unbcd(unsigned char *dat);
//        char *unbcd2(unsigned char *dat);
        void pack7(char *dst,char *s);
        char *unpack7(unsigned char *dat,int len);
        unsigned char gettrans(unsigned char c);
        int process(Message*);
public:
        void addchar(char *str,char c){
              int n=strlen(str); str[n]=c; str[n+1]=0;
        int sendmsg(int type,int len,uchar*buf);
        TM();
        ~TM();
        void sinc();
        int ackwait(int x);
        int wait(int x);
        int send(uchar *,uchar*);
        int update();
        int gettxt(uchar*);
        void show(Message*);
        void ver();
        int getmail(){return inbox;}
        void savemsg(char *sender,char *d,char *t,char *m);
int off=0,mode=0,datp=0,multiple=0,readsize=0;
char Paulo[]={"918617088"};
uchar msg[512];
uchar msg2[512];
uchar Date[10];
uchar Time[10];
char sender[15];
uchar s1[50];
uchar Imei[50];
uchar Operator[50];
uchar SmsC[15];
int NetStatus=0;
int Battery=0;
uchar index=0;
uchar memtype=0x02;
  this is a part of a frame.this frame is complet wen sending
   to the function TM::sendmsg(getver[0],getver[1],&getver[2])
uchar getver[] =   {0xd1,0x05,0x00,0x01,0x00,0x03,0x00};
uchar getsmsc[]=   {0x02,0x06,0x00,0x01,0x00,0x33,0x64,0x01};
uchar getimei[]=   {0x1b,0x04,0x00,0x01,0x00,0x01};
uchar getbatt[]=   {0x17,0x04,0x00,0x01,0x00,0x02};
uchar getrf[]  =   {0x0a,0x04,0x00,0x01,0x00,0x81};
uchar getnetwork[]={0x0a,0x04,0x00,0x01,0x00,0x70};
uchar readsms[]=   {0x14,0x0a,0x00,0x01,0x01,0x07,memtype,0x00,index,0x01,0x65,0x01};
uchar getalarm[]=  {0x11,0x04,0x00,0x01,0x00,0x6d};
uchar delsms[]  =  {0x14,0x08,0x00,0x01,0x00,0x0a,memtype,0x00,index,0x00};
uchar smsstatus[]= {0x14,0x05,0x00,0x01,0x00,0x36,0x64};
class App:public TM{
        int status,todo,old;
        char port;
        uchar *doit;
        uchar *tarefa[255];
public:
      App():status(0),port('1'),todo(0),old(0){}
      int init(){
        if( rs_initport(port,RS_B115K,RS_NOPAR,RS_DBIT8,RS_SBIT1,
            BUF_SIZ,input_buffer,BUF_SIZ,output_buffer)>0){
              status=0;
              rs_modctrl(RS_WRTMCR,RS_MCRDTR,RS_LINON);
              cprintf("Terminal mode active \r\n");
        else{
             status=1;
             cprintf("Unable to open COM port\r\n");
               return status;
        tarefa[6]=::getver;
        tarefa[5]=::getsmsc;
        tarefa[4]=::getimei;
        tarefa[3]=::getbatt;
        tarefa[2]=::getrf;
        tarefa[1]=::getnetwork;
        tarefa[0]=::smsstatus;
        todo=7;
        return status;
     ~App(){
        if(status==0)rs_modctrl(RS_WRTMCR,RS_MCRDTR,RS_LINOFF);
        rs_close();
      int upload(){
        int r;
        if(todo!=old && todo){
            doit=tarefa[todo-1];
            sendmsg(doit[0],doit[1],&doit[2]);
            old=todo;r=0;
        }else{
           if(old>0){
                   printf("Comando [%s] ",itoa((int)doit[0],s1,16));
            printf("Nao Executado. Repetir?  esc:space\r\n");
            old=0;
            r=27;
      return r;
     int getstatus(){
      if(done && todo==old && todo ){
        todo--;old=0;done=0;
        return ((message.type<<8)|message.dat[3]);
        return 0;
     void insertcmd(uchar * cmd){
      if(todo<255){tarefa[todo++]=cmd;}
      else printf("Error to mutch tarefas\r\n");
     int getarefa(){return todo;}
     void sendsms(uchar *dst,uchar *m){
      if(smsc==0 || dst==0){
        printf("Falta o numero do Centro de mensagens\r\n");
        return;
      smssendfull(smsc,dst,m);
     void savemsg(uchar *s,uchar *d,uchar *t,uchar *mess){
      FILE *f=fopen("backup.dat","at");
      if(!f)return;
      strcat(s,d);
      strcat(s,t);
      strcat(s,mess);
      fwrite(s,strlen(s),1,f);
      fclose(f);
void main(){
  int end=0,c=0,er=0,type,mail=0;
  App app;
  long t1=0,t2,t3=8000;
  char *dst;
  if(app.init()==0){
        t1=clock();
        while(!end){
        t2=clock();
        if(t2>t1){
            t1=t2+t3;
            if(app.getarefa()==0){
                    app.insertcmd(smsstatus);
            //    see if there is sms to send ? send it
                  if(app.loadnet());
            c=app.upload();
        if(kbhit())c=getch();
        if(c){
            if(c==27){
             while(!kbhit());
             if((c=getch())==27)break;
             c=0;
      if(c==0x52){
             if(app.gettxt(msg)){
              dst=Paulo;
              app.sendsms(dst,msg);
  delay(1);
  if((er=app.update())){
      if(er&0x01)printf("Receive overrun(buffer) ");
      if(er&0x02)printf("Receive overrun(UART) ");
      if(er&0x04)printf("Parity error ");
      if(er&0x08)printf("Framing error ");
      if(er&0x10)printf("Break detected ");
      if(er&0x20)printf("Error in receive FIFO ");
      printf(" Esc-ABort : Else-Continue \r\n");
      c=27;
  if((type=app.getstatus())){
         if(type==0x1437){
  //if status report a sms message
            if(index==0)index=message.dat[15];
            mail=index;
            if(mail ){
                  printf("%sª Messagem nova ",itoa(mail,s1,10));
                  readsms[8]=mail;t1=0;
                  app.insertcmd(readsms);     // read it
        if(type==0x1408){
           //if there is a sms mark as read
            mail=message.dat[7];
            if(mail){
                  printf("%s %s\r\n",sender,::msg);
//                  app.show(&message);
                  printf("\r\n");
                  if(index)index--;
//                  app.insertcmd(delsms);      // delete it
//                  app.savemsg(sender,Date,Time,msg);
        if(app.getarefa()>1)t1=0;
TM::TM():seqnum(0),prevseq(0),ack(0),memtype(0x02),inbox(0),done(0),nsms(0){
  smsc[0]=0;version[0]=0;Imei[0]=0;Operator[0]=0;SmsC[0]=0;
TM::~TM(){}
int TM::send(uchar *num,uchar *msg){
        if(smsc[0]==0)return 0x300;
        printf("Waiting...");
        smssendfull(smsc,num,msg);
        return 0;
int  TM::sendmsg(int type,int size,unsigned char *data){
        unsigned char buf[N61MAXSIZE+2];
        unsigned char num,lastsize;
        int n,len,er;
        num=(size+N61MAXSIZE-1)/N61MAXSIZE;
        lastsize=size%N61MAXSIZE;
        sinc();
        for(n=0;n<num;++n){
              if(n+1==num) len=lastsize;
              else len=N61MAXSIZE;
              memcpy(buf,data+(n*N61MAXSIZE),len);
              buf[len++]=num-n;            //  multiple framed msg
              buf[len++]=nextseq();      //  sequenci
              if(n) buf[len-1]&=7;
              ack=0;
              if((er=sendframe(type,len,buf)))break;
        return er;
int TM::sendframe(int type,int size,uchar *data){
        unsigned char buf[256];
        int at,n,check,len;
        unsigned short *p;
        at=0;
        buf[at++]=0x1e;         //   id comunication 0x1e cable=0x1e infred=0x1c
        buf[at++]=0x00;         //   dest  0x00=mobil
        buf[at++]=0x0c;         //   source  0x0c=pc
        buf[at++]=type;         //   comand type  see below
        buf[at++]=0;            //   multiple sms
        buf[at++]=size;         //   size of data
        for(n=0;n<size;n++) buf[at++]=data[n];
        if(size%2)buf[at++]=0;
        check=0;
        p=(unsigned short *)buf;
        len=at/2;
        for(n=0;n<len;n++) check ^=p[n];
        p[n]=check;
        at+=2;
        int er;
        er=rs_sndstr(at,buf);
//        printf(" send   ");        show((Message*)buf);
        if(er>0)er|=0x500;
        return er;
Remainder of code
int TM::update(){
  int n,er=0;
  uchar c;
  while(rs_inrcvd()){
       c=rs_getbyt();
       if(er=rs_error())break;
       message.cs[(off&1)]^=c;
       switch (mode){
            case 0:
              if(c==0x1e){
                     if(!multiple){
                        memset(message.dat,0,255);}
                        message.id=message.cs[0]=0x1e;message.cs[1]=0;
                  mode=1;off=0;
            case 1:
                   if((message.dest=c)==0x0c)mode=2; else mode=0;
            case 2: message.source=c;mode=3;break;
            case 3: message.type=c;mode=4;break;
            case 4: message.unknown=c;mode=5;break;
            case 5:
              if(multiple) { message.size+=c-2; }
              else {message.size=c;datp=0;}
              mode=6;n=message.size%2;
              readsize=message.size+n+2;break;
            case 6:
              n=datp++;
              if(n>255){
                     multiple=0;mode=0;
                   printf("Data to long \r\n");break;
              message.dat[n]=c;
              if(n>=readsize-1){
             if(message.cs[0]==message.cs[1] && message.cs[0]==0){
             if(message.type!=0x7f ){
      sendack(message.type,message.dat[message.size-1]&0x0f);
      if(message.size>1 && message.dat[message.size-2]!=0x01){
              datp-=4;
              ++multiple;
      }else multiple=0;
  if(!multiple || message.type==0x7f){
                  printf("Accept ");show(&message);
             multiple=0;
             process(&message);
 }else{ multiple=0;printf("CheckSum Error\r\n");show(&message);}
 mode=0;
default:break;
 off++;
 return er;
void TM::smssendfull(char *smsc,char *dest,char *msg){
        int n;
        //short Message Service Frame header
        buf[0]=0x00;  //  \
        buf[1]=0x01;  //   >  SMS Frame header
        buf[2]=0x00;  //  /
        buf[3]=0x01;  //  \
        buf[4]=0x02;  //   >  Send SMS Message
        buf[5]=0x00;  //  /
        memset(buf+6,0,12);
        bcd(buf+6,smsc);    //Short Message Service Center 12 bytes
        buf[18]=0x11;    // Message type
        buf[19]=0x00;    // SMS reference
        buf[20]=0x00;    // Protocol ID
        buf[21]=0xf1;    // Data coding scheme
        buf[22]=strlen(msg); //message size
        memset(buf+23,0,12);
        bcd2(buf+23,dest);    /// 12 bytes
        buf[35]=0xa7;      // valid period code
        buf[36]=0x00;
        buf[37]=0x00;
        buf[38]=0x00;
        buf[39]=0x00;  //
        buf[40]=0x00;  //
        buf[41]=0x00;  //
        pack7(buf+42,msg);   //  44 bytes
        sendmsg(0x02,42+strlen(msg),buf);
void TM::sendack(int type,int seqnum){
        char buf[2];
        buf[0]=type;
        buf[1]=seqnum;            //  sequenci
        sendframe(0x7f,2,buf);
int TM::ackwait(int x){
       int n;
       for(n=0;n<x;n++){
             delay(1);
             update();
             if(ack)return 1;
       return 0;
int  TM::nextseq(){
              int n,n1;
              n=seqnum;
              prevseq=n;
              ++seqnum;
              seqnum&=7;
              if(::firsttime){::firsttime=0;n1=0x60;}else n1=0x40;
              return (n+n1);
void TM::bcd(char *dst,char *s){
                   int size,x,y,n,hi,lo;
                   if(s[0]=='+'){ dst[1]=0x91;++s;}
                   else dst[1]=0xa1;//unknown 0x81;
                   x=0;y=2;
                   while(s[x]){
                          lo=s[x++]-'0';
                          if(s[x])hi=s[x++]-'0';
                          else hi=0x0f;
                          n=(hi<<4)+lo;
                          dst[y++]=n;
                   dst[0]=y-1;
void TM::bcd2(char *dst,char *s){
                   else dst[1]=0x81;
                   x=0;y=2;
                   while(s[x]){
                          lo=s[x++]-'0';
                          else hi=0x0f;
                          n=(hi<<4)+lo;
                          dst[y++]=n;
                   dst[0]=strlen(s);
char *TM::unbcd(unsigned char *dat){
              static char buf[32];
              int len,n,x;
              buf[0]=0;
              len=dat[0];
              if(dat[1]==0x91) addchar(buf,'+');
              for(n=0;n<len-1;n++){
                    x=dat[n+2]&0x0f;
                    if(x<10)      addchar(buf,'0'+x);
                    x=(dat[n+2]>>4)&0x0f;
                    if(x<10)      addchar(buf+1,'0'+x);
              return buf;
char *TM::unbcd2(unsigned char *dat){
              int len,n,x,at=2;
              buf[0]=0;
              len=dat[0];
              for(n=0;n<len;n++){
                    x=dat[at]&0x0f;
                    ++n;
                    if(!(n<len))break;
                    x=(dat[at]>>4)&0x0f;
                    ++at;
              return buf;
}void TM::pack7(char *dst,char *s){
                   int len,at,shift,n,x;
                   unsigned char c;
                   unsigned short *p;
                   unsigned short w;
                   len=strlen(s);
                   x=(len*8)/7;
                   for(n=0;n<len;n++)dst[n]=0;
                   shift=at=w=0;
                   for(n=0;n<len;n++){
                          p=(unsigned short*)(dst+at);
                          w=gettrans(s[n])&0x7f;
                          w<<=shift;
                          *p|=w;
                          shift+=7;
                          if(shift>=8){shift&=0x07;++at;      }
char * TM::unpack7(unsigned char *dat,int len){
              static char buf[256];
              unsigned short *p;
              unsigned short w;
              unsigned char c;
              int n,shift,at;
              shift=at=buf[0]=0;
              for(n=0;n<len;n++){
                    p=(unsigned short *)(dat+at);
                    w=*p;
                    w>>=shift;
                    c=w&0x7f;
                    shift+=7;
                    if(shift &8){  shift&=0x07;  ++at; }
                    addchar(buf,transtable[c]);
              buf[n]=0;
              return buf;
unsigned char TM::gettrans(unsigned char c){
       unsigned char n;
       if(c=='?')return 0x3f;
       for(n=0;n<128;n++)
             if(transtable[n]==c)
                    return n;
       return 0x3f;
void TM::show(Message *head){
       int i=0;
       printf("%s ",itoa((int)head->id,s1,16));
       printf("%s ",itoa((int)head->dest,s1,16));
       printf("%s ",itoa((int)head->source,s1,16));
       printf("%s ",itoa((int)head->type,s1,16));
       printf("%s ",itoa((int)head->unknown,s1,16));
       printf("%s ",itoa((int)head->size,s1,16));
       for(int n=0;n<head->size+2;n++)
             printf("%s ",itoa(head->dat[n],s1,16));
       printf("\r\n");
int TM::process(Message *msg){
        int n,stype;
        switch(msg->type){
                  case 0x02:
                          if(msg->dat[3]==0x02){printf("Mensagem Entrege\r\n");done=1;}
                          if(msg->dat[3]==0x03){printf("BAD\r\n");done=1;}
                          if(msg->dat[3]==0x10){
                                    printf("%s %s\r\n",unbcd(msg->dat+23),unpack7(msg->dat+42,msg->dat[22]));
  //                                    if(mess->dat[5])delsms(mess->dat[5]);
                                    done=1;
                          if(msg->dat[3]==0x34) {  // recev sms center
                                    strcpy(smsc,unbcd(msg->dat+21));
                                    printf("SMS Center: %s \r\n",smsc);
                                    done=1;
                  case 0x0a:
                          if(msg->dat[3]==0x71){           // Get Network Operator
                                    for(n=0;n<msg->dat[16];n++)
                                          addchar(Operator,msg->dat[n+17]);
                                    printf("NetWork     %s\r\n",Operator);
                                    done=1;
                          if(msg->dat[3]==0x82){           // Get Network Status RF
                                    NetStatus=msg->dat[4];
                                    done=1;
                                    printf("RF signal   %s Percent\r\n",itoa((int)NetStatus,s1,10));
                  case 0x14:
                          if(msg->dat[3]==0x08){           //ler mensagem
                                          int at=0,x;
                                          for(n=2;n>=0;n--){
                                                 x=(msg->dat[37+n]&0x0f);
                                                 if(x<10)Date[at++]=x+'0';
                                                 x=(msg->dat[37+n]>>4);
                                                 Date[at++]='-';
                                          Date[at-1]=0;at=0;
                                          for(n=0;n<3;n++){
                                                 Time[at++]='0'+(msg->dat[40+n]&0x0f);
                                                 Time[at++]='0'+(msg->dat[40+n]>>4);
                                                 Time[at++]=':';
                                          Time[at-1]=0;
/*                                          if(msg->dat[42]==0x34){
                                                 printf("_ %s_ \r\n",unbcd(&msg->dat[44]));
  */                                           strcpy(::msg,unpack7(msg->dat+44,msg->dat[24]));
                                           strcpy(sender,unbcd2(msg->dat+25));
                                           if(nsms){
  //                                           printf("%s ",itoa((int)msg->dat[49],s1,16));
 //                                           printf("%s \r\n",itoa((int)msg->dat[48],s1,16));
                                                if(msg->dat[49]==(nsms>>8))strcpy(msg2,::msg+7);
                                                else {strcat(::msg,msg2);strcpy(msg2,::msg+7);}
                                                if(msg->dat[49]==1){strcpy(::msg,msg2);nsms=0;}
                                          done=1;
                          else if(msg->dat[3]==0x09){done=1;}  // nao ha mensagens novas
                          else if(msg->dat[3]==0x0b){done=1;printf("Mensagem Apagada\r\n");}
                          else if(msg->dat[3]==0x37){done=1;}  //memsagen  nova recebida
                  case 0x17:
                          if(msg->dat[3]=0x03){      // Battery charge
                                    Battery=msg->dat[5];
                                    printf("Battery     %s Percent\r\n",itoa((int)Battery,s1,10));
                                    done=1;
                  case 0x1b:                      // Imei
                                    n=4;
                                    while(msg->dat[n])addchar(Imei,msg->dat[n++]);
                                    printf("Imei:       %s\r\n",Imei);
                                    done=1;
                  case 0x1f:
                          done=1;
                  case 0xd0:
                  case 0xd2:
                          version[0]=0;              //recev software & hardware versin
                          for(n=4;n<35;n++)
                                     addchar(version,msg->dat[n]);
                          printf("Version: %s\r\n",version);
                          done=1;
                  case 0x40:
                          if(msg->dat[2]==0xca){     //ProducteCode
                                done=1;
                  case 0x7f:                      // acknoledg previos command
                          if((msg->dat[1]&7)==prevseq) ack=1;
                  default:break;
void TM::savemsg(char *sender,char *d,char *t,char *m){
      printf("Sender: %s ",sender);
      printf("date: %s ",d);
      printf("time: %s ",t);
      printf(": %s ",m);
int TM::gettxt(uchar *msg){
        int off=0;uchar c=0;
        printf("Enter text\r\n");
        while(1){
                   if (kbhit()){
                         c=getch();
                         if(c==13 || c==27)break;
                         msg[off++]=c;
                         msg[off]=0;
                         printf(&msg[off-1]);
                         c=0;
        printf("\r\n");
        if(c==27)        return 0;
        else return 1;
void TM::sinc(){
      for(int n=0;n<128;n++) //55
        rs_sndbyt(0x55);
      delay(5);
uchar msg[512];
uchar msg2[512];
uchar Date[10];
uchar Time[10];
char sender[15];
uchar s1[50];
uchar Imei[50];
uchar Operator[50];
Don't try this on a 168-based board!
[edit]Read a bit more:
Woah! or even a 328 ;D
I wouldn't even bother translating - go through it, work out what bits you really need (and tidy up the awful coding style) and rewrite.[/edit]
