Hi all
i have been searching for a while now to understand the syntax of ? : because sometimes i see poeple use this. but i dont understand what it does?
can some one explain this?
/Spirit
Hi all
/Spirit
? : <if false, take this value>
thanks!
Its called a ternary operator - the only one in C. You can easily google it.
yes i did but i think i googled the wrong words. i realy could not find it!
and i realy did not know what to search for.
only i dont know if it is better or worse or equal then if(){}else{}
If you understand it, it's as good. If you don't, it isn't. The compiler will generate the same code.
You can find an overview here: Operators in C and C++.
