C coding in arduino
i have a simple question. in C programming i used to write this,
printf("value : %d", value);
if value = 13. so it will print, "value : 13"
so, my question, how to write similar coding, but this time for char instead of decimal. thanks in advance.
char myBuffer[32] = ""
sprintf(myBuffer, ""value : %d", value);
Serial.println(myBuffer);
make sure not to overflow myBuffer (or use snprintf())
Since 13 is a non-printing character, and is a carriage return, I'm not sure how the Serial object would handle it. However, the following program does show that the monitor does properly handle displaying a simple char:
  char c;
  c = 10;               // A line feed, which should be visible
  Serial.print("this should be followed by two blank lines:");
  Serial.print(c);
  Serial.print(c);
  Serial.print("Now a new line.");
econjack:
the format specifier kind-of suggests that value is a signed integer...
thanks guys. that helps me.
i use String instead of char, so it becomes
String word = "Aigoo";
Serial.print("The word is " + word);
the ouput is:
"The word is Aigoo"
btw, thanks guys :slight_smile:
rafiuddin:
the ouput is:
"The word is Aigoo"
so that's a lot different than a char!
BTW, the format specifier for a char is c (e.g. %c)
I'll leave it to you to look up the format specifier for your string
