The following code is giving me an error that I don't understand. Can't I make an object a private variable of another object without using inheritance? Is it just because there is a non-trivial constructor? (I'm pretty sure I've seen objects with String
member variables, haven't I?)
class singleNeo {
private:
Adafruit_NeoPixel pixs(1, NEOPIN, NEO_GRB + NEO_KHZ800);
uint_fast8_t pin;
public:
singleNeo(uint_fast8_t pinNo): pin(pinNo) {}
void RGB(uint_fast8_t redv, uint_fast8_t greenv, uint_fast8_t bluev) {
pixs->setPixelColor(0, pixs->Color(redv, greenv, bluev));
pixs->show();
void setup() {}
void loop() {}
"D:\\arduino-1.8.13\\portable\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -Werror=return-type -Wno-expansion-to-defined -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-D__SKETCH_NAME__=\"\"\"singleneo_simple.ino\"\"\"" -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_QTPY_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ADAFRUIT -D__SAMD21E18A__ -DCRYSTALLESS -DADAFRUIT_QTPY_M0 -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x80CB -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"QT Py M0\"" "-ID:\\arduino-1.8.13\\portable\\packages\\adafruit\\hardware\\samd\\1.7.13/libraries/Adafruit_TinyUSB_Arduino/src/arduino" -Os -D__SAMD21E18A__ -DCRYSTALLESS -DADAFRUIT_QTPY_M0 -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x80CB -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"QT Py M0\"" "-ID:\\arduino-1.8.13\\portable\\packages\\adafruit\\hardware\\samd\\1.7.13/libraries/Adafruit_TinyUSB_Arduino/src/arduino" "-ID:\\arduino-1.8.13\\portable\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-ID:\\arduino-1.8.13\\portable\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-ID:\\arduino-1.8.13\\portable\\packages\\adafruit\\tools\\CMSIS-Atmel\\1.2.2/CMSIS/Device/ATMEL/" "-ID:\\arduino-1.8.13\\portable\\packages\\adafruit\\hardware\\samd\\1.7.13\\cores\\arduino" "-ID:\\arduino-1.8.13\\portable\\packages\\adafruit\\hardware\\samd\\1.7.13\\variants\\qtpy_m0" "-ID:\\arduino-1.8.13\\portable\\sketchbook\\libraries\\Adafruit_NeoPixel" "d:\\tmp\\Arduino1.8.13Build\\sketch\\singleneo_simple.ino.cpp" -o "d:\\tmp\\Arduino1.8.13Build\\sketch\\singleneo_simple.ino.cpp.o"
singleneo_simple:5:28: error: expected identifier before numeric constant
5 | Adafruit_NeoPixel pixs(1, NEOPIN, NEO_GRB + NEO_KHZ800);
singleneo_simple:5:28: error: expected ',' or '...' before numeric constant
(and a bunch more errors since pixs didn't get defined)
