c++ openGLCD library
hi, im quite new to c++ when i try to run my code it gives me
the error: expected primary-expression before ';' token
in line 24.
can someone tell me what i did wrong?
code:
void glcd_Device::GotoXY(uint8_t x, uint8_t y)
uint8_t chip, cmd;
if((x == this->Coord.x) && (y == this->Coord.y))
return;
if( (x > DISPLAY_WIDTH-1) || (y > DISPLAY_HEIGHT-1) ) // exit if coordinates are not legal
return;
this->Coord.x = x; // save new coordinates
this->Coord.y = y;
chip = glcdDev_XYval2Chip(x, y);
#ifdef LCD_SET_XYADD
this->Coord.chip[chip].page = glcdDev_Yval2ChipPage(y);
cmd = (LCD_SET_XYADD | glcdDev_XYval2XYaddr(x,y));
this->WriteCommand(cmd, chip);
#else
if(y/8 != this->Coord.chip[chip].page)
this->Coord.chip[chip].page = y/8;
cmd = LCD_SET_PAGE | this->Coord.chip[chip].page;
  • NOTE: For now, the "if" below is intentionally commented out.
  • In order for this to work, the code must properly track
  • the x coordinate of the chips and not allow it go beyond proper
  • boundaries. It isnn't complicated to do, it just isn't done that
  • way right now. We currently allow the coordinates to be larger than
  • the actual geometry and just ignore them. This allows things like
  • graphic functions to plot things larger than the display but display
  • those portions that land within the diplays geometry.
x = glcdDev_Xval2ChipCol(x);
#ifdef GLCD_XCOL_SUPPORT
if(x != this->Coord.chip[chip].col)
#endif
this->Coord.chip[chip].col = x;
#endif
#ifdef LCD_SET_ADDLO
cmd = LCD_SET_ADDLO | glcdDev_Col2addrlo(x);
cmd = LCD_SET_ADDHI | glcdDev_Col2addrhi(x);
#else
cmd = LCD_SET_ADD | x;
#endif
#endif // LCD_SET_XYADD
thanks in advance.
in line 24.
Since this is not the complete code, how are we supposed to know which line is 24 ? the error message was probably a bit more specific than that anyway.
You posted only part of your code and didn't post it within </> code-tags
