C# PIN CONTROL WITH ARDUNIO PWM PLEASE HELP !!!
Hello, sorry for my bad english. I am using Ardunio Uno and want to control track bar with C # interface for more than one pwm pin. LED 1 Dimmer LED 2 Dimmer LED 3 Dimmer for example LED 1 = 11 pin brightness turn on, LED 2 = 12 pin brightness turn on, I want to control them all separately. Now I can control only one of them. My knowledge is not working for me. Can someone share C # sample code with ardunio codes? Please help me.
We need to check the pwm pin separately as in the example picture. How can I do this please help. I want separate values ​​for his pin need codes.
Can you share the code for your C# form?
Robin’s updated Serial Input Basics can give you ideas (assuming you are using serial communication although the principles can also be applied to other ways of communication).
