C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\h
Hi guys im new to programming and Arduino. I've experienced this error and I dont know a way around it
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/main.cpp:46: undefined reference to `loop'
Please assist if you solved this error code
Can we see your code?
unsigned long start, finished, elapsed;
#include <Wire.h>
#define Start 11
#define Stop 12
#define readyLED 13
#define buzzer 10
#define contrast 9
int distance = 100; //in METERS!
float velocity;
float time; //seconds
boolean recordedTime = false;
float oldTime = 0;
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address.
int x =0;
float h, m;
int s, ms;
unsigned long over;
void setup ()
lcd.begin(16,2);
pinMode(Start, INPUT_PULLUP); // start button
pinMode(Stop, INPUT_PULLUP); // STOP button
pinMode(readyLED, OUTPUT); // Light to say when the stopwatch is primed
//pinMODE(buzzer, OUTPUT);
digitalWrite(readyLED, LOW);
lcd.setCursor(5,0); lcd.print(“LAP TIMER”);
delay(800);
//lcd.clear();
//analogWrite(buzzer, 0);
//analogWrite(contrast, 75);
//lcd.noDisplay();
lcd.setCursor(0, 2); // set cursor to [character-place 0, line 0]. (first row)
lcd.print(“READY”)
//lcd.write(1);lcd.write(2);lcd.write(3);lcd.write(4);lcd.write(5);lcd.write(6);lcd.write(7);lcd.write(8);
//lcd.setCursor(0, 3); lcd.print(“12345678”);
digitalWrite (readyLED, HIGH);
Romonaga:
Lyle_Wentzel:
#include <Wire.h>
#define Start 11
#define Stop 12
#define readyLED 13
#define buzzer 10
#define contrast 9
float velocity;
float oldTime = 0;
int x =0;
float h, m;
int s, ms;
unsigned long over;
void setup ()
lcd.begin(16,2);
delay(800);
//lcd.clear();
//lcd.noDisplay();
lcd.print(“READY”)
See how much nicer it looks when code is in code tags?
#include <Wire.h>
#define Start 11
#define Stop 12
#define readyLED 13
#define buzzer 10
#define contrast 9
float velocity;
float oldTime = 0;
int x =0;
 float h, m;
 int s, ms;
 unsigned long over;
void setup ()
  lcd.begin(16,2);
  lcd.setCursor(5,0); lcd.print("LAP TIMER");
  delay(800);
  //lcd.clear();
  //lcd.noDisplay();
  lcd.print("READY")
  //lcd.setCursor(0, 3); lcd.print("12345678");
Whre is the loop() function?
When you started a new project you had two blank functions:
The thing don’t work without both of those function present, even if you don’t use them.
