Hi, I have been trying to figure out my problem with sending serial data from arduino to c#.
My arduino sends out readings for Temp, RH, CO2, Light, HighTemp, LowTemp, HighRH, LowRH, HiCo2, LowCo2 every 10seconds, every 5 minutes it takes the average of these values and stores them in eprom.
I pass the values to
void addPacketData(uint32_t S, uint16_t T, uint16_t H, uint16_t C, uint32_t L, uint16_t fil)
savePacket.Sec = S;
savePacket.Temp = T;
savePacket.RH = H;
savePacket.CO2 = C;
savePacket.Lights = L;
savePacket.filler = fil;
eeWrite(getAddress(),savePacket);
delay(5);
getAddress() gets the address Im storing in address 0x0 again this address is stored using a struct, the starting address is 0x40, once the data is stored I increment the address by 16 and store that so the next reading goes into the new address, savepacket is the struct. All that seems to be working fine and in short runs the readings come through fine but when I leave the device for long periods and the data being sent is large it seems to fail and it doesnt even get to the parsing point in c# as I have lots of console.writelines so I can see whats happening.
This is my getHistoricData() which is called when i press a button on the application, Im a little unsure if this is the best way to send all that data, I was going to just send everything as a packet eg 25,85,1600,1,198762537 but if you have 5000 records it may take a while as your reading from eprom / put onto serial port / etc etc.
void getHistoricData()
int numofrecords = (epromaddress.SA - 0x40) / 16;
//Serial.println(numofrecords, DEC);
int TempArray[numofrecords];
int RHArray[numofrecords];
int COArray[numofrecords];
int LightArray[numofrecords];
long int TimeS[numofrecords];
for(unsigned int i = 0x40, p = 0; i < epromaddress.SA; p++, i = i + 16)
Eprom.eeRead(i,histPacket);
delay(10);
TempArray[p] = histPacket.Temp;
RHArray[p] = histPacket.RH;
COArray[p] = histPacket.CO2;
LightArray[p] = histPacket.Lights;
TimeS[p] = histPacket.Sec;
Serial.print("*");
for(int i = 0; i < numofrecords; i++)
Serial.print(TempArray[i], DEC);
Serial.print(",");
Serial.println("*");
Serial.print("{");
Serial.print(RHArray[i], DEC);
Serial.print(",");
Serial.println("{");
Serial.print("+");
Serial.print(COArray[i], DEC);
Serial.print(",");
Serial.println("+");
Serial.print("-");
Serial.print(LightArray[i], DEC);
Serial.print(",");
Serial.println("-");
Serial.print(":");
Serial.print(TimeS[i], DEC);
Serial.print(",");
Serial.println(":");
Once sent to the c# application and it goes through the readserial function I seperate using this
if (text[0] == '[')
ParseCurrentData(text);
if (text[0] == '*')
t_globalstring = text.Substring(1, text.Length - 3);
System.Console.WriteLine(t_globalstring);
if (text[0] == '{')
h_globalstring = text.Substring(1, text.Length - 3);
System.Console.WriteLine(h_globalstring);
if (text[0] == '+')
c_globalstring = text.Substring(1, text.Length - 3);
System.Console.WriteLine(c_globalstring);
if (text[0] == '-')
l_globalstring = text.Substring(1, text.Length - 3);
System.Console.WriteLine(l_globalstring);
if (text[0] == ':')
ti_globalstring = text.Substring(1, text.Length - 3);
addData(t_globalstring, h_globalstring, c_globalstring, l_globalstring, ti_globalstring);
t_globalstring = "";
h_globalstring = "";
c_globalstring = "";
l_globalstring = "";
ti_globalstring = "";
And then it goes into this function
private void addData(string a, string b, string c, string d, string e)
System.Console.WriteLine(a);
System.Console.WriteLine(b);
System.Console.WriteLine(c);
System.Console.WriteLine(d);
System.Console.WriteLine(e);
System.Console.WriteLine("Add data to database here!!");
string[] datT = a.Split(',');
string[] datH = b.Split(',');
string[] datC = c.Split(',');
string[] datL = d.Split(',');
string[] datTi = e.Split(',');
histlistt.Clear();
histlisth.Clear();
histlistc.Clear();
histlistl.Clear();
if (datT.Length > 2)
for (int i = 0; i < datT.Length - 1; i++)
this.histlistt.Add(histlistt.Count, int.Parse(datT[i]));
this.histlisth.Add(histlisth.Count, int.Parse(datH[i]));
this.histlistc.Add(histlistc.Count, int.Parse(datC[i]));
//DataRow dRow = ds1.Tables["THCdata"].NewRow();
//dRow[1] = datT[i];
//dRow[2] = datH[i];
//dRow[3] = datC[i];
//dRow[5] = datTi[i];
if (int.Parse(datL[i]) > 4)
this.histlistl.Add(histlistc.Count, 1);
//dRow[4] = 1;
this.histlistl.Add(histlistc.Count, 0);
//dRow[4] = 0;
//ds1.Tables["THCdata"].Rows.Add(dRow);
UpdateHistGraphs();
//da.Update(ds1, "THCdata");
//port.Write("3");
//GetDataFromDatabase();
I dont think its a problem with c#, before switching to structing everything up I was just allocating long lines of eprom address for each variable and iterating through them, worked no problem for weeks on end. Ive tried changing the port timeout on c# but they have no effect on my problem, i was getting timeout exceptions though this problem because i need to reset the arduino after asking for historic data and it fails.
Regards
