C-String vs Number Comparison
A quick question, say if a number is derived and stored in C-String, and I would like to do a comparison. Would it be more efficient memory and CPU wise to compare it directly as a string, or parse it to a number first? For instance:
char myString[] = "12345678";
if( strcmp_P(myString, PSTR("12345678")) == 0 ) //Is this better?
  //DO Something
if( atol(myString) == 12345678 ) //Or is this better?
  //DO Something
Converting to a number is far more compute-intensive.
Thanks Paul, may I ask would either one consume more memory than the other in the comparison process, or would it not make a difference?
PaulS:
I suspect strcmp_P (scan two strings, read from Flash, with comparison) is more expensive than atol (scan one string with convert) followed by an integer comparison.
I was very wrong. 6.351 μs for strcmp_P; 22.008 μs for atol.
atol takes 94 bytes more Flash. Neither uses SRAM.
With enough string constants strcmp_P will eventually consume more Flash.
Coding Badly thanks, exactly the answer I was looking for. :slight_smile:
You are welcome.
Thank you to @PaulS for keeping me on the right path.
Which is greater, "987" or "12345" ?
Well, "9" is greater than "1" so strcmp would indicate "987" is greater. The integer 987 is less than 12345 so atol would indicate 12345 is greater.
