You have a lot of macro definitions that i believe originate from the PIC world. You have probably have to change or adapt these
Arduino program do NOT have a main() function. Instead they have a setup() function that is called after startup and a loop() function that is called continuously thereafter. In you code, put the (adapted) contents of you main() function up to the while(1) statement and put them into the setup() function. Put the contents of the while(1) loop and put them inte the loop() function
//Initialisation
ansel = 0;
cmcon = 0x07;
//Code Initialisation Interruption
option_reg = 0xC0;
//Appel d'une Macro
//Appel d'une Macro: AjoutDe61sec()
FCM_AjoutDe61sec();
//Appel d'une Macro
//Appel d'une Macro: Pas()
FCM_Pas();
that would be your starting point.
however, you have to rework a lot of the code specific to the LCD, you first would need to figure out what it is doing and how to make the mapping.. there seems to be a significant amount of code in the file "C:\Program Files (x86)\Flowcode\v5\FCD\internals.c" - which isn't even provided here.. just take it one line of code at a time.. add functions as needed.. start with FCM_AjoutDe61sec and FCM_Pas - not all the code may be used.
