Can anyone tell me if these are suitable for use connected to an Output pin ?
I want to drive some 12V relays and some small 12V devices.
Not sure about all the technical terms, but from the data sheet I am (really) guessing that :
this can run safely on anything up to 400V 4A.
needs 2.2V 5mA to activate and hold the gate.
I would need a 560 ohms resistor between the output pin and the gate (calc done using : http://led.linear1.org/1led.wiz ) and a 1K resistor from Gate to Ground to pull down against any floating of the gate pin.
I assume that as this is "Reverse Blocking", I would not get any current from the cathode / anode side ( 12V ) of the chip feeding back into the gate ? or should I add a diode just in case ?
Graynomad:
SCRs will not turn OFF until the AK voltage is removed IIRC. So they aren't very suitable for switching DC items such as relays.
Rob
Thanks Rob.
So if I understand you correctly, once I have powered the gate, even if I remove the gate power, it still remains on, until I stop the flow of the current between cathode and anode ?
Any chance someone can tell me what I should be looking at to get the values for :
max V and A that can pass through the transistor.
V and mA required to activate the transistor.
I guess the pin to base resistor should be calculated in much the same way as for an LED to reduce the voltage to that required by the base ?
Also, would this type of transistor only pass thru current when the base is powered - so when I cut the base power, it breaks the flow thru the transistor ?
