Cable for a Display
Hello, I have a question, The display ( https://www.seeedstudio.com/05-inch-OLED-display-Arduino-shield-p-2194.html# ) must be about 20 cm away from the Arduino Nano, I have still until now found no possibility with which this is possible. The display comes in a place where there is almost no space, so I need a cable with which it is possible to keep the display there. So my question is if there is a cable for my problem? Because I have never done anything like this before, I know nothing about it. Thank you for your answers! xXH_HXx
It sounds like you want a self-supporting remote display on a stalk. Why can't you use some ribbon jumper, bundled with heat-shrink, and with a length of stiff insulated wire inside for additional support?
Do you have enough space for Dupont cables? Would be easy solution. e.g.
https://www.aliexpress.com/item/3set-lot-20cm-Male-male-Male-female-Female-Female-Jumper-Wire-Dupont-Cable-All-120-pcs/1680586000.html
Thank you so much! Well I still have a question if there is a cable to get the display a few inches away from the other thing in the picture?
